From the learning page: https://learn.adafruit.com/adafruit-pn5 ... eld-wiring
I2C only uses two pins (Analog 4 and 5 which are fixed in hardware and cannot be changed) to communicate and one pin as an 'interrupt' pin (Digital 2 - can be changed however). […] The Interrupt pin is handy because instead of constantly asking the NFC shield "is there a card in view yet? what about now?" constantly, the chip will alert us when a NFC target comes into the antenna range.
Please give me an example on how to use the interrupt, if it is really possible.
NFC Shield with Interrupt
- Franklin97355
Re: NFC Shield with Interrupt
The readMifare.pde file in the examples uses it.
- kariy
I came to these forums looking for examples on how to use the interrupt on your NFC shield and found this thread...
Thank you!
I looked at that file, I don't see any use of interrupts. Can you point me to a specific line in the example you mentioned?The readMifare.pde file in the examples uses it.
Thank you!
- adafruit_support_rick
The library polls the IRQ line. It does not actually use interrupts.
- kariy
Right, thank you. Can you give me an example of how to use an interrupt with the shield?
Why do you want an interrupt? What are you going to do with it?
- kariy
Well I want to be able to handle button presses, so what I wanted to do was each time a button is pressed I could somehow interrupt the busy waiting of the passiveRead method.
It's easier to just eliminate the timeout on readPassiveTargetID. See this thread:
viewtopic.php?f=31&t=59393&p=300270&hil ... ID#p300270
