Adafruit Bluetooth LE and SPI sharing
j4zzcat
Post by j4zzcat »
Hi All,
I'm designing a solution that needs to store data that comes over BLE on a flash chip.
I'm thinking of using the Adafruit BLE and the W25Q80BV (flash chip).
These two products provide a SPI interface, and I'm thinking of doing something like this -- is it enough?
while there's data to read from the BLE {
  read a chunk of data into a buffer
  set the chip select pin of the BLE to HIGH
  set the chip select pin of the W25Q80BV to LOW
  write the data to the W25Q80BV
  set the chip select pin of the W25Q80BV to HIGH
  set the chip select pin of the BLE to LOW
Thanks.
adafruit_support_rick
Re: Adafruit Bluetooth LE and SPI sharing
There's a problem. The BLE library is interrupt-driven, and it does SPI operations at interrupt level. That means it doesn't play well with other SPI devices, which may be in the middle of a SPI operation when a BLE interrupt occurs.
If you want to do this, you'll need to establish two different SPI buses. The BLE is hardcoded to use hardware SPI, so you would have to do software SPI on a different set of pins for your flash chip.
paulstoffregen
Post by paulstoffregen »
I am working on this problem. If anyone is still watching this thread, here's the latest attempt to use SPI transactions to make this library play nicely with SPI-based libs. This is a work-in-progress, and I could really use your feedback if you're willing to help test it.
https://github.com/PaulStoffregen/Adafruit_nRF8001
This requires SPI transactions. To try this code, you need either Arduino 1.5.8 or Arduino 1.0.6 with Teensyduino 1.20.
If you try this with a nRF8001 and SD card or other SPI device, please let me know if it works for you?
