Hi ,
I am trying to follow the instructions for your music maker and when I made the little change to the Player-simple test code , I then had this error on verify:
player_simple:44: error: 'SHIELD_RESET' was not declared in this scope
Please advise?
Music maker code problems
- SeiRruf
Re: Music maker code problems
Can you please post a copy of the code you revised?
From that error, it's declaring that the (defined?) variable 'SHIELD_RESET' was never declared. You may have accidentally deleted it, forgot to define it (typeo?) or moved some things around.
The only reset variable I know that exists in the sample code is "BREAKOUT_RESET". You can try replacing "SHIELD_RESET" on line 44 with "BREAKOUT_RESET", if you made changes there.
I doubt it would work too well but you could also try adding "#define BREAKOUT_RESET 9" to the top of your code to please the error.
Just some troubleshooting while you wait for more support replies.
Thanks, I figured that out and changed BREAKOUT to SHIELD.
- mikethechap
I had this as well. Is there someplace I can post the corrected script so the Library can be corrected? As soon as I changed it to BREAKOUT_RESET instead of SHIELD_RESET on the first variable, it worked, The rest of the new code seems fine. But, the first variable should be BREAKOUT_RESET, not SHIELD_RESET. Thanks.
You can post the code here in the forums.. just put CODE tags around it to preserve the formatting and make it easy for folks to select and copy it.
