How To Make A Program Adafruit Motor Shield V2 With Button S
Re: How To Make A Program Adafruit Motor Shield V2 With Butt
So if I use this motor, is it still safe to use Adafruit Motor Shield v2
I don't know. I need to know the coil resistance per phase.
How do you know where the ideal speed of the motor, can you provide a way to search for ideal speed
It is a combination of the motor, the driver, the power supply and the load. You have to test them as a system to find the maximum speed.
Inra_Juntak
Post by Inra_Juntak »
If i still using this motor, but i using heatshik for chip driver, Is the motor still safe drivers
Inra_Juntak
This it the specification
Model No:42BYGH1861A-C
Step Angle (degrees) :1.8
2 Phase
Rated Voltage : 3.4V
Current : 1.7A/PHASE
Holding Torque : 3.5kg*cm (48.6 oz/in)
Detent Torque: 180g*cm
5mm Diameter Drive Shaft
Winding resistance: 2±10% Ω/PHASE
Winding inductance: 2±20% mH/PHASE
Max flux linkage: 1.8 Vs
Maximum Detent Torque: 0.016 N.M
Total inertia (kg.m.m): 3.5 Kg.m.m
Total friction (kg.m/s): 4 Kg.m/s
Step Angle Accuracy : ±5% (full step, no load)
Temperature Rise: 80°C Max.(rated current,2 phase on)
Ambient Temperature: -20°C~+50°C
Isulation Class: B
Life: 6000 hours
Cable Length:50cm
Weight: 270 gram
That motor is not compatible with the V2 motor shield. You need to use a current-limiting driver. Please read this guide on how to select the right driver for your motor:
https://learn.adafruit.com/all-about-st ... he-stepper
Inra_Juntak
Ok, Thank You
Inra_Juntak
Sorry before I asked again, If I use this motor, with a working voltage of 4V and Work current 1.2 A, what coud, the work of the motor rated current equal to the current work of the motor driver
As I said, I need to know the coil resistance. The V2 motor shield is a constant voltage driver. With motors designed for current-limiting drivers, the rated current may be less than the rated voltage divided by the coil resistance.
Most motors of that size with voltage ratings as low as 4v are designed for use with current limiting drivers.
Inra_Juntak
Ok,
I have finding the specification of motor but not meet
Inra_Juntak
I want to ask again. When adjusting the speed of the motor using a 10K potentiometer with different 5K, then I want to ask if the value of the motor speed in RPM of 1-255 In units of voltage and current,
Best Regards,
BANNED Juntak
For stepper motors, the motor speed is expressed in RPM. This is translated into a step rate. It is not related to voltage or current.
Inra_Juntak
Is it different when the motor speed setting potentiometer different uses resistance
The potentiometer just gives us a variable voltage to measure. We convert that into a RPM value and calculate a step rate. The step rate is what determines the motor speed.
Inra_Juntak
Now, i know resistance the coil per phase, the resistance is 3.3 Ohm/phase,
So, how to calculate the torque and the speed ideal from this motor.
Best Regards,
BANNED.S
That motor is at the very upper limit of the motor shield current rating. If you use this motor, I would recommend adding heat-sinks to the bridge chips.
https://www.adafruit.com/product/1041
This must be determined by testing. The stepper motor manufacturer should be able to supply a speed torque curve for the motor: http://www.linengineering.com/contents/ ... Basics.pdf
Inra_Juntak
I use this (https://www.adafruit.com/products/1042) I've been ordering it, just waiting for my orders have arrived.
