Cloud Thermometer help
- superman136
Hello everyone, I am working on the same project Cloud Thermometer. I followed exactly the tutorial,... and checked again and again all the configuration needed on the arduino sketch. But when I am trying to open Serial Monitor. It only shows Running... Then it hang like that forever. I don't know what happens with that. I checked all the steps, I didn't miss anything.
- Franklin97355
Re: Cloud Thermometer help
Could you post clear pictures of both sides of your board showing any soldering you have done and the connections to it?
- superman136
I am using Wifi Shield, therefore there is no extra connection for wifi shield. I stacked a protoshield board on top. I've just simply used the code, didn't change any pin configuration. Also I tested with buildTest, WebClient,... everything works fine.
- FullSizeRender.jpg (1020.46 KiB) Viewed 833 times
- Franklin97355
did you solder the pins on the shield?I am using Wifi Shield
- superman136
Yes, i did. Do you think i may damage my shield already? But i followed all others tutorial with CC3000, it works fine. Like wifi controlling relay, read temperature and humidity to webserver, everything works correctly. But I havent done anything with internet controlling. Do you think so? How can i check to make sure before i go ahead and buy a new one?
- superman136
I followed exactly the tutorial for overview of CC3000 with all the tests. I solderred the headers coming with the shield to the shield.
- adafruit_support_rick
If buildtest, WebClient, and the other example sketches work, then there's nothing wrong with your CC3000.
If the CloudThermometer sketch gets to 'Running...", that also means that your CC3000 is OK. I'm not sure what your problem could be. I'll contact the tutorial author.
- superman136
Thanks a lot. Hope hearing from youguys soon.
- tdicola
Do you mind sharing the full code for the sketch you're running? You can blank out the AWS access keys and SSID details--I just want to check what the other configuration is set to for the sketch. By default it should grab a reading every minute, but lets check if the configuration is different and it might not be grabbing any measurements.
Also to get a little more debug info, change the loop function to look like this so it prints out the temperature when it takes a reading:
Run the sketch and after a minute we should hopefully see at least the "Temp: <temperature>" output to the serial console. This can help tell us if there's a problem reading the data from the thermistor or if we can't write to AWS for some reason.
void loop(void) {
// Update the current time.
// Note: If the sketch will run for more than ~24 hours, you probably want to query the time
// server again to keep the current time from getting too skewed.
unsigned long currentTime = lastPolledTime + (millis() - sketchTime) / 1000;
if ((currentTime - lastReading) >= (READING_DELAY_MINS*60)) {
lastReading = currentTime;
// Get a temp reading
float currentTemp = readTemp();
Serial.print("Temp: "); Serial.println(currentTemp);
// Write the result to the database.
dynamoDBWrite(TABLE_NAME, ID_VALUE, currentTime, currentTemp);
- superman136
This is the arduino sketch, I used to test. For the library sha256.h, I used the file coming with the zip file of package for this tutorial.
Cloud Data-Logging Thermometer
Log a thermomistor value to an Amazon DynamoDB table every minute.
Copyright 2013 Tony DiCola ([email protected]).
Released under an MIT license:
http://opensource.org/licenses/MIT
Dependencies:
- Adafruit CC3000 Library
https://github.com/adafruit/Adafruit_CC3000_Library
- RTClib Library
https://github.com/adafruit/RTClib
Parts of this code were adapted from Adafruit CC3000 library example
code which has the following license:
Designed specifically to work with the Adafruit WiFi products:
----> https://www.adafruit.com/products/1469
products from Adafruit!
Written by Limor Fried & Kevin Townsend for Adafruit Industries.
BSD license, all text above must be included in any redistribution
SHA256 hash and signing code adapted from Peter Knight's library
available at https://github.com/Cathedrow/BANNED
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#include <SPI.h>
#include <Wire.h>
#include <RTClib.h>
#include "sha256.h"
// CC3000 configuration
#define ADAFRUIT_CC3000_IRQ 3 // MUST be an interrupt pin!
#define ADAFRUIT_CC3000_VBAT 5 // VBAT and CS can be any two pins
#define ADAFRUIT_CC3000_CS 10
// Use hardware SPI for the remaining pins
// On an UNO, SCK = 13, MISO = 12, and MOSI = 11
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS,
ADAFRUIT_CC3000_IRQ,
ADAFRUIT_CC3000_VBAT,
SPI_CLOCK_DIV2);
// Wireless network configuration
#define WLAN_SSID "Solar" // cannot be longer than 32 characters!
#define WLAN_PASS "ample3A7V"
#define WLAN_SECURITY WLAN_SEC_WPA2 // Security can be WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
// Thermistor configuration
#define THERMISTOR_PIN 0 // Analog pin to read thermistor values.
#define SERIES_RESISTOR 10000 // Resistor value (in Ohms) in series with the thermistor.
#define ADC_SAMPLES 5 // Number of ADC samples to average for a reading.
// Change the thermistor coefficient values below to match what you measured
// after running through the calibration sketch.
#define A_COEFFICIENT 0.001050874114
#define B_COEFFICIENT 0.000180189037
#define C_COEFFICIENT 0.000000277196
// DynamoDB table configuration
#define TABLE_NAME "Temperatures" // The name of the table to write results.
#define ID_VALUE "Test ID Value" // The value for the ID/primary key of the table. Change this to a
// different value each time you start a new measurement.
// Amazon AWS configuration
#define AWS_ACCESS_KEY "*********" // Put your AWS access key here.
// Don't put the read-only user credentials here, instead use your AWS account credentials
// or the credentials of an account with write access to your DynamoDB table here.
#define AWS_SECRET_ACCESS_KEY "*************" // Put your AWS secret access key here.
#define AWS_REGION "us-west-2" // The region where your dynamo DB table lives.
// Copy the _exact_ region value from this table: http://docs.aws.amazon.com/general/latest/gr/rande.html#ddb_region
#define AWS_HOST "dynamodb.us-west-2.amazonaws.com" // The endpoint host for where your dynamo DB table lives.
// Copy the _exact_ endpoint host from this table: http://docs.aws.amazon.com/general/latest/gr/rande.html#ddb_region
// Other sketch configuration
#define READING_DELAY_MINS 1 // Number of minutes to wait between readings.
#define TIMEOUT_MS 15000 // How long to wait (in milliseconds) for a server connection to respond (for both AWS and NTP calls).
// Don't modify the below constants unless you want to play with calling other DynamoDB APIs
#define AWS_TARGET "DynamoDB_20120810.PutItem"
#define AWS_SERVICE "dynamodb"
#define AWS_SIG_START "AWS4" AWS_SECRET_ACCESS_KEY
#define SHA256_HASH_LENGTH 32
// State used to keep track of the current time and time since last temp reading.
unsigned long lastPolledTime = 0; // Last value retrieved from time server
unsigned long sketchTime = 0; // CPU milliseconds since last server query
unsigned long lastReading = 0; // Time of last temperature reading.
void setup(void) {
Serial.begin(115200);
// Initialize and connect to the wireless network
// This code is adapted from CC3000 example code.
if (!cc3000.begin()) {
Serial.println(F("Unable to initialise the CC3000!"));
while(1);
if (!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) {
Serial.println(F("Failed to connect to AP!"));
while(1);
// Wait for DHCP to complete
while (!cc3000.checkDHCP()) {
delay(100);
// Get an initial time value by querying an NTP server.
unsigned long t = getTime();
while (t == 0) {
// Failed to get time, try again in a minute.
delay(60*1000);
t = getTime();
lastPolledTime = t;
sketchTime = millis();
Serial.println(F("Running..."));
void loop(void) {
// Take a reading of the thermistor and return the current temp in kelvin.
float readTemp() {
float R = 0;
for (int i = 0; i < ADC_SAMPLES; ++i) {
R += analogRead(THERMISTOR_PIN);
R /= (float)ADC_SAMPLES;
R = (1023 / R) - 1;
R = SERIES_RESISTOR / R;
return 1/(A_COEFFICIENT + B_COEFFICIENT*log(R) + C_COEFFICIENT*pow(log(R), 3));
// Write a temperature reading to the DynamoDB table.
void dynamoDBWrite(char* table, char* id, unsigned long currentTime, float currentTemp) {
// Generate time and date strings
DateTime dt(currentTime);
// Set dateTime to the ISO8601 simple date format string.
char dateTime[17];
memset(dateTime, 0, 17);
dateTime8601(dt.year(), dt.month(), dt.day(), dt.hour(), dt.minute(), dt.second(), dateTime);
// Set date to just the year month and day of the ISO8601 simple date string.
char date[9];
memset(date, 0, 9);
memcpy(date, dateTime, 8);
// Set currentTimeStr to the string value of the current unix time (seconds since epoch).
char currentTimeStr[8*sizeof(unsigned long)+1];
memset(currentTimeStr, 0, 8*sizeof(unsigned long)+1);
ultoa(currentTime, currentTimeStr, 10);
// Generate string for the temperature reading.
char temp[8*sizeof(unsigned long)+5];
memset(temp, 0, 8*sizeof(unsigned long)+5);
// Convert to fixed point string. Using a proper float to string function
// like dtostrf takes too much program memory (~1.5kb) to use in this sketch.
ultoa((unsigned long)currentTemp, temp, 10);
int n = strlen(temp);
temp[n] = '.';
temp[n+1] = '0' + ((unsigned long)(currentTemp*10)) % 10;
temp[n+2] = '0' + ((unsigned long)(currentTemp*100)) % 10;
temp[n+3] = '0' + ((unsigned long)(currentTemp*1000)) % 10;
// Generate string with payload length for use in the signing and request sending.
char payloadlen[8*sizeof(unsigned long)+1];
memset(payloadlen, 0, 8*sizeof(unsigned long)+1);
ultoa(71+strlen(table)+strlen(id)+strlen(currentTimeStr)+strlen(temp), payloadlen, 10);
// Generate the signature for the request.
// For details on the AWS signature process, see:
// http://docs.aws.amazon.com/general/latest/gr/signature-version-4.html
// First, generate signing key to use in later signature generation.
// Note: This could be optimized to generate just once per day (when the date value changes),
// but since calls are only made every few minutes it's simpler to regenerate each time.
char signingkey[SHA256_HASH_LENGTH];
Sha256.initHmac((uint8_t*)AWS_SIG_START, strlen(AWS_SIG_START));
Sha256.print(date);
memcpy(signingkey, Sha256.resultHmac(), SHA256_HASH_LENGTH);
Sha256.initHmac((uint8_t*)signingkey, SHA256_HASH_LENGTH);
Sha256.print(AWS_REGION);
Sha256.print(AWS_SERVICE);
Sha256.print(F("aws4_request"));
// Second, generate hash of the payload data.
Sha256.init();
Sha256.print(F("{\"TableName\":\""));
Sha256.print(table);
Sha256.print(F("\",\"Item\":{\"Id\":{\"S\":\""));
Sha256.print(id);
Sha256.print(F("\"},\"Date\":{\"N\":\""));
Sha256.print(currentTimeStr);
Sha256.print(F("\"},\"Temp\":{\"N\":\""));
Sha256.print(temp);
Sha256.print(F("\"}}}"));
char payloadhash[2*SHA256_HASH_LENGTH+1];
memset(payloadhash, 0, 2*SHA256_HASH_LENGTH+1);
hexString(Sha256.result(), SHA256_HASH_LENGTH, payloadhash);
// Third, generate hash of the canonical request.
Sha256.init();
Sha256.print(F("POST\n/\n\ncontent-length:"));
Sha256.print(payloadlen);
Sha256.print(F("\ncontent-type:application/x-amz-json-1.0\nhost:"));
Sha256.print(AWS_HOST);
Sha256.print(F(";\nx-amz-date:"));
Sha256.print(dateTime);
Sha256.print(F("\nx-amz-target:"));
Sha256.print(AWS_TARGET);
Sha256.print(F("\n\ncontent-length;content-type;host;x-amz-date;x-amz-target\n"));
Sha256.print(payloadhash);
char canonicalhash[2*SHA256_HASH_LENGTH+1];
memset(canonicalhash, 0, 2*SHA256_HASH_LENGTH+1);
hexString(Sha256.result(), SHA256_HASH_LENGTH, canonicalhash);
// Finally, generate request signature from the string to sign and signing key.
Sha256.print(F("AWS4-HMAC-SHA256\n"));
Sha256.print(F("\n"));
Sha256.print(date);
Sha256.print(F("/"));
Sha256.print(F("/aws4_request\n"));
Sha256.print(canonicalhash);
char signature[2*SHA256_HASH_LENGTH+1];
memset(signature, 0, 2*SHA256_HASH_LENGTH+1);
hexString(Sha256.resultHmac(), SHA256_HASH_LENGTH, signature);
// Make request to DynamoDB API.
uint32_t ip = 0;
while (ip == 0) {
if (!cc3000.getHostByName(AWS_HOST, &ip)) {
Serial.println(F("Couldn't resolve!"));
delay(500);
Adafruit_CC3000_Client www = cc3000.connectTCP(ip, 80);
if (www.connected()) {
www.fastrprint(F("POST / HTTP/1.1\r\nhost: "));
www.fastrprint(AWS_HOST);
www.fastrprint(F(";\r\nx-amz-date: "));
www.fastrprint(dateTime);
www.fastrprint(F("\r\nAuthorization: AWS4-HMAC-SHA256 Credential="));
www.fastrprint(AWS_ACCESS_KEY);
www.fastrprint(F("/"));
www.fastrprint(date);
www.fastrprint(AWS_REGION);
www.fastrprint(AWS_SERVICE);
www.fastrprint(F("/aws4_request, SignedHeaders=content-length;content-type;host;x-amz-date;x-amz-target, Signature="));
www.fastrprint(signature);
www.fastrprint(F("\r\ncontent-type: application/x-amz-json-1.0\r\ncontent-length: "));
www.fastrprint(payloadlen);
www.fastrprint(F("\r\nx-amz-target: "));
www.fastrprint(AWS_TARGET);
www.fastrprint(F("\r\n\r\n{\"TableName\":\""));
www.fastrprint(table);
www.fastrprint(F("\",\"Item\":{\"Id\":{\"S\":\""));
www.fastrprint(id);
www.fastrprint(F("\"},\"Date\":{\"N\":\""));
www.fastrprint(currentTimeStr);
www.fastrprint(F("\"},\"Temp\":{\"N\":\""));
www.fastrprint(temp);
www.fastrprint(F("\"}}}"));
else {
Serial.println(F("Connection failed"));
www.close();
return;
// Read data until either the connection is closed, or the idle timeout is reached.
Serial.println(F("AWS response:"));
unsigned long lastRead = millis();
while (www.connected() && (millis() - lastRead < TIMEOUT_MS)) {
while (www.available()) {
char c = www.read();
Serial.print(c);
www.close();
// Convert an array of bytes into a lower case hex string.
// Buffer MUST be two times the length of the input bytes array!
void hexString(uint8_t* bytes, size_t len, char* buffer) {
for (int i = 0; i < len; ++i) {
btoa2Padded(bytes[i], &buffer[i*2], 16);
// Fill a 16 character buffer with the date in ISO8601 simple format, like '20130101T010101Z'.
// Buffer MUST be at least 16 characters long!
void dateTime8601(int year, byte month, byte day, byte hour, byte minute, byte seconds, char* buffer) {
ultoa(year, buffer, 10);
btoa2Padded(month, buffer+4, 10);
btoa2Padded(day, buffer+6, 10);
buffer[8] = 'T';
btoa2Padded(hour, buffer+9, 10);
btoa2Padded(minute, buffer+11, 10);
btoa2Padded(seconds, buffer+13, 10);
buffer[15] = 'Z';
// Print a value from 0-99 to a 2 character 0 padded character buffer.
// Buffer MUST be at least 2 characters long!
void btoa2Padded(uint8_t value, char* buffer, int base) {
if (value < base) {
*buffer = '0';
ultoa(value, buffer+1, base);
else {
ultoa(value, buffer, base);
// getTime function adapted from CC3000 ntpTest sketch.
// Minimalist time server query; adapted from Adafruit Gutenbird sketch,
// which in turn has roots in Arduino UdpNTPClient tutorial.
unsigned long getTime(void) {
Adafruit_CC3000_Client client;
uint8_t buf[48];
unsigned long ip, startTime, t = 0L;
// Hostname to IP lookup; use NTP pool (rotates through servers)
if(cc3000.getHostByName("pool.ntp.org", &ip)) {
static const char PROGMEM
timeReqA[] = { 227, 0, 6, 236 },
timeReqB[] = { 49, 78, 49, 52 };
startTime = millis();
do {
client = cc3000.connectUDP(ip, 123);
} while((!client.connected()) &&
((millis() - startTime) < TIMEOUT_MS));
if(client.connected()) {
// Assemble and issue request packet
memset(buf, 0, sizeof(buf));
memcpy_P( buf , timeReqA, sizeof(timeReqA));
memcpy_P(&buf[12], timeReqB, sizeof(timeReqB));
client.write(buf, sizeof(buf));
while((!client.available()) &&
if(client.available()) {
client.read(buf, sizeof(buf));
t = (((unsigned long)buf[40] << 24) |
((unsigned long)buf[41] << 16) |
((unsigned long)buf[42] << 8) |
(unsigned long)buf[43]) - 2208988800UL;
client.close();
return t;
- superman136
Running...
Temp: 29.21
The Serial Monitor gives me this, after I replaced the code in void loop(). So it must be sth wrong with AWS (or the Sha library).
Temp: 29.21
- tdicola
Thanks for checking, that's good to see at least the temperature read is working. I have a feeling there's some kind of permission or connection issue talking to Amazon's service. Try changing the dynamoDBWrite function to use the following code (I inserted a few print statements to help check how far it's getting into the function):
Give that a shot and lets see how much serial output you get. My suspicion is you might be getting stuck in the loop to try to resolve the IP address of the dynamo DB server, perhaps because of a DNS or other issue.
Serial.print("Preparing to write to table "); Serial.println(table);
char dateTime[17];
char date[9];
memset(date, 0, 9);
temp[n] = '.';
Sha256.print(date);
Sha256.init();
Sha256.print(id);
Sha256.print(temp);
Sha256.init();
Sha256.print(date);
Serial.println("Generated hash! Resolving IP address...");
uint32_t ip = 0;
while (ip == 0) {
delay(500);
Serial.println("Found DynamoDB IP address! Connecting...");
www.fastrprint(id);
else {
www.close();
return;
Serial.print(c);
www.close();
- superman136
Literally when I replaced exactly the dynamodb function into my sketch. The serial monitor gave nothing. I am really confused. Therefore I tried to put back the original code. It gives me the same output like the previous post.
Then I examined your dynamodb function again by continuously added 3 serial.print command lines. I take turn add them 1 by 1, and let see what happens.
If I only added the first "Serial.print("Preparing to write to table "); Serial.println(table);" exactly right at the position located in your debug code.
The Serial output spitted out millions of weird symbols, and lines, continuously running, almost freeze my desktop. I can recognize just a few letter among those outputs like "Temp....", "runn..."
If I added one more "Serial.println("Generated hash! Resolving IP address...");" exactly right at the position located in your debug code.
The Serial output displayed the same like above.
If I continued to add the 3rd "Serial.println("Found DynamoDB IP address! Connecting...");" exactly right at the position located in your debug code.
The Serial output displayed nothing.
I dont understand what's going on.
- tdicola
That's odd, it almost sounds like the Arduino is running out of memory and behaving erratically. One thing I wanted to check, what version of the Arduino IDE are you using ? Is it a beta version 1.5.7/1.5.8 or normal version 1.0.5 or 1.0.6?
- superman136
its 1.0.5-r2 Arduino IDE
