Hello, does anyone know if this shield will fit snugly on the Yun?
https://www.adafruit.com/products/196
I believe the pins are correct but doesn't seem like it will fit nicely with the ethernet and USB connectors on the Yun protruding higher than the board pins.
Proto-Screwshield and Yun
Re: Proto-Screwshield and Yun
The connections will be iffy by themselves, but you can use a layer of stacking header between the Yun and the shield to get better clearance: https://www.adafruit.com/products/85
