Hello!
I bought two 16x2 RGB shields and thought i could make them work separately. I used a little program to search the IC2 bus for addresses but it only finds one address: 0x20. With only 1 address on the bus and when attached both shields to the SDA and SCL pins, whenever i send a command it does the same thing on both LCDs.
Is there any way to change the address of the shields in order to talk to them separately?
You can see my setup on the image below:
Note: The SDA (yellow) and SCL (blue) cables are not connected to the arduino in this photo. I have them connected now.
Ill try to add another photo soon showing both LCDs displaying the same thing.
Thanks! (:
16x2 RGB Shield Address change?
- adafruit_support_bill
Re: 16x2 RGB Shield Address change?
The shield uses the default address for the MCP23017 i2c port expander chip. The chip does have 3 address pins and it is possible to re-address the shield with a bit of hacking.
Here are the links to the schematics and data sheets. The address pins (15, 16 & 17) are currently all tied to GND. You can pull one or more of them high with a jumper to change the address.
https://github.com/adafruit/Adafruit-RGB-LCD-shield
http://www.adafruit.com/datasheets/mcp23017.pdf
- rodcar125
Great, I'll give it a try and report back
Thanks a lot!
Rodrigo
Thanks a lot!
Rodrigo
- rodcar125
Hi again,
Maybe this is a silly question but do i just connect a 5V cable to any of the pin number 15, 16 or 17? does the shield has specific pins i could connect them to? i reviewed the schematic you posted searching for the pin from the IC to the board but i can figure it out ):
Thanks again!
Thanks again!
The pins now are connected to ground. If you just connect 5v to it, you will create a short circuit. You need to cut the pin where it is soldered to the shield, bend it out away from the board, then solder a jumper from it to 5v.
- rodcar125
Really glad I asked before doing something stupid!
I have desoldered the pin 15 from the board and solder a jumper to that pin. I added a couple drops of hot silicone for support since the leg its too weak. Ill try it as soon as i get home (:
I suppose ill have to create two different instances of the Adafruit_RGBLCDShield for the LCDs right?
something like:
something like:
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
Adafruit_RGBLCDShield lcd2 = Adafruit_RGBLCDShield();
- rodcar125
I connected everything and ran the I2C scanner...
Awesome!!
Now ill try to figure out how to talk to each one.
Thanks a lot Bill!!
Awesome support team
Awesome!!
Thanks a lot Bill!!
- mikel_hubo
had the same adress conflict and solved it to 20 and 22
Where in the driver software do I have to change the adress to 22 now ?
thx for helping
mikel
thx for helping
mikel
On line 119 of Adafruit_RGBLCDShield.cpp
To change from 20 (the default) to 22, change:
To:
_i2c.begin();
_i2c.begin(2);
- mikel_hubo
Hi and thanks for the quik answer.
I got a next one question on this,
where do I find the source code of Adafruit_RGBLCDShield.cpp
thx for helping
mikel
thx for helping
mikel
The library code is here in github:
https://github.com/adafruit/Adafruit-RG ... ld-Library
- mikel_hubo
Thanks a lot !
