Got my new ultimate GPS breakout shield and man... It is slick! I especially like the GPS library that comes with. I am working on a project that is going to contain several sensors, so I want to be very careful with memory. I'd like to make sure I have a GPRMC string, parse it from the GPS, and write it to SDCard. I've noticed in the header files there is a GPS.waitForSentence(String) where I can pass in "$GPRMC" but what I can't see is how I can use the GPS.* library to get the full NMEA string. It's a waste of memory to parse the string all over again...
My logic is somethling like this pseudocode:
if (GPS.newNMEAreceived())
GPS.parse(GPS.lastNMEA()); // Read the string
GPS.<here's where i want to just get the NMEA string>
I can't find a command in the header to do this, so is my only option to approach this the other way? Do I have to keep parsing the serial port looking for $GPRMC?
Adafruit GPS Library
Re: Adafruit GPS Library
The simplest solution would be to tell the GPS module only to send $GPRMC sentences at the rate you want them.
The commands to do that are listed in the module's documentation (pages 12 and 13):
http://www.adafruit.com/datasheets/PMTK_A11.pdf
- johnover
Mike, thanks - that did it. In fact, there's a string in the header to do it (I'd only opened one of the GPS support files):
GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCONLY);
Then sending the following command disabled the PGTOP messages:
GPS.sendCommand(PGCMD_NOANTENNA);
Now I'm simply working on cutting my memory use. GPS uses a lot of memory. I may ultimately end up simply parsing pointers, but this is a good beginning for sure.
