I'm driving a 7-segment LED from a constant-current driver that matches the audio file being played. Excuse my code..
This is an example for the Adafruit VS1053 Codec Breakout
Designed specifically to work with the Adafruit VS1053 Codec Breakout
----> https://www.adafruit.com/products/1381
products from Adafruit!
BSD license, all text above must be included in any redistribution
// include SPI, MP3 and SD libraries
#include <SPI.h>
#include <Adafruit_VS1053.h>
#include <SD.h>
// define the pins used
//#define CLK 13 // SPI Clock, shared with SD card
//#define MISO 12 // Input data, from VS1053/SD card
//#define MOSI 11 // Output data, to VS1053/SD card
// Connect CLK, MISO and MOSI to hardware SPI pins.
// See http://arduino.cc/en/Reference/SPI "Connections"
// These can be any pins:
//#define RESET 9 // VS1053 reset pin (output)
//#define CS 10 // VS1053 chip select pin (output)
//#define DCS 8 // VS1053 Data/command select pin (output)
//#define CARDCS 4 // Card chip select pin
// DREQ should be an Int pin, see http://arduino.cc/en/Reference/attachInterrupt
//#define DREQ 3 // VS1053 Data request, ideally an Interrupt pin
// above was original
// below is from kerns_JW on Adafruit https://forums.adafruit.com/viewtopic.php?f=25&t=53543&p=270725#p270725
//Define MP3 Shield Setup
#define RESET 31 // VS1053 reset pin (output)
#define CS 30//7 // VS1053 chip select pin (output)
#define DCS 34//6 // VS1053 Data/command select pin (output)
#define DREQ 3 // VS1053 Data request pin (into Arduino)
#define CARDCS 32//4 // Card chip select pin
const int ledData = 44;//4;
const int ledClk=46;//5;
const int ledOe=5;//6;
const int ledLat=6;//7;
const int aseg=B10000000;
const int bseg=B1000000;
const int cseg=B100000;
const int dseg=B10000;
const int eseg=B1000;
const int fseg=B100;
const int gseg=B10;
char testdigit=0;
Adafruit_VS1053_FilePlayer musicPlayer = Adafruit_VS1053_FilePlayer(RESET, CS, DCS, DREQ, CARDCS);
pinMode(ledData,OUTPUT);
pinMode(ledClk,OUTPUT);
pinMode(ledOe,OUTPUT);
pinMode(ledLat,OUTPUT);
digitalWrite(ledOe,1);
Serial.begin(9600);
Serial.println("Adafruit VS1053 Simple Test");
musicPlayer.begin(); // initialise the music player
SD.begin(CARDCS); // initialise the SD card
// Set volume for left, right channels. lower numbers == louder volume!
musicPlayer.setVolume(20,20);
// Timer interrupts are not suggested, better to use DREQ interrupt!
//musicPlayer.useInterrupt(VS1053_FILEPLAYER_TIMER0_INT); // timer int
// If DREQ is on an interrupt pin (on uno, #2 or #3) we can do background
// audio playing
musicPlayer.useInterrupt(VS1053_FILEPLAYER_PIN_INT); // DREQ int
// Play one file, don't return until complete
musicPlayer.playFullFile("1.wav");
delay(3000);
musicPlayer.playFullFile("2.wav");
//delay(3000); musicPlayer.playFullFile("firstservice.output.wav");
//delay(3000); musicPlayer.playFullFile("goback.output.wav");
// Play another file in the background, REQUIRES interrupts!
//musicPlayer.startPlayingFile("track002.mp3");
byte tempnumber;
byte number;
char filename[6]="1.wav";
testdigit++;
if(testdigit>9){
testdigit=0;
number=0;
for(tempnumber=0;tempnumber <testdigit;tempnumber ++)
number+=1<<tempnumber;
writeByte(maskDigit(testdigit));
delayMicroseconds(1);
digitalWrite(ledLat,1);
digitalWrite(ledLat,0);
digitalWrite(ledOe,0);
// File is playing in the background
if (musicPlayer.stopped()) {
//delay(500);
filename[0]=testdigit + 48;//converts to ascii numeral
musicPlayer.playFullFile(filename); // Serial.println("Done playing music");
//musicPlayer.startPlayingFile(filename);
//while (1);
if (Serial.available()) {
char c = Serial.read();
// if we get an 's' on the serial console, stop!
if (c == 's') {
musicPlayer.stopPlaying();
// if we get an 'p' on the serial console, pause/unpause!
if (c == 'p') {
if (! musicPlayer.paused()) {
Serial.println("Paused");
musicPlayer.pausePlaying(true);
} else {
Serial.println("Resumed");
musicPlayer.pausePlaying(false);
delay(100);
void writeByte(byte mydata)
uint8_t bitMask;
for (bitMask = 0x01; bitMask; bitMask <<= 1)
digitalWrite(ledData, (bitMask & mydata)?1:0);
digitalWrite(ledClk,1);
digitalWrite(ledClk,0);
//Serial.println();
byte maskDigit(byte mydigit)
byte temp;
switch (mydigit) {
case 1:
temp=bseg | cseg;
break;
case 2:
temp=aseg | bseg | gseg | eseg | dseg;
break;
case 3:
temp=aseg | bseg | cseg | gseg | dseg;
break;
case 4:
temp=fseg | gseg | bseg | cseg;
break;
case 5:
temp=aseg | fseg | gseg | cseg | dseg;
break;
case 6:
temp = aseg | fseg | eseg | dseg | cseg | gseg;
break;
case 7:
temp=aseg | bseg | cseg;
break;
case 8:
temp =aseg | bseg | cseg | dseg | eseg | fseg | gseg;
break;
case 9:
temp =aseg | bseg | cseg | dseg | fseg | gseg;
break;
case 0:
temp =aseg | bseg | cseg | dseg | eseg | fseg ;
break;
default:
temp=0;
//Serial.print(" ");
//Serial.print( temp,DEC);
return temp;
