Hello!
I need to control many LEDs via PWM, so i've bought for 16-Channel 12-bit PWM/Servo Shields.
At the moment i've chained 2 shields together, as shown here on manual:
https://learn.adafruit.com/16-channel-p ... ng-drivers
On the first one there in no jumpers soldered so it has 0x40, on second i've soldered so to have 0x41.
I can control only one board. Either 0x40 or 0x41, but not two same time
Basically i need similar to basic PWM test(from library) but using multiple boards, how can i do that?
Chaining up multiple 16-Channel 12-bit PWM/Servo Shields
- MaD_YeTTi
- adafruit_support_rick
Re: Chaining up multiple 16-Channel 12-bit PWM/Servo Shield
Please post clear, detailed pictures of both boards and of the wiring between them.
- MaD_YeTTi
Please pay no attention to LEDs.
It's just powered off at the moment.
- Attachments
- 20140823_183714 copy.jpg (167.37 KiB) Viewed 324 times
- 20140823_183655 copy.jpg (188.17 KiB) Viewed 324 times
It looks as if you haven't soldered any of those jumper wires between the two boards. Are they soldered? The LEDs don't look soldered, either.
- MaD_YeTTi
Yes, all the wires between the PWM board are soldered, LEDs are not, they are there just for test purposes(and they are working properly), later i'll solder there wires till LEDs.
I can use first board if i use in sketch 0x40 or second one using address or 0x41.
Just like here, in tutorial:
But i'd like to use more boards(more than one) to controll more leds.
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x40);
// you can also call it with a different address you want
//Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x41);
Serial.begin(9600);
Serial.println("16 channel PWM test!");
pwm.begin();
pwm.setPWMFreq(1600); // This is the maximum PWM frequency
// save I2C bitrate
uint8_t twbrbackup = TWBR;
// must be changed after calling Wire.begin() (inside pwm.begin())
TWBR = 12; // upgrade to 400KHz!
// Drive each PWM in a 'wave'
for (uint16_t i=0; i<4096; i += 8) {
for (uint8_t pwmnum=0; pwmnum < 16; pwmnum++) {
pwm.setPWM(pwmnum, 0, (i + (4096/16)*pwmnum) % 4096 );
Ah. I see. The problem is that you have to address each board individually. So you need two instances of the pwm object, one for each board:
#include <Wire.h>
Adafruit_PWMServoDriver pwm1 = Adafruit_PWMServoDriver(0x40);
Adafruit_PWMServoDriver pwm2 = Adafruit_PWMServoDriver(0x41);
Serial.begin(9600);
pwm1.begin();
pwm1.setPWMFreq(1600); // This is the maximum PWM frequency
pwm2.begin();
pwm2.setPWMFreq(1600); // This is the maximum PWM frequency
. . . etc . . .
- Franklin97355
You would write your code to start more than one instance of pwm
Adafruit_PWMServoDriver pwm0 = Adafruit_PWMServoDriver(0x40);
Adafruit_PWMServoDriver pwm1 = Adafruit_PWMServoDriver(0x41);
Adafruit_PWMServoDriver pwm2 = Adafruit_PWMServoDriver(0x42);
- MaD_YeTTi
Thanks very much!!! Now everything is working perfect!!!adafruit_support_rick wrote:Ah. I see. The problem is that you have to address each board individually. So you need two instances of the pwm object, one for each board:Code: Select all
#include <Wire.h> #include <Adafruit_PWMServoDriver.h> Adafruit_PWMServoDriver pwm1 = Adafruit_PWMServoDriver(0x40); Adafruit_PWMServoDriver pwm2 = Adafruit_PWMServoDriver(0x41); void setup() { Serial.begin(9600); Serial.println("16 channel PWM test!"); pwm1.begin(); pwm1.setPWMFreq(1600); // This is the maximum PWM frequency pwm2.begin(); pwm2.setPWMFreq(1600); // This is the maximum PWM frequency . . . etc . . .
IMHO it's a good idea to put that into FAQ.
Yup. I put it right on the Chaining Drivers page.MaD_YeTTi wrote:IMHO it's a good idea to put that into FAQ.
