Since the Rx/Tx leds are on the processor side of the 8u2 chip, I suspect that is working OK. I think you are looking at a corrupted bootloader or possibly a bad processor (it doesn't necessarily have to release smoke to get fried).
In the IDE under File->Preferences, you can enable "verbose" output for the upload. That will show you if there is any response at all from the processor.
Programing Motor Shield V2
Re: Programing Motor Shield V2
So i did that and tried to upload the code again and this appeared:
Binary sketch size: 9,760 bytes (of a 258,048 byte maximum)
C:\Users\Colin\Desktop\Arduino\hardware/tools/avr/bin/avrdude -CC:\Users\Colin\Desktop\Arduino\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cwiring -P\\.\COM7 -b115200 -D -Uflash:w:C:\Users\Colin\AppData\Local\Temp\build6796389473833654899.tmp\Motorcontroller_Test.cpp.hex:i
avrdude: Version 5.11, compiled on Sep 2 2011 at 19:38:36
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Users\Colin\Desktop\Arduino\hardware/tools/avr/etc/avrdude.conf"
Using Port : \\.\COM7
Using Programmer : wiring
Overriding Baud Rate : 115200
avrdude: wiring_open(): releasing DTR/RTS
avrdude: wiring_open(): asserting DTR/RTS
avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14]
avrdude: Recv:
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude done. Thank you.
Looks like your bootloader is not responding at all. You might be able to re-flash it. The Arduino.cc forums would be your best resource for details on that.
I attempted to re-burn the bootloader onto the board but i got this error message:
C:\Users\Colin\Desktop\Arduino\hardware/tools/avr/bin/avrdude -CC:\Users\Colin\Desktop\Arduino\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -Pusb -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xD8:m -Ulfuse:w:0xFF:m
Using Port : usb
Using Programmer : stk500v2
avrdude: usbdev_open(): did not find any USB device "usb"
What are you using to burn the bootloader?
Under tools there is an option that says "Burn Bootloader"
You can't do it over the regular USB connection. You ned an ISP programmer of some sort,
http://arduino.cc/en/Hacking/Bootloader ... Bootloader
Could I send the board to you guys and have you burn the bootloader instead?
I'm sorry, but we are not set up for that sort of thing. If the board were in warranty and purchased from us we would replace it for you. But it sounds like you have an older board.
Ok I'll get an ISP programer and burn the boot loader myself.
Ok, I burned the bootloader on to the old board and the upload still failed. These lines of code appeared in the communications box at the bottom of the window: I think this maybe a problem with ether avrdude, the cable, for the upload software, but i don't know.
C:\Users\Colin\Desktop\Arduino\hardware/tools/avr/bin/avrdude -CC:\Users\Colin\Desktop\Arduino\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cwiring -P\\.\COM8 -b115200 -D -Uflash:w:C:\Users\Colin\AppData\Local\Temp\build7573687462377458720.tmp\Motorcontroller_Test.cpp.hex:i
Using Port : \\.\COM8
avrdude: Recv:
avrdude: Recv:
What kind of programmer are you using, and are you sure you've selected the right type under the 'Programmer' menu?
Yes, also i tried uploading to an other mega i have, and i got the same result.
Hmm.. are you sure you've selected the right target under the Tools -> Board menu?
Yes I even tried to upload after I re-downloading the software, and used a new cable both with the new and old boards, and i got the same result. Do you think it's a problem with avrdude?
