Trying to get "Music Maker" MP3 shield to play random MP3
Re: Trying to get "Music Maker" MP3 shield to play random MP
Glad to hear you have it working. Happy hacking! ;-)
- haybear
Hmmm, seems like the Music Maker Library needs a function similar to the that you can use with the Sparkfun MP3 Shield's "MP3player.playTrack(X);"
I just picked these shields up for a project and really like them, but was surprised I couldn't tell it to play a track by number... I guess the trade off is that you can call the tracks anything you like.
That's the beauty of Open Source.. you can tweak the library to do whatever you want.
That should be a fairly simple wrapper function.. take a number as a parameter, turn it into a complete filename, then pass that to .startPlaying() or .playFullFile().
- tertiumquid
Thanks for posting this, it was extremely helpful for my project (http://www.thingswemake.com/psl-modem/).
One note. Using a variant of your code, I wound up with a big memory leak. I resolved this by making a global variable, rather than instantiating it each time through the loop. Instead, I call each time through the loop to avoid the leak.
File path
path = SD.open("/");
- haybear
Thanks for pointing that out, Mike. I will try my hand at it. I am not the best coder, and depend on the hard work of others... a lot!
All that said, this code ended up helping me create a little random song playing MP3 player wrapped in an old Realist WeatheRadio, and for that I am very grateful.
Also, that Music Make board is AWESOME!!! The built in amp option is clutch and the price is great. Adafruit's got some real standout items. Keep it up! Please!!!
- ndnbolla
I am trying to implement random mp3 file playing into my code using the techniques discussed in this thread however it is unable to compile.
I end up with the error:
How were you guys able to compile, I tried using the exact same code but to no avail.
The following is my code:
Casptone_Program_Loop_Works.ino: In function 'char* selectRandomFileFrom(File, File)':
Casptone_Program_Loop_Works:513: error: [b]invalid conversion from 'const char*' to 'char*' [-fpermissive][/b]
#include <UTFT.h>
#include <UTouch.h>
#include <UTFT_Buttons.h>
#include <SPI.h>
#include <UTFT_SdRaw.h>
#include <SdFat.h>
#include <Adafruit_VS1053.h>
#include <DueFlashStorage.h>
// #include <SD.h>
UTFT display_LCD(EHOUSE70, 22, 23, 31, 33);
UTouch touch(25, 26, 27, 29, 30);
UTFT_Buttons button(&display_LCD, &touch);
UTFT_SdRaw sd_Files(&display_LCD);
#define BREAKOUT_RESET 9 // VS1053 reset pin (output)
#define BREAKOUT_CS 10 // VS1053 chip select pin (output)
#define BREAKOUT_DCS 8 // VS1053 Data/command select pin (output)
// #define CARDCS 4 // Card chip select pin
#define DREQ 3 // VS1053 Data request, ideally an Interrupt pin
#define mosipin 11
#define misopin 12
#define clkpin 13
DueFlashStorage dueFlashStorage; //Memory Storage
// SD chip select pin
const uint8_t chipSelect = 42;
//Push Button Setup
const int p_button = 2; // the number of the pushbutton pin
uint8_t debounceRead(int pin)
uint8_t pinState = digitalRead(pin);
uint32_t timeout = millis();
while (millis() < timeout+10)
if (digitalRead(pin) != pinState)
timeout = millis();
return pinState;
boolean pressed = HIGH;
boolean played = 0;
unsigned char count=0;
// file system
SdFat sd;
Adafruit_VS1053_FilePlayer musicPlayer =
Adafruit_VS1053_FilePlayer(mosipin, misopin, clkpin, BREAKOUT_RESET, BREAKOUT_CS, BREAKOUT_DCS, DREQ, chipSelect); // create breakout-example object!
extern unsigned short bw_logo[3100];
extern unsigned short uml_logo[7040];
extern uint8_t SmallFont[];
extern uint8_t BigFont[];
extern uint8_t SevenSegNumFont[];
extern uint8_t Dingbats1_XL[];
extern uint8_t arial_bold[];
int more_b, less_b, start_b, set_b, enter, pressed_button;
int buf[798];
int g, prev_g, f, prev_f = 0;
int x, y, w, l;
int X, Y;
uint8_t counter = 3;
void setup()
// Setup the LCD
display_LCD.InitLCD();
display_LCD.setFont(BigFont);
display_LCD.clrScr();
display_LCD.fillScr(255, 255, 255); //Fill screen with white color
// initialize the pushbutton pin as an input:
// pinMode(buttonPin, INPUT);
pinMode(p_button, INPUT_PULLUP);
digitalWrite(p_button, HIGH);
Serial.begin(9600);
while (!Serial) {
; // wait for serial port to connect. Needed for DUE & Leonardo only
counter = constrain(counter, 1, 10);
Serial.println(F("Initialising SD card..."));
bool mysd = 0;
// see if the card is present and can be initialized:
while (!mysd)
if (!sd.begin(chipSelect, SPI_FULL_SPEED)) {
Serial.println(F("Card failed, or not present"));
Serial.println(F("Retrying...."));
else
mysd = 1;
Serial.println(F("Card initialised."));
// initialise the music player
if (! musicPlayer.begin()) {
Serial.println(F("Couldn't find VS1053!"));
else
Serial.println(F("VS1053 found"));
// if (!sd.begin(CARDCS)) // initialize the SD card
// Serial.println(F("SD failed, or not present"));
// else
// Serial.println(F("SD OK"));
if (!musicPlayer.useInterrupt(VS1053_FILEPLAYER_PIN_INT)) { // DREQ int
Serial.println(F("DREQ Pin problem"));
// Set volume for left, right channels. lower numbers == louder volume!
musicPlayer.setVolume(30,30);
touch.InitTouch();
touch.setPrecision(PREC_EXTREME);
button.setTextFont(arial_bold);
button.setSymbolFont(Dingbats1_XL);
[b] uint32_t seed = 0; // Generate random seed start
for ( uint8_t i = 10 ; i ; i-- ) {
seed = ( seed << 5 ) + ( analogRead( 0 ) * 3 );
randomSeed( seed ); //set random seed[/b]
void loop()
button.deleteAllButtons();
// MainMenu();
MainProgram();
void MainMenu()
// Make a Main Menu Title Bar
display_buttons(0, 0, 799, 50, 20, 40, 140);
display_LCD.setBackColor(20, 40, 140);
display_LCD.setColor(255, 255, 255);
display_LCD.print("MAIN MENU", CENTER, 15);
//Display text asking how to continue
display_LCD.setFont(SmallFont);
display_LCD.setBackColor(255, 255, 255);
display_LCD.setColor(0, 0, 0);
display_LCD.print("How would you like to continue?", 100, 100);
start_b = button.addButton(150, 120, 500, 50, "Begin messaging");
set_b = button.addButton(150, 200, 500, 50, "Change settings");
button.setButtonColors(VGA_WHITE, VGA_GRAY, VGA_WHITE, VGA_RED, VGA_NAVY);
button.drawButtons();
//Display text telling battery percentage
display_LCD.print("Battery Remaining", CENTER, 380);
display_LCD.print("100%", CENTER, 420);
while(1)
if (touch.dataAvailable() == true)
pressed_button = button.checkButtons();
if (pressed_button == start_b)
MainProgram();
loop();
if (pressed_button == set_b)
SettingsPage();
void check(unsigned char num)
count = 0;
played = 0;
while(count<(counter*10)) //delay of 10 second with the checking of input
pressed = digitalRead(p_button);
delay(100);
if((pressed==LOW)&&(played==0)) //the button is pressed
switch(num)
case 1:
musicPlayer.playFullFile("talk.mp3");
break;
case 2:
musicPlayer.playFullFile("hungry.mp3");
break;
case 3:
musicPlayer.playFullFile("thirsty.mp3");
break;
case 4:
musicPlayer.playFullFile("bathroom.mp3");
break;
case 5:
musicPlayer.playFullFile("clean.mp3");
break;
case 6:
musicPlayer.playFullFile("sick.mp3");
break;
case 7:
musicPlayer.playFullFile("wheelc.mp3");
break;
case 8:
musicPlayer.stopPlaying();
break;
default:
break;
played = 1;
else if (touch.dataAvailable() == true)
SettingsPage();
count++;
pressed = HIGH;
void MainProgram()
display_LCD.clrScr(); // clear the screen
int mytime1 = millis();
int ret1 = sd_Files.load(0, 0, 800, 480, "talk.raw", 16);
Serial.println(millis() - mytime1);
Serial.println(ret1);
set_b = button.addButton(599, 0, 200, 50, "SETTINGS");
check(1);
// display_LCD.clrScr(); // clear the screen
// display_LCD.setColor(255, 255, 255);
// int mytime2 = millis();
// int ret2 = sd_Files.load(0, 0, 800, 480, "hungry.raw", 16);
// Serial.println(millis() - mytime2);
// Serial.println(ret2);
// check(2);
// int mytime3 = millis();
// int ret3 = sd_Files.load(0, 0, 800, 480, "thirsty.raw", 16);
// Serial.println(millis() - mytime3);
// Serial.println(ret3);
// check(3);
// int mytime4 = millis();
// int ret4 = sd_Files.load(0, 0, 800, 480, "bathroom.raw", 16);
// Serial.println(millis() - mytime4);
// Serial.println(ret4);
// check(4);
// int mytime5 = millis();
// int ret5 = sd_Files.load(0, 0, 800, 480, "clean.raw", 16);
// Serial.println(millis() - mytime5);
// Serial.println(ret5);
// check(5);
// int mytime6= millis();
// int ret6 = sd_Files.load(0, 0, 800, 480, "sick.raw", 16);
// Serial.println(millis() - mytime6);
// Serial.println(ret6);
// check(6);
// int mytime7 = millis();
// int ret7 = sd_Files.load(0, 0, 800, 480, "wheelc.raw", 16);
// Serial.println(millis() - mytime7);
// Serial.println(ret7);
// check(7);
//all 7 pictures are shown
//now show the picture for audio
int mytime8 = millis();
int ret8 = sd_Files.load(0, 0, 800, 480, "picmusic.raw", 16);
Serial.println(millis() - mytime8);
Serial.println(ret8);
[b]//////////////////////////////////////////////////////////////////////////////////////////////
count = 0;
played = 0;
while(count<counter*10) //delay of some selected time delay with the checking of input
pressed = debounceRead(p_button);
delay(100);
if (pressed == LOW) //the button is pressed
{ File path = sd.open("MUSIC/");
File results;
char* MP3 = selectRandomFileFrom( path, results );
delay(250); // Delay is necessary for good operation
if (! musicPlayer.startPlayingFile(MP3)) {
Serial.println("Could not open file track001.mp3");
while (1);
Serial.println(F("Started playing"));
while (musicPlayer.playingMusic) {
check(8);
// file is now playing in the 'background' so now's a good time
// to do something else like handling LEDs or buttons :)
// Serial.print(".");
// if (Serial.available()) {
// char c = Serial.read();
// // if we get an 's' on the serial console, stop!
// pressed = debounceRead(p_button);
// delay(100);
// if (c == 's') {
// if (pressed==LOW) {
// musicPlayer.stopPlaying();
// delay(1000);
// Serial.println("Done playing music");
count++;
[/b]
void SettingsPage()
// Make a Settings Title Bar
display_LCD.print("SETTINGS", CENTER, 15);
//Display text asking how long
display_LCD.print("How long would you like images to be displayed on screen for?", CENTER, 125);
//Create '+' Button
int w1 = 80;
button.setButtonColors(VGA_WHITE, VGA_GRAY, VGA_WHITE, VGA_RED, VGA_GREEN);
more_b = button.addButton(533, 150, w1, 48, "+"); //(X, Y, W, H, "")
button.drawButton(more_b);
//Create '-' Button
button.setButtonColors(VGA_WHITE, VGA_GRAY, VGA_WHITE, VGA_RED, VGA_RED);
less_b = button.addButton(267 - w1, 150, w1, 48, "-");
button.drawButton(less_b);
//Seconds Counter & Label
display_LCD.setFont(SevenSegNumFont);
display_LCD.printNumI(counter, CENTER, 150, 2, '0');
display_LCD.print("SECONDS", CENTER, 200);
//Main Menu Button
int w2 = 320;
enter = button.addButton(400 - w2 / 2, 320, w2, 48, "Return to Main Menu");
button.drawButton(enter);
//Display Bridgewell Logo
// display_LCD.drawBitmap(10, 429, 100, 31, bw_logo, 1);
//Display UML Logo
// display_LCD.drawBitmap(611, 390, 88, 80, uml_logo, 1);
while(1)
if (pressed_button==more_b)
counter = counter + 1;
if (pressed_button==less_b)
counter = counter - 1;
else if (pressed_button==enter)
// dueFlashStorage.write(1, counter);
MainMenu();
void display_buttons(int x, int y, int w, int l, int R, int G, int B)
display_LCD.setColor(R, G, B);
display_LCD.fillRect(x, y, w, l);
[b]// Function to select random mp3
char* selectRandomFileFrom( File dir, File result)
File entry;
int rcount = 0;
dir.rewindDirectory();
while ( entry = dir.openNextFile() )
if ( random( rcount ) == 0 )
result = entry;
entry.close();
rcount++;
return result.name(); // returns the randomly selected file name
}[/b]
- michaelw3
In case it is helpful to other people searching for a solution for playing random files off this board, I've taken the code that was reported to work (without adding the memory leak fix) and cut out all of the stuff that has to do with the servos. So this is just the code to randomly play the files off the card.
adapted from https://forums.adafruit.com/viewtopic.php?f=31&t=60742
// include SPI, MP3 and SD libraries
#include <SPI.h>
#include <SD.h>
// These are the pins used for the music maker shield
#define SHIELD_RESET -1 // VS1053 reset pin (unused!)
#define SHIELD_CS 7 // VS1053 chip select pin (output)
#define SHIELD_DCS 6 // VS1053 Data/command select pin (output)
// These are common pins between breakout and shield
// DREQ should be an Int pin, see http://arduino.cc/en/Reference/attachInterrupt
// create shield-exmaple object!
Adafruit_VS1053_FilePlayer(SHIELD_RESET, SHIELD_CS, SHIELD_DCS, DREQ, CARDCS);
//Pin Definitions //The 74HC595 uses a serial communication link which has three pins
int data = 2;
int clock = 5;
int latch = 8;
//Used for single LED manipulation
int ledState = 0;
const int ON = HIGH;
const int OFF = LOW;
Serial.begin(9600);
uint32_t seed = 0; // Generate random see start
Serial.println("Adafruit VS1053 Library Test");
Serial.print("RandomSeed value = ");
Serial.println(seed);
if (! musicPlayer.begin()) { // initialise the music player
Serial.println(F("Couldn't find VS1053, do you have the right pins defined?"));
while (1);
if (!SD.begin(CARDCS)) {
while (1); // don't do anything more
Serial.println("SD OK!");
// list files
printDirectory(SD.open("/"), 0);
musicPlayer.setVolume(20, 20);
if (! musicPlayer.useInterrupt(VS1053_FILEPLAYER_PIN_INT))
Serial.println(F("DREQ pin is not an interrupt pin"));
// put your main code here, to run repeatedly:
File path = SD.open("/");
File results;
delay(1000);
// Start playing a file, then we can do stuff while waiting for it to finish
Serial.println("Could not open file: ");
Serial.println(MP3);
Serial.print(F("Now playing "));
//Serial.print(".");
Serial.print("Done playing: ");
Serial.println();
/// File listing helper
void printDirectory(File dir, int numTabs) {
while (true) {
File entry = dir.openNextFile();
if (! entry) {
// no more files
//Serial.println("**nomorefiles**");
break;
for (uint8_t i = 0; i < numTabs; i++) {
Serial.print('\t');
Serial.print(entry.name());
if (entry.isDirectory()) {
Serial.println("/");
printDirectory(entry, numTabs + 1);
} else {
// files have sizes, directories do not
Serial.print("\t\t");
Serial.println(entry.size(), DEC);
entry.close();
char* selectRandomFileFrom( File dir, File result ) {
File entry;
int count = 0;
while ( entry = dir.openNextFile() ) {
if ( random( count ) == 0 ) {
result = entry;
entry.close();
count++;
- Marby
Awesome! Even years later!
I'm so happy that you put the complete working code in this threat; I think its really important & helpful to do so!
- jim_lee
@adafruit_support_mikeadafruit_support_mike wrote:The routine that reads your text file reads one byte at a time. You're getting a 308 because there are 307 bytes in the file.
To read the file into an array you'd need to scan the bytes as you read them and decide where each filename begins. That's possible, but there's an easier way to select a random file.
Start by putting all the files you want in your option pool into a single directory, then use this routine to select one at random:
The Arduino's random() function returns an integer between zero and the limit you provide as a parameter. The chance of getting a zero is 1/N where N is the limit.Code: Select all
void playRandomFileIn( File dir ) { File entry, result; int count = 1; dir.rewindDirectory(); while ( entry = dir.openNextFile() ) { if ( random( count ) == 0 ) { if ( result ) { result.close(); } result = entry; } else { entry.close(); } count++; } // play result }
When N=1, the result is guaranteed to be zero, so the first file in the directory will always be selected. There's a 50% chance of the result being zero when N=2, so if there are only two files in the directory there's a 50-50 chance that either one will be selected. As the count increases, each new item has a 1/N chance of replacing the previous selection, so each item gets an equal chance of being the one that finally makes it to the end.
It's a nice routine to have in the bag of tricks because you don't have to know how many items are in the set before you start choosing them.
That's a really neat trick! Never in 1,000 years would I have come up with something like that! I was thinking I wanted to do a random play file thing. I was going to count everything, pick a number, rewind, look for it..
-jim lee
I picked that up years ago, either in an algorithms class or from a collection of coding tricks.
The secret to being a good programmer is to steal from the best. ;-)
- Marby
Sadly there is still a memory leak? Because after 3 plays it can't read anything from the SD card anymore. (I've only added the neopixel library )
There does seem to be a point in the code where something like this happens:
Now playing SOUND42.MP3
Done playing: SOUND42.MP3
Now playing
Done playing:
Now playing
Done playing:
It tries to open a blank, can't find it, and crashes.
With 90 neopixel it happens after 3 playbacks, with 150 it even can't get so far, the serial output stops at 'SD OK!
'. Without it seems to work fine (for x instances ?).
Now playing
Done playing:
Now playing
Done playing:
#include <SPI.h>
#include <SD.h>
Adafruit_VS1053_FilePlayer musicPlayer = Adafruit_VS1053_FilePlayer(SHIELD_RESET, SHIELD_CS, SHIELD_DCS, DREQ, CARDCS);
const int buttonPin = 5; // the number of the pushbutton pin
int buttonState = 0; // variable for reading the pushbutton status
#define PIN 2
#define NUMPIXELS 250
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
int val = 0;
Serial.begin(9600);
while (1);
// list files
///////////////////////// button
delay(1000);
/////////// ws2812b
strip.begin(); // This initializes the NeoPixel library.
colorWipe(strip.Color(0, 100, 0), 0);
delay(100);
colorWipe(strip.Color(0, 0, 0), 0);
strip.setBrightness(200);
delay(100);
buttonState = digitalRead(buttonPin);
if (buttonState == LOW) {
Serial.println("Button Pressed");
File results;
Serial.print("Light = ");
Serial.println(val);
// file is now playing in the 'background' so now's a good time to do something else like handling LEDs or buttons :)
switch (val) {
case 0:
theaterChase(strip.Color(127, 127, 127), 20);
break;
case 1:
theaterChase(strip.Color(250, 255, 0), 20);
break;
case 2:
theaterChase(strip.Color(255, 0, 255), 20);
break;
case 3:
colorWipe(strip.Color(255, 0, 0), 3);
delay(100);
colorWipe(strip.Color(0, 0, 255), 3);
delay(100);
break;
case 4:
colorWipe(strip.Color(0, 255, 0), 3);
delay(100);
colorWipe(strip.Color(255, 0, 255), 3);
delay(100);
break;
case 5:
delay(100);
colorWipe(strip.Color(255, 255, 0), 3);
delay(100);
break;
Serial.println();
val = random(6);
while (true) {
if (! entry) {
// no more files
break;
Serial.print('\t');
} else {
entry.close();
File entry;
int count = 0;
result = entry;
entry.close();
count++;
void colorWipe(uint32_t c, uint8_t wait) {
for (uint16_t i = 0; i < strip.numPixels(); i++) {
strip.setPixelColor(i, c);
strip.show();
delay(wait);
void theaterChase(uint32_t c, uint8_t wait) {
for (int j = 0; j < 6; j++) { //do 10 cycles of chasing
for (int q = 0; q < 3; q++) {
for (int i = 0; i < strip.numPixels(); i = i + 3) {
strip.setPixelColor(i + q, c); //turn every third pixel on
strip.show();
delay(wait);
strip.setPixelColor(i + q, 0); //turn every third pixel off
strip.show();
- jim_lee
You never close this file.
Or this file.
Actually printDirectory(SD.open("/"), 0); Is a real bad idea. You create something in a call but who is responsible to free it? If it were created -before- the call you could close it after. But better would be just to pass in "/" and have it created and closed inside the function.
-jim lee
Or this file.
-jim lee
- Marby
Hi! Thanks for your reply!
Could you give me the example how I can do that?
- jim_lee
// The original function. + a file name string.
void chooseRandomFile( File dir , char* outFileName) {
File entry, result;
int count = 1;
if ( result ) { // This bit was forgotten. We put it back.
result.close();
result = entry;
} else {
entry.close();
count++;
strcpy(outFileName,result.name()); // Copy the resulting file name out.
result.close(); // Close result.
char MP3[15]; // Allocate some room.
File dir = SD.open("/"); // Your standard root directory.
chooseRandomFile(dir,MP3);
dir.close(); // Clean up our stuff.
// Go play the file.
-jim lee
- mikememmi
https://www.youtube.com/watch?v=Y-Mp6BJoY_k
hi guys, i found lots of great info in this thread for a project i am just starting. support here is excellent. in any case, there is a solution to the "playing in same order every time" issue in this video. by coincidence i just found this today. my app will use lots of random numbers. i will be building midi files with rando notes.
randomSeed(##)
thanks
randomSeed(##)
thanks
