adafruit gps breakout v3.0
fleetprobe
Post by fleetprobe »
We are currently testing the gps breakout board in multiple cars. But we encounter a deadlock which consists of the modules not giving any output at all, untill we reset the atmega. Is there a workaround for this or do you have any idea what might be causing this?
Note that we use the sleep- and wake-function. So the module is put to sleep when the cars stops and is woke up when the car starts. During all times the module has vin power.
Franklin97355
Re: adafruit gps breakout v3.0
Post by Franklin97355 »
Could you post your code ? Please use the code button "</>" in the button bar when posting code to the forums.
Also could you post clear pictures of your board, any soldering you did and the connections to it?
fleetprobe
it's a difficult to post code. As its a big project. The soldering is just 2 wires to ground and vin powered by the 5v ldo of the atmega. and the rx and tx are mounted on a header. When the module is not spitting out anymore it doesnt help wiggling the rx tx, there's also no led so the gps module should have a fix and the 5v supply is never interrupted. Would it be possible the module goes into a state where #define PMTK_AWAKE "$PMTK010,002*2D\r\n" is not effective anymore for waking up?
fleetprobe
This is the constructor and initialization of the gtop module:
#define MTK_OUTPUT_5HZ	       "$PMTK220,200*2C\r\n"
#define PMTK_SET_NMEA_OUTPUT_RMCGGA "$PMTK314,0,0,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*29\r\n"
#define WAAS_ON                "$PMTK301,2*2E\r\n"
#define SBAS_ON	               "$PMTK313,1*2E\r\n"
#define MTK_DT_SBAS_ENABLED    "$PMTK513,1*28\r\n"
#define MTK_SBAS_INTEGRITYMODE "$PMTK319,1*24\r\n"
#define MTK_DT_DGPS_WAAS       "$PMTK501,2*28\r\n"
gpslib::gpslib(HardwareSerial *_serial) {
	// TODO Auto-generated constructor stub
	this->_serial = _serial;
	_serial->begin(9600);
	delay(2000);
	_serial->println(MTK_OUTPUT_5HZ);
	_serial->println(PMTK_SET_NMEA_OUTPUT_RMCGGA);
	_serial->println(WAAS_ON);
	_serial->println(SBAS_ON);
	_serial->println(MTK_DT_SBAS_ENABLED);
	_serial->println(MTK_SBAS_INTEGRITYMODE);
	_serial->println(MTK_DT_DGPS_WAAS);
This is the sleep wake code :
#define PMTK_STANDBY "$PMTK161,0*28\r\n"
void sleep(){
	_serial->println(PMTK_STANDBY);
void wake(){
	_serial->println(PMTK_AWAKE);
This is how we read the output:
bool gpslib::findGPGGA() {
	unsigned long start_time = millis();
	memset(message, '\0', GPS_BUFFER_SIZE);
	bool startfound = false;
	bool endfound = false;
	int i = 0;
	do {
		char c = _serial->read();
		if (c != 0xFFFF) {
			if (c == '$') {
				startfound = true;
				i = 0;
			} else if (startfound && c == '\n') {
				endfound = true;
			if (startfound && !endfound) {
				message[i++] = c;
			if (endfound && strstr(message, "$GPGGA") == NULL) {
				Serial.println(message);
				i = 0;
				endfound = false;
				startfound = false;
			} else if (endfound && strstr(message, "$GPGGA") != NULL) {
				return 1;
	} while (millis() - start_time < 1500UL && i < GPS_BUFFER_SIZE);
	return 0;
Any help would be appreciated.
fleetprobe
Did anyone have any time to look at this or maybe share some experience in these modules?
Franklin97355
You have not posted pictures or the code as requested yet. If this is an Arduino sketch it will fit between
 tags just fine.
fleetprobe
Attached is a picture of our selfdesigned pcb with the gps module on it. It uses an atmega2560. The gps module is on Serial3. We have noticed that we sometimes get incomplete messages aswell as the deadlock that sometimes happens. As I said it is impossible to give you all the code as it is a big project. But the relevant gps code has been included in the post before.
Franklin97355
OK, I have no more ideas. Perhaps someone will chime in here.
JimBob
Post by JimBob »
Curious as to how you are constructing the sentences with "\n\r" and also sending the command with _serial->println - aren't you essentially sending two "end" sentinels. Are you also sending the LRC?
Does the GPS respond with a good acknowledgement packet?
fleetprobe
yes we know we send /n/r/n at the end, it is just to be on the safe side serial.println("command\r") should actually be enough. The LRC is sent in the initialization methods it starts after "*" and has been calculated according to the pmtk spec. For the parsing of messages we also check if the LRC is correct.
adafruit_support_mike
Try dropping the extra end-of-line characters. If the extra characters aren't spec, they aren't a safety margin.
Most text input handling is done with a state machine, and every input character triggers a transition. The input sequence "\n\r\n" will trigger three transitions to the "\n" sequence's one. It's possible that the input lexer is getting stuck in some kind of error state, or a state where it's waiting for a specific character sequence.
