What can i do?
//wifi libraries
#include <SPI.h>
#include <WiFi.h>
//NFC-Libs
#include <Wire.h>
#include <Adafruit_NFCShield_I2C.h>
#define IRQ (2)
#define RESET (3) // Not connected by default on the NFC Shield
Adafruit_NFCShield_I2C nfc(IRQ, RESET);
char ssid[] = ""; // your network SSID (name)
char pass[] = ""; // your network password
int status = WL_IDLE_STATUS;
// Initialize the Wifi client library
WiFiClient client;
// server address:
//char server[] = "www.arduino.cc";
IPAddress server(192,xxx,xxx,xxx); // numeric IP for laptop with server xamp installed (no DNS)
// What page to grab!
#define WEBSITE "192,xxx,xxx,xxx" // need to enter actual IP
#define WEBPAGE "/PhpProjectThesis/add_data.php"
//define Arduino pins to operate status LEDs
const int signalPin = 8;
const int failPin = 7;
const int logUser = 6;
const int logKiste = 5;*/
//this is the counter that will be used for uploading data
long pollCounter = 1;
//used for storing data for upload
//set it to the data type that suits your data
int id;
int im_type = 1; // 1 stands for RFID to Log In in the Checkin-DB, 2 stands for LogOut
int sublocation = 4; //set location key according to where the RFID reader is installed, e.g. 4 for Office 4
//used for data received from base station
int
command_1, command_2;
//variables for poll timer
//this is a 'non-blocking' timer -- does not use delay(), so operations such as sensor reads can continue between polls
//interval at which to poll base station
//takes a value in seconds; add more multipliers if you want a more convenient unit
long pollInterval = 10L * 1000L; //converts from millis; initial default value is to poll every 10 sec
long lastPoll; //stores the last time we polled
boolean pollFlag = false; //tells the sketch whether to poll or not
//declare a variable to hold a numeric IP address
//can be overridden below if you use lookup
void setup(void)
/*set the LEDs
pinMode(signalPin, OUTPUT);
pinMode(failPin, OUTPUT);
pinMode(logUser, OUTPUT);
pinMode(logKiste, OUTPUT);
//turn on the signal LED to show we're starting
digitalWrite(signalPin, HIGH);
//flash LEDs to confirm it works
digitalWrite(failPin, HIGH);
delay(200);
digitalWrite(failPin, LOW);
digitalWrite(logUser, HIGH);
delay(200);
digitalWrite(logKiste, LOW);
delay(200);
digitalWrite(logKiste, LOW);*/
Serial.begin(115200);
Serial.println(F("Hello, Beginning!\n"));
/* Initialise the module */
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
// digitalWrite(failPin, HIGH); //turn on the fail LED
Serial.println(F("WiFi shield not present"));
// don't continue:
while(true);
// attempt to connect to Wifi network:
while ( status != WL_CONNECTED) {
Serial.println(F("Attempting to connect to SSID: "));
Serial.println(ssid);
// Connect to WPA/WPA2 network.
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
// you're connected now, so print out the status:
printWifiStatus();
//flash the LED
/*for (int i=0; i<5; i++) {
delay(200);
digitalWrite(signalPin, LOW);
delay(200);
if (!WiFi.begin(ssid, pass))
//digitalWrite(failPin, HIGH); //turn on the fail LED
Serial.println(F("Couldn't begin()! Check your wiring?"));
while(true);
//Set up the NFC module
Serial.println(F("Starting NF-Reader..."));
nfc.begin();
uint32_t versiondata = nfc.getFirmwareVersion();
if (! versiondata) {
Serial.print(F("Didn't find PN53x board"));
while (true); // halt
// Got ok data, print it out!
Serial.print("Found chip PN5"); Serial.println((versiondata>>24) & 0xFF, HEX);
Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
// configure board to read RFID tags
nfc.SAMConfig();
Serial.println(F("NF-Reader started!"));
//flash the LED
delay(200);
delay(200); */
//Text for User to see system is ready
Serial.println(F("Waiting for an ISO14443A Card ..."));
void loop(void)
//digitalWrite(signalPin, LOW); //turn off the signal LED
//check if it is time to poll
if(pollFlag == true)
Serial.println();
Serial.print("Poll counter: "); Serial.println(pollCounter);
//execute our data handlers to get data to send back to base station
NFC_ID_handler();
//build the URI and GET args
//we have to do this within the loop to get fresh values for data
String url_base = WEBPAGE;
String url_param1 = "?id=" + String(id);
String url_param2 = "&im_type=" + String(im_type);
String url_param3 = "&sublo=" + String(sublocation);
String url_httptail = " HTTP/1.0";
String url_complete = url_base + url_param1 + url_param2 + url_param3 + url_httptail;
Serial.println("url: " + url_complete);
//String pageValue = connectAndRead(url_complete); //connect to the server and read the output
//Serial.println(pageValue); //print out the findings.
/* Try connecting to the website */
if (client.connect(server, 80)) {
Serial.println("connecting...");
//digitalWrite(signalPin, HIGH); //turn on the signal LED to show we're connected
client.print("GET ");
client.println(url_complete);
client.println();
client.print(F("Host: ")); client.print(F(WEBSITE)); client.print(F("\n"));
client.print(F("Connection: close\n"));
client.println();
//digitalWrite(failPin, LOW); //make sure fail LED is off after successful poll
} else {
Serial.println(F("Connection failed"));
//digitalWrite(failPin, HIGH); //turn fail LED on after unsuccessful poll
return;
//define a String to hold our json object
String commands = "";
//set a flag for when to start adding to String
boolean readflag = false;
//read in data one character at a time while connected
while (client.available() && status == WL_CONNECTED) {
char c = client.read();
//start storing at the [ marker
if (c=='[') {readflag = true;}
if (c==']') {readflag = false;}
//build data read from client into a String
if ((readflag == true) && (c != '[')) {
commands = commands + c;
client.flush();
client.stop();
//digitalWrite(signalPin, LOW); //turn off the LED
//now we should have all our commands in the String 'commands'
//next we need to parse it into three separate integers
//find out where the commas are
int comma1 = commands.indexOf(',');
int comma2 = commands.lastIndexOf(',');
command_1 = (commands.substring(0,comma1)).toInt();
command_2 = (commands.substring(comma1+1,comma2)).toInt();
Serial.print(("\r\nRESULTS:\r\n command_1: "));
Serial.println(command_1);
Serial.print((" command_2: "));
Serial.println(command_2);
//execute our command handlers to process commands we received from the base station
command_1_handler();
command_2_handler();
//now that we've polled, get ready for next poll
pollCounter = pollCounter + 1; //increment the counter
pollFlag = false;
lastPoll = millis();
Serial.print("\r\n Next poll in ");
Serial.println(pollInterval/1000);
} //end of what we do if pollFlag == true
else //what we do if pollFlag == false
//check to see if it's time to poll
if (millis() >= (lastPoll + pollInterval))
{ //it's time to poll!
pollFlag = true;
} //end of what we do if pollFlag == false
} //end of the loop
@brief Tries to read the IP address and other connection details
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
@brief NFC-Reader is reading TAGs here
void NFC_ID_handler(void)
uint8_t success;
uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 }; // Buffer to store the returned UID
uint8_t uidLength; // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
// Wait for an ISO14443A type cards (Mifare, etc.). When one is found
// 'uid' will be populated with the UID, and uidLength will indicate
// if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength);
Serial.print("Success: "); Serial.println(success);
id=0;
for (int i = 0; i < 8; i++) { //iterate over array, take value and write to ID_final as an integer
id = id + uid[i];
// Display some basic information about the card
Serial.println("Found an ISO14443A card");
Serial.print(" UID Length: ");Serial.print(uidLength, DEC);Serial.println(" bytes");
Serial.print(" UID Value: ");
nfc.PrintHex(uid, uidLength);
Serial.println("");
Serial.print("UID_final: "); Serial.println(id);
if (uidLength == 4)
// We probably have a Mifare Classic card ...
Serial.println("Seems to be a Mifare Classic card (4 byte UID)");
// Now we need to try to authenticate it for read/write access
// Try with the factory default KeyA: 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
//Serial.println("Trying to authenticate block 4 with default KeyA value");
uint8_t keya[6] = { 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF };
// Start with block 4 (the first block of sector 1) since sector 0
// contains the manufacturer data and it's probably better just
// to leave it alone unless you know what you're doing
success = nfc.mifareclassic_AuthenticateBlock(uid, uidLength, 4, 0, keya);
if (success)
//Serial.println("Sector 1 (Blocks 4..7) has been authenticated");
uint8_t data[16];
// If you want to write something to block 4 to test with, uncomment
// the following line and this text should be read back in a minute
// data = { 'a', 'd', 'a', 'f', 'r', 'u', 'i', 't', '.', 'c', 'o', 'm', 0, 0, 0, 0};
// success = nfc.mifareclassic_WriteDataBlock (4, data);
// Try to read the contents of block 4
success = nfc.mifareclassic_ReadDataBlock(4, data);
if (success)
// Data seems to have been read ... spit it out
Serial.println("Reading Block 4:");
nfc.PrintHexChar(data, 16);
Serial.println("");
// Wait a bit before reading the card again
delay(1000);
pollFlag = true;
else
Serial.println("Ooops ... unable to read the requested block. Try another key?");
else
Serial.println("Ooops ... authentication failed: Try another key?");
if (uidLength == 7)
// We probably have a Mifare Ultralight card ...
Serial.println("Seems to be a Mifare Ultralight tag (7 byte UID)");
// Try to read the first general-purpose user page (#4)
Serial.println("Reading page 4");
uint8_t data[32];
success = nfc.mifareultralight_ReadPage (4, data);
if (success)
nfc.PrintHexChar(data, 4);
Serial.println("");
delay(1000);
pollFlag = true;
else
Serial.println("Ooops ... unable to read the requested page!?");
void command_1_handler(void)
//example
if (command_1 == 1)
//log in user
//flash the LED
delay(200);
digitalWrite(logUser, LOW);
delay(200);
else if (command_1 == -1)
//Not registered or logged
//flash the LED
delay(200);
delay(200);
void command_2_handler(void)
//example
if (command_2 == 1)
//log in kiste
//flash the LED
digitalWrite(logKiste, HIGH);
delay(200);
delay(200);
else if (command_2 == -1)
//flash the LED
delay(200);
delay(200);
Found chip PN532
Firmware ver. 1.6
NF-Reader started!
Poll counter: 1
Success: 1
UID Length: 4 bytes
UID Value: 0x03 0x11 0x5A 0xC2
UID_final: 304
Reading Block 4:
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
url: /PhpProjectThesis/add_data.php?id=304&im_type=1&sublo=4 HTTP/1.0
connecting...
RESULTS:
command_1: 0
command_2: 0
Next poll in 10
Poll counter: 2
Success: 1
UID Length: 4 bytes
UID Value: 0xE3 0x71 0x67 0xC2
UID_final: 638
Reading Block 4:
url: /PhpProjectThesis/add_data.php?id=638&im_type=1&sublo=4 HTTP/1.0
connecting...
RESULTS:
command_1: 0
command_2: 0
Next poll in 10
Poll counter: 3
Success: 1
UID Length: 4 bytes
UID_final: 637
Reading Block 4:
url: /PhpProjectThesis/add_data.php?id=637&im_type=1&sublo=4 HTTP/1.0
connecting...
RESULTS:
command_1: 0
command_2: 0
Next poll in 10
Poll counter: 4
Success: 1
UID Length: 4 bytes
UID_final: 637
Reading Block 4:
connecting...
RESULTS:
command_1: 0
command_2: 0
Next poll in 10
Poll counter: 5
Success: 1
UID Length: 4 bytes
UID_final: 637
Reading Block 4:
connecting...
RESULTS:
command_1: 0
command_2: 0
Next poll in 10
Poll counter: 6
Success: 1
UID Length: 4 bytes
UID_final: 637
Reading Block 4:
connecting...
RESULTS:
command_1: 0
command_2: 0
Next poll in 10
Poll counter: 7
Success: 1
UID Length: 4 bytes
UID_final: 325
Reading Block 4:
url: /PhpProjectThesis/add_data.php?id=325&im_type=1&sublo=4 HTTP/1.0
connecting...
RESULTS:
command_1: 0
command_2: 0
Next poll in 10
Poll counter: 8
PD: i am using Arduino IDE 1.0.2. With a newer version it doesnt connect
