Hey,
I was wondering whether or not Motor Shield v2.3 reserves different pins than 1.X models as mentioned in the sticky.
Motor Shield V2.3 used pins?
- Franklin97355
Re: Motor Shield V2.3 used pins?
According to this tutorial
What pins are/are not used on the motor shield?
The shield uses the SDA and SCL i2c pins to control DC and stepper motors. On the Arduino UNO these are also known as A4 and A5. On the Mega these are also known as Digital 20 and 21. On the Leonardo these are also known as digital 2 and 3. Do not use those pins on those Arduinos with this shield with anything other than an i2c sensor/driver.
Since the shield uses I2C to communicate, you can connect any other i2c sensor or driver to the SDA/SCL pins as long as they do not use address 0x60 (the default address of the shield)
If you want to use the servo connections, they are on pins #9 and #10. If you do not use the connector then those pins are simply not used.
You can use any other pins for any other use
