2.8" TFT Touch Down Event
figgyb
2.8" TFT shield - touch buffer issues
Post by figgyb »
I seem to always have bad data in my touch buffer, and suspect I am missing something. I noticed in the example sketch, the following
ts.writeRegister8(STMPE_INT_STA, 0xFF); // reset all ints
but there was no explanation as to what it does. What does it do? Is it related to the ts buffer?
figgyb
Re: 2.8" TFT shield - touch buffer issues
Post by figgyb »
Sample code. This is multiple presses in to the menu and always kicks back an old value :(
//table showing cell mv readings with yellow button area on top
void startChartData(O2Sensor Cells[], PressureSensor P1)
  unsigned long prevTime = 0;
  //set first cell to plot
  uint8_t activeCell = 1;
  //refresh sensor data
  getCell_mV(Cells);
  getPressure(P1);
  setupLCD_chartData(Cells, activeCell);
  printChartData(Cells, activeCell);
  while (1) {
    if(millis() - prevTime > 1000) {
      getCell_mV(Cells);
      getPressure(P1);
      //print current cell mv on table row 1
      tft.setTextColor(ILI9341_BLUE);
      tft.fillRect(90, 79, 70, 15, ILI9341_BLACK);
      tft.setCursor(100, 79); tft.print(Cells[activeCell-1].mV);
      //print pressure in yellow button area
      tft.setTextColor(ILI9341_RED);
      tft.fillRect(253, 21, 60, 15, ILI9341_YELLOW);
      tft.setCursor(253, 21); tft.print(convertkPa(P1.pressure, ATA), 3);
      prevTime = millis();
    if (touch.touched()) {
      int x = 0;
      int y = 0;
      while (! touch.bufferEmpty()) {
        //cycle through all to select last coordinates for finger lift
        mapTouchscreen(x, y);
        Serial.print("map> "); Serial.print(x); Serial.print(", "); Serial.println(y);
      if (x < 75 && y < 80) {
        // Mark selected
        Serial.println("Lock selected");
        Serial.print("used> "); Serial.print(x); Serial.print(", "); Serial.println(y);
        chartData_SavePoint(Cells, P1, activeCell);
      else if (x > 85 && x < 155 && y < 80) {
        // Clear Selected
        Serial.println("Graph cells selected");
        //clear cell pts
        //redraw screen
        //draw linear
      else if (x > 165 && x < 235 && y < 80) {
        //swap cells selected
        Serial.println("swap cells selected");
        activeCell++;
        if(activeCell > 3) activeCell = 1;
      else break;
void mapTouchscreen(int &x, int &y)
  //TS_Point p = touch.getPoint();
  uint16_t y1=0;
  uint16_t x1=0;
  uint8_t z1=0;
  touch.readData(&x1, &y1, &z1);
  //p.x = map(p.x, TS_MINY, TS_MAXY, 0, tft.height());
  //p.y = map(p.y, TS_MINX, TS_MAXX, 0, tft.width());
  //y = tft.height() - p.x;
  //x = p.y;
  x1 = map(x1, TS_MINY, TS_MAXY, 0, tft.height());
  y1 = map(y1, TS_MINX, TS_MAXX, 0, tft.width());
  y = tft.height() - x1;
  x = y1;
  //Serial.print("ori> "); Serial.print(p.x); Serial.print(", "); Serial.println(p.y);
figgyb
Post by figgyb »
Anyone?
asteroid
Post by asteroid »
The following source code template was recently published on this forum as a way to trap 'touch down' events ( I added some code to it in order to create a runnable demo). However, I am unable to get it to work correctly. If the screen is touched in all four corners starting in the left lower and going clockwise (USB on right) this record may be generated:
X = 65527 Y = 65526
X = 231 Y = 285
X = 229 Y = 290
X = 19 Y = 297
X = 17 Y = 298
X = 17 Y = 21
X = 16 Y = 20
X = 228 Y = 13
Note that each corner has to be touched twice in order to get the correct value (shown in red). Furthermore, the initial touch down event is incorrect. The 'current' touch down event is actually reporting the one immediately preceding it, and is always one behind. Any help would be appreciated. The source code follows:
  Demonstrates "touch down" event
  UNO + 2.8 TFT Touch Shield - v2
  USB in right lower corner
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_ILI9341.h>
#include <Adafruit_STMPE610.h>
// Default values for Adafruit shield v2.
#define STMPE_CS 8
#define TFT_DC 9
#define TFT_CS 10
Adafruit_STMPE610 ts = Adafruit_STMPE610(STMPE_CS);
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
 #define TS_MINX 150
 #define TS_MINY 130
 #define TS_MAXX 3800
 #define TS_MAXY 4000
void setup()
  Serial.begin(9600);
  tft.begin();
  ts.begin();
void loop()
  uint16_t x = 0;
  uint16_t y = 0;
  TS_Point p = ts.getPoint();
  // wait for a touch
  if (! ts.touched()) {
    return;
  x = map( p.x, TS_MINX, TS_MAXX, 0, tft.width());
  y = map( p.y, TS_MINY, TS_MAXY, 0, tft.height());
  // print the "touch down" position
  Serial.print("X = "); Serial.print(x);
  Serial.print("\tY = "); Serial.println(y);
  //hang around in a while loop until the touch is released
  while (ts.touched()) {
adafruit_support_rick
Re: 2.8" TFT Touch Down Event
Post by adafruit_support_rick »
Should work. But try it this way instead:
void loop()
  uint16_t x = 0;
  uint16_t y = 0;
  // wait for a touch
    return;
asteroid
Post by asteroid »
Unfortunately, the problem persists. Now a touch in all four corners (starting in left lower, USB on right) yields the following Serial Monitor data:
X = 65527 Y = 65526
X = 235 Y = 291
X = 237 Y = 291
X = 237 Y = 291
It no longer gives different data for each corner.
asteroid
Post by asteroid »
I'm also experiencing this problem and interested in finding a solution. However, it is difficult for me to follow the sample code that you posted. Would it be possible to write a simple runnable demo which illustrates the problem?
Strange. There's obviously some sort of buffering going on. However, the following seems to work, and should get you going:
#include <SPI.h>
#include <Wire.h>
#define STMPE_CS 8
#define TFT_DC 9
#define TFT_CS 10
 #define TS_MINX 150
 #define TS_MINY 130
void setup()
  Serial.begin(9600);
  tft.begin();
  ts.begin();
void loop()
  uint16_t x = 0;
  uint16_t y = 0;
  // wait for a touch
    return;
  delay(100);
  p = ts.getPoint();
asteroid
Post by asteroid »
Thank you, Rick. Now I get the correct data with a touch in each lcd corner:
X = 237 Y = 288
X = 16 Y = 288
X = 18 Y = 17
X = 237 Y = 13
