I am a complete novice at this. Yesterday I assembled my Wave Shield and thought everything was ok but when I set up Arduino this morning as soon as I connected the wave shield to Arduino Uno would loose power and power light would fade. Works fine without shield installed.
Now from what I can find that suggests a short ?
I will check all my solder connections but after seeing another post about a chip upside down I realised that one of the chips I have does not have the little semi circular cut out to match to silk screen so am wondering if I have put it on the wrong way around. It is the TLV2462 chip.
Included photo of back of board in case anyone can spot any issues
Any help appreciated
I
Problem with Wave Shield
- Franklin97355
Re: Problem with Wave Shield
It does look like the chip is upside down The spots I marked should be pin 1 and the chip in the lower left isn't correct. Most of your soldering looks OK but there are a few that could use a bit more sloder and some that didn't flow out well.
- Nzarra
Many Thanks - I will have a go at removing it and flipping chip and then re check all solder and be a little more generous (did not want to overdo and think went to other extreme, especially on the header pins.
Any tips for removing a component - assume I melt solder again and remove but with six pins could be tricky
- Franklin97355
ChipQuik solder is what they use for multi pin devices or a hot air gun. The other way is to run your iron along one side until it melts and pry (gently) a small amount then go to the other side. Walk back and forth until the pins come out. Use solder braid to get as much solder off as possible before starting.
- Nzarra
Many thanks, picked up some solder braid this afternoon so will give it a go tomorrow.
- Nzarra
Removing and turning chip around worked well and got power to the Arduino with Wave whiled plugged in. Formatted SD card and put some WAV files together - based on the serial output appears to be reading and playing files but I am only getting a little buzzing from the headphones or speaker (connected through headphone jack)
Could I have damaged the chip putting in wrong to start ?
- Nzarra
Did some testing using cheap headset test from other threads - nothing on R7 capacitor lead
On Arduino
3 - light static
4 - loud static
5 - nothing
DAC Pins
3 - light static
4 - loud static
5 - nothing
8 - nothing
On Arduino
3 - light static
4 - loud static
5 - nothing
DAC Pins
3 - light static
4 - loud static
5 - nothing
8 - nothing
- Nzarra
Any suggestions ? Any help appreciated.
It's possible that the heat and stress of removing/resoldering the TLV2462 did damage it. That's always a risk in rework.
Post another photo of the underside of the shield to confirm the soldering, then we'll look for other sources of trouble.
- Nzarra
No problems, will take some updated ones tonight.
- Nzarra
Any suggestions on where to go with this - or do I just bite the bullet and order another one ?
You probably don't need a whole new Wave Shield, just another op amp for output.
Go ahead and remove the one that's there (the same way you did before, or just clip it out with a wire cutter and remove the pins from the holes one at a time), and get one of these:
https://www.adafruit.com/products/808
That will work as a replacement for the one that's there.
Once you've removed the op amp, try testing the DAC's output with a high-impedance speaker again.
