music maker shield
ahmedablak
music maker shield
Post by ahmedablak »
hi, i have recently bought the adafruit music maker shield w/3W Stereo Amp. i have two speaker of rating 4ohm-3w. the tutorial points out that i might need to power the Arduino from DC power jack instead of USB since USB can only provide 5W (5V @ 1A) max and two 3W speakers = 6W. is DC power jack really needed if i'm using 3w speakers? or its just a suggestion to increase the loudness?
P.S. will i end up damaging my shield if both speakers are connected using USB
https://learn.adafruit.com/adafruit-mus ... er/pinouts
Franklin97355
Re: music maker shield
Post by Franklin97355 »
You should be OK. The power will just be less and as you say lower in volume.
