Conflict with WaveHC and Servo Libraries
nordb732
Post by nordb732 »
When I first added the WaveHC libraries I was getting this error:
"Arduino: 1.0.6 (Windows NT (unknown)), Board: "Arduino Uno"
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino/Arduino.h:235,
from sketch_oct19a.ino:18:
C:\Program Files (x86)\Arduino\hardware\arduino\variants\standard/pins_arduino.h:40: error: expected unqualified-id before numeric constant
C:\Program Files (x86)\Arduino\hardware\arduino\variants\standard/pins_arduino.h:41: error: expected unqualified-id before numeric constant
C:\Program Files (x86)\Arduino\hardware\arduino\variants\standard/pins_arduino.h:42: error: expected unqualified-id before numeric constant
C:\Program Files (x86)\Arduino\hardware\arduino\variants\standard/pins_arduino.h:43: error: expected unqualified-id before numeric constant"
Then I went and comment out two of the WaveHC libraries and manage to clear this error but I want to make sure by not including these libraries it won't affect the sketch. These are the two libraries I've comment out:
#include <WavePinDefs.h>
#include <mcpDac.h>
After commenting those libraries out, I'm now getting this error message when I go to compile my sketch:
"WaveHC\WaveHC.cpp.o: In function `__vector_11':
C:\Users\Brandon\Documents\Arduino\libraries\WaveHC/WaveHC.cpp:41: multiple definition of `__vector_11'
Servo\Servo.cpp.o:C:\Program Files (x86)\Arduino\libraries\Servo/Servo.cpp:103: first defined here"
Is there a modified version of the WaveHC library that can work with the Servo Library? Or Can I combine the two libraries by putting Servo int WaveHC? Or something else that I can be step through to fix my issue?
I can be contacted by email at: [email protected]
Re: Conflict with WaveHC and Servo Libraries
WaveHC is not compatible with the Servo Lbrary. They both use the same timer, so there is a conflict over the timer interrupt vector.
There are software servo libraries out there that don't use the timer interrupts. Check over at the Arduino Playground. http://playground.arduino.cc/ComponentLib/Servo
nordb732
Post by nordb732 »
Thank you for the help.
nordb732
Post by nordb732 »
I'm still using a Uno R3 with a Wave shield, Parallax B.O.E. shield and a 1GB X Digital Media SD card. Libaries being used are the Servotimer2 and the WaveHC libraries. The issue is that I have all my servo being trigger while music is playing. What do I need to do to solve this issue? Would it make a difference if I use a Mega2560 instead of the Uno? Or is there a way to modify the libraries to use different timers? The code below is what I'm using for my project.
#include <ServoTimer2.h>
#include <FatReader.h>
#include <SdReader.h>
#include <avr/pgmspace.h>
#include "WaveUtil.h"
#include "WaveHC.h"
ServoTimer2 HOIST;
ServoTimer2 CRANE;
ServoTimer2 LEFT;
ServoTimer2 RIGHT;
const int BB = 0;
const int PPB = 1;
const int FB = 11;
SdReader card;
FatVolume vol;
FatReader root;
uint8_t dirLevel;
dir_t dirBuf;
WaveHC wave;
void lsR(FatReader &d);
void play(FatReader &dir);
void setup()
  Serial.begin(9600);
  Serial.println (F("Hello World,"));
  //delay (500);
  Serial.println (F("Welcome"));
  delay (500);
  Serial.println (F("System is Booting Up!"));
  delay (100);
  Serial.println (F("\nAttaching Servos NOW!"));
  delay (100);
  HOIST.attach (7);
  Serial.println (F("\tServo 1 Attached!"));
  delay (500);
  CRANE.attach (6);
  Serial.println (F("\tServo 2 Attached!"));
  delay (500);
  LEFT.attach (8);
  Serial.println (F("\tServo 3 Attached!"));
  delay (500);
  RIGHT.attach (9);
  Serial.println (F("\tServo 4 Attached!"));
  delay (500);
  Serial.println (F("Centering Servos NOW!"));
  delay (100);
  HOIST.write (1500);
  Serial.println (F("\tServo 1 Centered!"));
  delay (500);
  CRANE.write (1500);
  Serial.println (F("\tServo 2 Centered!"));
  delay (500);
  LEFT.write (1500);
  Serial.println (F("\tServo 3 Centered!"));
  delay (500);
  RIGHT.write (1500);
  Serial.println (F("\tServo 4 Centered!"));
  delay (500);
  Serial.println (F("Attaching Inputs NOW!"));
  delay (100);
  pinMode (A0, INPUT);
  Serial.println (F("\tInput 1 Attached!"));
  delay (500);
  pinMode (A1, INPUT);
  Serial.println (F("\tInput 2 Attached!"));
  delay (500);
  pinMode (A2, INPUT);
  Serial.println (F("\tInput 3 Attached!"));
  delay (500);
  pinMode (A3, INPUT);
  Serial.println (F("\tInput 4 Attached!"));
  delay (500);
  putstring_nl("\nWave test!");
  putstring ("Free RAM: ");
  Serial.println (freeRam());
  pinMode (BB, INPUT);
  pinMode (PPB, INPUT);
  pinMode (FB, INPUT);
  pinMode (2, OUTPUT);
  pinMode (3, OUTPUT);
  pinMode (4, OUTPUT);
  pinMode (5, OUTPUT);
  if (!card.init ())
    putstring_nl ("Card init. failed!");
    sdErrorCheck ();
    return;
  card.partialBlockRead(true);
  uint8_t part;
  for (part = 0; part < 5; part++)
    if (vol.init (card, part) )
      break;
  if (part == 5)
    putstring_nl ("No valid FAT partition!");
    sdErrorCheck ();
    while (1);
  putstring ("Using partition ");
  Serial.print (part, DEC);
  putstring (", type is FAT");
  Serial.println (vol.fatType(),DEC);
  if (!root.openRoot(vol))
    putstring_nl ("Can't open root dir!");
    while (1);
  putstring_nl ("Files found:");
  dirLevel = 0;
  lsR (root);
  skip:
  Serial.println (F("System is now Running!"));
void loop()
  Serial.println (F("START OF LOOP\n"));
  int x = 1;
  int L_R_base = analogRead(A2);
  int U_D_base = analogRead(A3);
  int L_R_crane = analogRead(A0);
  int U_D_hoist = analogRead(A1);
  Serial.println (F("Starting Scan Joystick Values"));
  delay (1);
  Serial.print ("\n\tL_R_base: "); Serial.print (L_R_base);
  delay (1);
  Serial.print ("\n\tU_D_base: "); Serial.print (U_D_base);
  delay (1);
  Serial.print ("\n\tL_R_crane: "); Serial.print (L_R_crane);
  delay (1);
  Serial.print ("\n\tU_D_hoist: "); Serial.print (U_D_hoist);
  delay (1);
//LOOP 1
  while (L_R_base <= 255.0)
    Serial.print (F("\n\nL_R_base:")); Serial.print (L_R_base);
    Serial.print (F("\nCrane is turning right NOW!\n"));
    LEFT.write (1600);
    delay (250);
    RIGHT.write (1600);
    delay (250);
    L_R_base = 511.0;
//LOOP 2
  while (L_R_base >= 767.0)
    Serial.print (F("\nCrane is turning left NOW!\n"));
    LEFT.write (1400);
    delay (250);
    RIGHT.write (1400);
    delay (250);
    L_R_base = 511.0;
//LOOP 3
   while (U_D_base <= 5.0)
    Serial.print (F("\n\nU_D_base:")); Serial.print (U_D_base);
    Serial.print (F("\nCrane is moving forwards NOW!\n"));
    LEFT.write (1600);
    delay (250);
    RIGHT.write (1400);
    delay (250);
    U_D_base = 15.0;
//LOOP 4
  while (U_D_base >= 30.0)
    Serial.print (F("\nCrane is moving backwards NOW!\n"));
    LEFT.write (1400);
    delay (250);
    RIGHT.write (1600);
    delay (250);
    U_D_base = 15.0;
//LOOP 5
  while (L_R_crane <= 255.0)
    Serial.print (F("\n\nL_R_crane:")); Serial.print (L_R_crane);
    Serial.print (F("\nCrane is rotating left NOW!\n"));
    CRANE.write (1520);
    delay (250);
    L_R_crane = 511.0;
//LOOP 6
  while (L_R_crane >= 767.0)
    Serial.print (F("\nCrane is rotating right NOW!\n"));
    CRANE.write (1480);
    delay (250);
    L_R_crane = 511.0;
//LOOP 7
   while (U_D_hoist >= 767.0)
    Serial.print (F("\n\nU_D_hoist:")); Serial.print (U_D_hoist);
    Serial.print (F("\nCrane is hoisting the hook NOW!\n"));
    HOIST.write (2000);
    delay (250);
    U_D_hoist = 511.0;
//LOOP 8
  while (U_D_hoist <= 255.0)
    Serial.print (F("\nCrane is lowering the hook NOW!\n"));
    HOIST.write (1000);
    delay (250);
    U_D_hoist = 511.0;
  if (PPB == HIGH)
    root.rewind();
    play(root);
  HOIST.write (1500);
  delay (1);
  CRANE.write (1500);
  delay (1);
  RIGHT.write (1500);
  delay (1);
  LEFT.write (1500);
  delay (1);
  Serial.println (F("\nEND OF LOOP\n"));
int freeRam(void)
  extern int  __bss_end;
  extern int  *__brkval;
  int free_memory;
  if ((int)__brkval == 0)
    free_memory = ((int)&free_memory) - ((int)&__bss_end);
  else
    free_memory = ((int)&free_memory) - ((int)__brkval);
  return free_memory;
void sdErrorCheck(void)
  if (!card.errorCode ()) return;
  putstring ("\n\rSD I/O error: ");
  Serial.print (card.errorCode (), HEX);
  putstring (", ");
  Serial.println (card.errorData (), HEX);
  return;
void printName (dir_t &dir)
  for (uint8_t i = 0; i < 11; i++)
    if (dir.name [i] == ' ')
        continue;
    if (i == 8)
        Serial.print ('.');
    Serial.print (dir.name [i]);
  if (DIR_IS_SUBDIR(dir))
    Serial.print ('/');
void lsR (FatReader &d)
  int8_t r;
  while ((r = d.readDir (dirBuf)) > 0)
    if (dirBuf.name [0] == '.')
      continue;
    for (uint8_t i = 0; i < dirLevel; i++)
      Serial.print (' ');
    printName (dirBuf);
    Serial.println ();
    if (DIR_IS_SUBDIR (dirBuf)) {
      FatReader s;
      dirLevel += 2;
      if (s.open (vol, dirBuf))
        lsR (s);
      dirLevel -=2;
  sdErrorCheck ();
void play (FatReader &dir)
  FatReader file;
  while (dir.readDir (dirBuf) > 0)
    if (dirBuf.name[0] == '.')
      continue;
    Serial.println ();
       Serial.print (' ');
    if (!file.open (vol, dirBuf))
      Serial.println ("file.open failed");
      while (1);
    if (file.isDir ())
      putstring ("Subdir: ");
      printName (dirBuf);
      dirLevel += 2;
      play (file);
      dirLevel -= 2;
    else
      putstring ("Playing "); printName (dirBuf);
      if (!wave.create (file))
        putstring (" Not a valid WAV");
      else
        Serial.println ();
        wave.play ();
        while (wave.isplaying)
          putstring (".");
          delay (100);
        sdErrorCheck ();
WaveHC uses timer 1 on the UNO. I don't know why ServoTimer2 would be affected by Timer 1. There is also a Software Servo library out there. That uses no timers at all. http://playground.arduino.cc/ComponentLib/Servo
The Wave shield is not compatible with the Mega.
