Just received my PowerBoost 500 Shield.
With power switch on there is no 5V output.
Checked my battery voltage while connected to board and my meter reads 0.0 VDC.
With battery disconnected from board 3.9 VDC
Tried 2 more lipoly batteries of different capacities with same results.
Measured resistance of boards battery terminals with a reading of 0.27 ohms.
No output from PowerBoost 500 Shield
- Franklin97355
Re: No output from PowerBoost 500 Shield
Could you post clear pictures of both sides of your board showing any soldering you have done and then email [email protected] with a link to this thread for a replacement
- daygecko
Pictures of faulty board.
- daygecko
Looks like two more Powerboost failures today.
- Franklin97355
Try adding a bit of solder to those pins and try again. Take a look at this Soldering Guide for some help.
- daygecko
Adding more solder to a faulty board is not going to magically make it work again.
A good board isn't going to work if not properly soldered either.
