Motor Shield V 2.0 - Not Functioning with DC Motors
Re: Motor Shield V 2.0 - Not Functioning with DC Motors
If you connect a motor directly to the external power jumper, it will be powered directly by your 9v power supply. Does you motor turn when you do that?
- blkrush
Yes! It does work. So then what could be going wrong.?
- blkrush
Both motors work perfectly when plugged directly into the external power jumper, but when placed in M1, it does not work. My code is set to "1"
Run the i2c scanner on your Arduino and post the output: http://playground.arduino.cc/Main/I2cScanner
- blkrush
Scanning...
No I2C devices found
Scanning...
Scanning...
- blkrush
Oh.. when I apply a certain amount of pressure, the scanner finds 0x61... So then the soldering is the issue?
Which Arduino are you using?
- blkrush
Arduino (Uno R3) (v1.3)
An UNO R3 should be compatible. If you contact [email protected] with a link to this thread, we can send you a replacement shield.
- jonsberndt
I have a similar problem. I got the motor shield a couple of weeks ago and set about setting it up this weekend, soldering in the header extensions. I got a 3-wire servo to work connected up to SERVO 2. I'm using a heavy duty 9 volt battery pack and inverting the power off the shield to supply my Arduino Uno R3. The green light glows on the motor shield. The motor works when connected to the external power terminals. The motor will not work on any of the motor terminals. When I run I2C I get this:
Scanning...
I2C device found at address 0x60 !
I2C device found at address 0x70 !
done
So ... what's this? The board isn't found at 0x61. I'm trying to run the standard AFMotor Motor Test sketch. No luck.
Jon
Scanning...
done
Jon
- blkrush
Jon,
Well I figured out my problem. First off, I do not know much about what your motors require, but I do not that is explicitly says that you should not use 9 volt batteries. Also, if it is hows 0x60, then you should just use that, as opposed to 0x61. Try it and let me know? It seems our problems were the same. Also, a big problem for me was the soldering. My shield was not sitting flat and therefore all of the pins were not in contact. I corrected it, but when my free replacement comes, I am going to solder it and ensure that my pins are long enough.
@jonsberndt
Your device is at the normal address. You do not need to specify 0x61. Yours should work with the example code as-is.Scanning...
done
- jonsberndt
Thanks - I thought that this would be the case. Any recommendations on next steps for diagnostics? I.compiled and uploaded the motor test seemingly without problems. All the lights on the boards are on. The serial monitor shows tick ticks being logged. The motors (both of them that I have tried) work fine when touched to the external power contacts on the shield. The servo port on the shield works.adafruit_support_bill wrote:@jonsberndtYour device is at the normal address. You do not need to specify 0x61. Yours should work with the example code as-is.Scanning...
done
Jon
- blkrush
Jon, have you tried using the first port, instead of the second servo port? Also, I do not think this matters, but try placing it on in different directions?
Good luck.
Good luck.
Jon - Please post photos of the board showing all of your soldering and motor connections.
