Powering Motor Shield v2 + Arduino Uno
- designCPU
At the moment, I'm powering 3 motor shields (each running four 12V/140mA computer fans -> 20.16W max) from a 12V/2A DC power adapter. The fans would rarely run all at once. The shields are stacked on top of an Arduino that's powered by its own separate 5V/1A DC power adapter. Everything runs fine. But I'd really, really like to eliminate having two power adapters. According to the Motor Shield manual, it's at least possible to run the whole system from the 12V/2A DC power adapter. But is this advisable, from a heat standpoint? (The Arduino and shields will be inside watertight plastic box) I'm considering using the Mini DC/DC Step-Down (Buck) Converter - 5V @ 1A output [https://www.adafruit.com/products/1065] along with the 12V/2A DC power adapter, to direct 12V to the fans and 5V to the Arduino. Is this an option, or are there other, easier/better options?
- Franklin97355
Re: Powering Motor Shield v2 + Arduino Uno
The Arduino can take the 12v as input power and as long as you are not using it's regulator to power the fans it should work OK.
- designCPU
Aright, I'll give it a try. Thanks!
- designCPU
Oh, one other question: If I'm supplying 12V to the Arduino, do each of the stacked v2 Motor Shields need the jumper in place to receive that sweet delicious power?
Yes, they do.
