NeoPixel Shield examples
JesssB
Post by JesssB »
I have recently purchased a NeoPixel Shield, downloaded all the libraries for it, read the guide and tried the examples, but I still don't know how to program the LEDs separately. The examples create a scrolling text, but how do I assign a specific color and an ON/OFF function to only one LED? I want to eventually create a drawing touch pad for which the display will be the NeoPixel Shield.
Franklin97355
Re: NeoPixel Shield examples
Post by Franklin97355 »
The commands to set pixel color are in the .h and .cpp files. You can look to see how they are used in the code. I pulled out a list of the functions here
Adafruit_NeoPixel::Adafruit_NeoPixel(uint16_t n, uint8_t p, uint8_t t) : numLEDs(n), numBytes(n * 3), pin(p), pixels(NULL)
Adafruit_NeoPixel::~Adafruit_NeoPixel()
void Adafruit_NeoPixel::begin(void)
void Adafruit_NeoPixel::show(void)
void Adafruit_NeoPixel::setPin(uint8_t p)
void Adafruit_NeoPixel::setPixelColor(uint16_t n, uint8_t r, uint8_t g, uint8_t b)
void Adafruit_NeoPixel::setPixelColor(uint16_t n, uint32_t c)
uint32_t Adafruit_NeoPixel::Color(uint8_t r, uint8_t g, uint8_t b)
uint32_t Adafruit_NeoPixel::getPixelColor(uint16_t n) const
uint8_t *Adafruit_NeoPixel::getPixels(void) const
uint16_t Adafruit_NeoPixel::numPixels(void) const
void Adafruit_NeoPixel::setBrightness(uint8_t b)
JesssB
Post by JesssB »
Nice, I'll look at it. But also, how do I set a pixel to light up? Like in the 16x32 matrix examples, using the RGB_matrix_Panel library, you have a matrix.setPixel(x, y, color) command. Anything like that for the NeoPixel shield?
Franklin97355
setPixelColor(uint16_t n, uint32_t c) and then show()
pburgess
Post by pburgess »
JesssB
Post by JesssB »
Again, thanks for the response, but at the risk of sounding very stupid, I am not sure I know what n and c stand for. I guess c stands for color. But then how do I define it from RGB values to one number? And what is n? Would that be the position? If so, how does it work? I have never programmed anything in bits and bytes like this.
JesssB
Post by JesssB »
Oh my god, after a week of trying to figure out how to work with the shield, and trying out every bit of very useful information you guys wrote here, I made it! Figured out how to define the position of each pixel, and used RGB values instead of uint32_t. I have never been that happy to see a single red LED turning on in my life! Haha!
