Is there technical documentation for the Bluefruit EZ-link Shield? I'd like a schematic and a general description of its pins.
Need Tech info for EZ-link Shield (1628)
- Franklin97355
- Rude_Dog
Re: Need Tech info for EZ-link Shield (1628)
Thanks for the speedy reply! Is there a PDF version of the schematic? Or, am I going to have to install something from EagleCAD in order to view the schematic file?
On the second link, that product has a nice description, but it's a different/smaller board. Is there something like that for shield that I bought (1628)?
- Franklin97355
The breakout and the shield use exactly the same code and hardware for communications. The schematic is in that above link and yes you need to download the free eagle program.
- Rude_Dog
The breakout has 8 terminals
Sts Not found on shield
GND Found on shield
DSR Found on shield
Vin Found on shield (doesn't connect to anything)
TX Not found on shield, but might be digital I/O 0
RX Not found on shield but might be digital I/O 1
DTR Not found on shield
3v Found on shield
The shield has
5v
RST
IOr
Conn
3Vo
STX
STR
Soft Serial/Direct switch
Reset Switch
These are all not found on the breakout. I don't understand how "exactly the same" applies here. Is there a document that guides the purchaser in the use of these features that are different and/or additional over the breakout board?
Also, is there a datasheet for the EZ-link module that's used on both the breakout and shield?
GND Found on shield
DSR Found on shield
3v Found on shield
The shield has
5v
RST
IOr
Conn
3Vo
STX
STR
Reset Switch
- Rude_Dog
When I load the the file Adafruit EZ-Link Shield v1.1.sch into Eagle 7.0.0 Light, it gives me this message:
Error:
line 7, column 18: This is not an EAGLE file.
I tried downloading the file a second time, but got the same result. Could you direct me to a copy of the file that works?
Error:
- adafruit_support_rick
Here's a png of the schematic
- EZ-Link_shield_v1-1.png (45.18 KiB) Viewed 297 times
- adafruit2
Try eagle 6 - eagle 7 came out like 3 days ago and all our files are eagle 6!
