Do I have to upload any files to my Arduino to...
- edv2009
Do I have to upload any files to my Arduino to make the voice changer work? I've connected everything like in the diagrams and tutorials, but am unclear on this step. So far the voice changer isn't working....;
Re: Do I have to upload any files to my Arduino to...
Yes. In the "Phase 2" section of the build instructions there is a link to the source for the "Adavoice" sketch.
https://learn.adafruit.com/wave-shield- ... uilding-it
- edv2009
Do I just copy and paste this onto my sketch? I'm sorry, I'm very new at all this and just don't really understand...
On the lower right of the github page is a "download zip" button. Download and unzip that into your Arduino sketchbook folder. (If you don't know where that is, run the IDE and click File->Preferences and it will show you your sketchbook location.)
Once there, you can click File->Sketchbook->adavoice to load the sketch. Then compile and upload it to your Arduino.
- edv2009
I'm on this page. https://github.com/adafruit/adavoice/bl ... avoice.pde
I'm not seeing any download zip button. I'm running windows 8, so not sure if its coming up different. Thanks for all your help so far.
- edv2009
Sorry, realized I had to download github.
- Franklin97355
Back up one level and you will see it on this page
- edv2009
Alright, I had it working for a few seconds. Thanks again for walking me thru that programming bit. But it appears I've popped my amplifier... I stole a little speaker from a speaker pod. Do I need a specific ohm speaker to use in the system?
It should work with most small speakers in the 4-8 ohm range. It is hard to burn out the amp unless you have a direct short. What kind of speaker did you connect? If you post photos of your soldering and connections, we'll take a look.
