I have two Adafruit motor shields V2 and three steppers on Arduino Mega. I only use onestep() to run them. My i2c is set to 400 kHz, thus I can now achieve only ~770 steps/s max combined among all three motors. I can't afford to loose MICROSTEPing capability to increase RPMs like this post suggests:
http://forums.adafruit.com/viewtopic.ph ... 1&start=15
However I found this reference here viewtopic.php?f=19&t=61371&p=310840&hil ... ed#p310840 that references a possibility for a further increase in i2c frequency. The question is how and/or if it's really possible?
Motor Shield RPM increase
- adafruit_support_bill
Re: Motor Shield RPM increase
You can try changing the 4000000L divisor in the line:
Some have reported success with 500KHz. The absolute max for your case will depend on the processor and what else you may have attached to the i2c bus.
TWBR = ((F_CPU /400000l) - 16) / 2; // Change the i2c clock to 400KHz
- kalniss
Of course doing it this way is the same as changing the #define TWI_FREQ 850000L in twi.h line, however this pushed me to do some incremental tests, and I was able to rise i2c frequency to 850kHz until it stopped responding. This gave me comfortable 1000 steps/s combined among my three motors (DOUBLE/MICROSTEP combo). It starts to get jerky at around 1050 steps/s.
Thanks for the replay.
Great! Thanks for posting your results. With 2 shields plugged in, you have effectively stronger pullups and a very short bus, both of which favor higher speeds.
