Moving Wave Shield pin 10
- wesg
Just assembled a Wave Shield kit for my Uno and I'd like to change pin 10 (I soldered female headers in the 10-13 pin section for my project in my eagerness). Searching the forum I've learned that WavePinDef.h has pin assignments but I don't see anywhere for pin 10. I'd like to clean up the wires and use pins 2-6 for the shield so the analog pins can read buttons. Where is the assignment for pin 10 (marked CCS in the tutorial)?
Re: Moving Wave Shield pin 10
Pin 10 is defined as SS in the file hardware/arduino/variants/standard/pins_arduino.h, and used under the name SS in the SPI library.
Unfortunately, the SPI and WaveHC libraries weren't designed to make it easy to redefine that pin for a single project.
- wesg
OK thanks for the info, Mike. I think I'll try to clear the solder for pin 10 and reduce the number of changes required.
