Adafruit SD Data Logging shield for Arduino
ServiceXp
Post by ServiceXp »
I purchased 2 of these shields, and they look good, well thought out design.
I having 2 problems:
1) The documented sketch fails to open the created .csv file. It creates the file, but it looks like it can't open it. If I change the file type to .txt everything works fine, and I no longer get the "couldn't create file" error.
2) When the file is created, it's created / modification date is set to something like 01-01-2010. How do I get the modify date set?
This version does not work:
 // create a new file
char filename[] = "LOGGER00.CSV";
for (uint8_t i = 0; i < 100; i++) {
filename[6] = i/10 + '0';
filename[7] = i%10 + '0';
if (! SD.exists(filename)) {
// only open a new file if it doesn't exist
logfile = SD.open(filename, FILE_WRITE);
break; // leave the loop!
if (! logfile) {
error("couldnt create file");
This version works perfectly:
char filename[] = "LOGGER00.TXT";
if (! logfile) {
adafruit_support_rick
Re: Adafruit SD Data Logging shield for Arduino
Post by adafruit_support_rick »
Easy answer first: The library does not support time stamping files. You can't get the creation/modification date set.
Hard answer: I have no explanation. The library doesn't know anything about particular extensions. .CSV should work just as well as .TXT.
ServiceXp
Post by ServiceXp »
adafruit_support_rick wrote:Easy answer first: The library does not support time stamping files. You can't get the creation/modification date set.
I know it's very strange. It simply will not work with the CSV ext. Any other good/easy spreadsheet ext's I can try?
There's something else going on. I just ran the GPS logger sketch with a CSV extension and it worked fine.
Can you post your entire sketch?
Franklin97355
Post by Franklin97355 »
Check this out for info on time stamping.
ServiceXp
Post by ServiceXp »
adafruit_support_rick wrote:There's something else going on. I just ran the GPS logger sketch with a CSV extension and it worked fine.
Sorry for the delay... You were right, while testing I also ran into the same problem with the .txt ext. I started breaking down my sketch and decided to change the setup order of a few functions and I discovered that if I initialize my DHT sensors before initializing the SD Card I would run into this problem.
Very strange.
ServiceXp
Post by ServiceXp »
franklin97355 wrote:Check this out for info on time stamping.
I don't understand? I didn't see anything referencing the file date created and modified stamps in that information???
Glad to hear you found the issue. Not sure why that would cause the problem, but if it works... :)
The SDFat library supports file creation timestamps - not sure about modification date, but I assume it does that as well.
https://github.com/greiman/SdFat
ServiceXp
Post by ServiceXp »
Thank You
