Mike,
I was able to attach the pictures once I cropped/sized them to below 800x600.... the input voltage that I tested was 5V and 12V.. I know the voltage is hitting the pins (Vin and Gnd) because I measured them...also I attached an amp meter and the board is not pulling any current. There was one solder joint that had some extra solder on it (see picture) but that has been removed and did not actually connect with the nearby Via from what I can tell by measuring.
Again, when I apply 5v to 12v to Vin I should get something at 3v/5v right ????
Music Shield MP3 player
Re: Music Shield MP3 player
The Music Maker Shield is made to go on an Arduino. The Vin pin doesn't connect to anything else on the shield, but it does connect to the Arduino's 5v regulator when the shield is plugged in. Then the shield draws power from the Arduino's 5v pin.
- doscherda
Mike,
So if I apply 5V to the 5V pin on the Music Maker then the unit will power on ? Should I also apply 3V to the 3V pin ?
I am using an AVR-CAN unit and expect that I can connect the AVR to the Music Maker by mapping the appropriate pins. I will write my own software for the AVR to drive the Music Maker. The documentation is not clear on the power issues and I would like to know exactly what is required to get the unit powered on.
David
David
- stem5
Sorry to keep bothering you, but I have a complex project idea that we have keep facing many obstacles with. The idea of the project is to have a pulse sensor control a music shield. In other words, depending on the person's heart's BPM, different tracks will be playing. To do this, I created a code that mixed your player_simple code, the pulse sensor code, and a map function. The code, however, is not working and I am not sure if it is the music shield or the pulse sensor. I wanted to know which out of all the codes that you provide are best for this sort of manipulation. I don't even know if it is possible to do such a thing, but if so, I would really like to try. If there is any advice that you can give me, I would really appreciate it. I am also attaching the code below so you can understand what I have done.
Thank you
Code:
Thank you
Code:
//Include Music Shield Library
#include <SPI.h>
#include <Adafruit_VS1053.h>
#include <SD.h>
// Define everything needed for the Music Shield
#define BREAKOUT_RESET 9 // VS1053 reset pin (output)
#define BREAKOUT_CS 10 // VS1053 chip select pin (output)
#define BREAKOUT_DCS 8 // VS1053 Data/command select pin (output)
#define SHIELD_RESET -1 // VS1053 reset pin (unused!)
#define SHIELD_CS 7 // VS1053 chip select pin (output)
#define SHIELD_DCS 6 // VS1053 Data/command select pin (output)
#define CARDCS 4 // Card chip select pin
#define DREQ 3 // VS1053 Data request, ideally an Interrupt pin
//Explain what musicplayer means
Adafruit_VS1053_FilePlayer musicPlayer =
// create breakout-example object!
//Adafruit_VS1053_FilePlayer(BREAKOUT_RESET, BREAKOUT_CS, BREAKOUT_DCS, DREQ, CARDCS);
// create shield-example object!
Adafruit_VS1053_FilePlayer(SHIELD_RESET, SHIELD_CS, SHIELD_DCS, DREQ, CARDCS);
//Variables for the Pulse Sensor
int pulsePin = 0; // Pulse Sensor purple wire connected to analog pin 0
//These variables are volatile because they are used during the interrupt service routine!
volatile int BPM; // used to hold the pulse rate
volatile int Signal; // holds the incoming raw data
volatile int IBI = 600; // holds the time between beats, must be seeded!
volatile boolean Pulse = false; // true when pulse wave is high, false when it's low
volatile boolean QS = false; // becomes true when Arduoino finds a beat.
//Define integer range for the switchcase map function
const int sensorMin = 40; // sensor minimum, dicovered through research MAY CHANGE
const int sensorMax = 180; // sensor maximum, discovered through research MAY CHANGE
//Now we are going to set up the sensor and the shield.
//The swtichcase does not need setup because we are not using the serial monitor for it.
void setup(){
Serial.begin(115200);
Serial.println("Adafruit VS1053 Simple Test");
interruptSetup(); // sets up to read Pulse Sensor signal every 2mS
//Now we setup the rest of the shield.
if (! musicPlayer.begin()) { // initialise the music player
Serial.println(F("Couldn't find VS1053, do you have the right pins defined?"));
while (1);
Serial.println(F("VS1053 found"));
SD.begin(CARDCS); // initialise the SD card
// Set volume for left, right channels. lower numbers == louder volume!
musicPlayer.setVolume(05,05);
musicPlayer.useInterrupt(VS1053_FILEPLAYER_PIN_INT); // DREQ int
//Void setup is done, now we tell the arduino what to do with all this information.
void loop(){
// read the sensor:
int sensorReading = analogRead(A0);
//A0 should be BPM
// map the sensor range to a range of four options:
int range = map(sensorReading, sensorMin, sensorMax, 0, 4);
//In our map range 0=70-110, 1=110-150, 2=150-190, 3=190-230, 4=end(DEAD)
// do something different depending on the
// range value:
//Track 1 is resting music, track 2 is medium beat, track 3 is fast beat, and track 4 is continous beeps.
switch (range) {
case 0: // 70BPM - 110 BPM
Serial.println(F("Playing track 001"));
musicPlayer.playFullFile("track001.mp3");
case 1: // 110 BPM - 150 BPM
Serial.println(F("Playing track 002"));
musicPlayer.startPlayingFile("track002.mp3");
case 2: // 150 BPM - 190 BPM
Serial.println(F("Playing track 003"));
musicPlayer.startPlayingFile("track003.mp3");
case 3: // 190 BPM - 230 BPM
Serial.println(F("Dangerous"));
musicPlayer.startPlayingFile("track004.mp3");
case 4: // DEAD
Serial.println(F("DEAD"));
musicPlayer.startPlayingFile("track005.mp3");
break;
delay(1); //This is the delay of the switchcase.
//The Music Shield Requests 100, so this MAY CHANGE
This is the interrupt setting for the pulse sensor. I open it in a tab to connect the two codes:
volatile int rate[10]; // array to hold last ten IBI values
volatile unsigned long sampleCounter = 0; // used to determine pulse timing
volatile unsigned long lastBeatTime = 0; // used to find IBI
volatile int P =512; // used to find peak in pulse wave, seeded
volatile int T = 512; // used to find trough in pulse wave, seeded
volatile int thresh = 512; // used to find instant moment of heart beat, seeded
volatile int amp = 100; // used to hold amplitude of pulse waveform, seeded
volatile boolean firstBeat = true; // used to seed rate array so we startup with reasonable BPM
volatile boolean secondBeat = false; // used to seed rate array so we startup with reasonable BPM
void interruptSetup(){
// Initializes Timer2 to throw an interrupt every 2mS.
TCCR2A = 0x02; // DISABLE PWM ON DIGITAL PINS 3 AND 11, AND GO INTO CTC MODE
TCCR2B = 0x06; // DON'T FORCE COMPARE, 256 PRESCALER
OCR2A = 0X7C; // SET THE TOP OF THE COUNT TO 124 FOR 500Hz SAMPLE RATE
TIMSK2 = 0x02; // ENABLE INTERRUPT ON MATCH BETWEEN TIMER2 AND OCR2A
sei(); // MAKE SURE GLOBAL INTERRUPTS ARE ENABLED
// THIS IS THE TIMER 2 INTERRUPT SERVICE ROUTINE.
// Timer 2 makes sure that we take a reading every 2 miliseconds
ISR(TIMER2_COMPA_vect){ // triggered when Timer2 counts to 124
cli(); // disable interrupts while we do this
Signal = analogRead(pulsePin); // read the Pulse Sensor
sampleCounter += 2; // keep track of the time in mS with this variable
int N = sampleCounter - lastBeatTime; // monitor the time since the last beat to avoid noise
// find the peak and trough of the pulse wave
if(Signal < thresh && N > (IBI/5)*3){ // avoid dichrotic noise by waiting 3/5 of last IBI
if (Signal < T){ // T is the trough
T = Signal; // keep track of lowest point in pulse wave
if(Signal > thresh && Signal > P){ // thresh condition helps avoid noise
P = Signal; // P is the peak
} // keep track of highest point in pulse wave
// NOW IT'S TIME TO LOOK FOR THE HEART BEAT
// signal surges up in value every time there is a pulse
if (N > 250){ // avoid high frequency noise
if ( (Signal > thresh) && (Pulse == false) && (N > (IBI/5)*3) ){
Pulse = true; // set the Pulse flag when we think there is a pulse
IBI = sampleCounter - lastBeatTime; // measure time between beats in mS
lastBeatTime = sampleCounter; // keep track of time for next pulse
if(secondBeat){ // if this is the second beat, if secondBeat == TRUE
secondBeat = false; // clear secondBeat flag
for(int i=0; i<=9; i++){ // seed the running total to get a realisitic BPM at startup
rate[i] = IBI;
if(firstBeat){ // if it's the first time we found a beat, if firstBeat == TRUE
firstBeat = false; // clear firstBeat flag
secondBeat = true; // set the second beat flag
sei(); // enable interrupts again
return; // IBI value is unreliable so discard it
// keep a running total of the last 10 IBI values
word runningTotal = 0; // clear the runningTotal variable
for(int i=0; i<=8; i++){ // shift data in the rate array
rate[i] = rate[i+1]; // and drop the oldest IBI value
runningTotal += rate[i]; // add up the 9 oldest IBI values
rate[9] = IBI; // add the latest IBI to the rate array
runningTotal += rate[9]; // add the latest IBI to runningTotal
runningTotal /= 10; // average the last 10 IBI values
BPM = 60000/runningTotal; // how many beats can fit into a minute? that's BPM!
QS = true; // set Quantified Self flag
// QS FLAG IS NOT CLEARED INSIDE THIS ISR
if (Signal < thresh && Pulse == true){ // when the values are going down, the beat is over
Pulse = false; // reset the Pulse flag so we can do it again
amp = P - T; // get amplitude of the pulse wave
thresh = amp/2 + T; // set thresh at 50% of the amplitude
P = thresh; // reset these for next time
T = thresh;
if (N > 2500){ // if 2.5 seconds go by without a beat
thresh = 512; // set thresh default
P = 512; // set P default
T = 512; // set T default
lastBeatTime = sampleCounter; // bring the lastBeatTime up to date
firstBeat = true; // set these to avoid noise
secondBeat = false; // when we get the heartbeat back
sei(); // enable interrupts when youre done!
}// end isr
Last edited by adafruit_support_mike on Fri Mar 20, 2015 5:18 am, edited 1 time in total.
Reason: added CODE tags to preserve formatting
- doscherda
Mike,
I would like to know exactly what is required to get the unit powered on without hooking the unit up to another shield.
David
David
@doscherda: You can power the Music Maker by connecting 5v to the 5v pin, but it won't do anything. You need a data connection from a microcontroller like the Arduino to tell it what to do.
See the tutorial for complete information about working with the Music Maker: https://learn.adafruit.com/adafruit-mus ... r/overview
@stem5: You're probably getting interrupt conflicts between the VS1053 and the ISR for your pulse sensor.
The ISR in the code above is far bigger than normal. The longer the CPU spends executing code in an interrupt handler, the higher the chance that it will miss some other interrupt or have timing problems with the main code. The general rule is to collect the smallest amount of information you can in the ISR, then set a flag or other data value that tells the main code to do the heavy lifting.
- stem5
Ok thank you, that makes sense... The problem is that the ISR for the pulse sensor if necessary in order to get an accurate reading of the heartbeat. I cannot shorten it without creating more conflicts. I can, however, make the interrupt routine collect data every minute instead of every 2 milliseconds. Also, is the interrupt routine for the music shield necessary? Maybe I can change the coding into a timer interrupt and then rotate between the pulse sensor interrupting and then the music shield interrupting.
Thank you
Thank you
Your ISR can be as simple as this:
and the rest of the code can live in your main loop inside the following condition:
As long as you read the input on a controlled interval, you can do the rest of the processing a few microseconds later.
int Signal;
boolean SignalReady = false;
SignalReady = true;
if ( SignalReady ) {
// rest of code
- stem5
That would be for the music shield? Sorry, I'm new to this so that sounds a bit confusing... If that is for the music shield, and it includes Timer2, would the pulse sensor work as well because it also uses Timer2...?
Thank you and sorry
Thank you and sorry
I'm pretty sure the interrupt for the Music Maker is on TIMER1, so putting the pulse sensor interrupt on TIMER2 should be okay as long as the interrupt service routine doesn't spend too much time blocking other interrupts.
- stem5
I tried putting the ISR that you told me but this keeps coming up:
"expected unqualified-id before string constant"
I am not sure what that means or how to address it. I searched what string constants are, but nothing comes up. If you have any idea as to what that means it would be helpful.
Thank you
Thank you
The error probably means you missed a semicolon somewhere.
Post the code you're using (between CODE tags please) and we'll see what we can find.
- stem5
#include <SPI.h>
#include <SD.h>
const int sensorMin = 49; // sensor minimum, dicovered through research MAY CHANGE
const int sensorMax = 205; // sensor maximum, discovered through research MAY CHANGE
void setup(){
while (1);
void loop(){
//A0 should be BPM
switch (range) {
Serial.println(F("Starting"));
Serial.println(F("Upbeat"));
musicPlayer.playFullFile("track002.mp3");
Serial.println(F("Vigorous"));
musicPlayer.playFullFile("track003.mp3");
musicPlayer.playFullFile("track004.mp3");
case 4: // DEAD
musicPlayer.playFullFile("track005.mp3");
default:
Serial.println(F("NOT WORKING"));
delay(100); //This is the delay of the switchcase.
int Signal;
SignalReady = true;
This compiles for me:
There was a duplicate declaration for 'Signal', but removing that made the compiler happy.
BTW - your switch() probably won't behave the way you expect it to.
In C, the switch() statement uses 'fall-through' syntax. As soon as the input matches a case specifier, all the code from there to the end of the switch() statement executes.
For this code:
the output is:
To stop that from happening, you need to add a 'break' statement to the end of each case:
#include <SPI.h>
#include <SD.h>
volatile int P = 512; // used to find peak in pulse wave, seeded
void interruptSetup() {
ISR(TIMER2_COMPA_vect) {
SignalReady = true;
while (1);
musicPlayer.setVolume(05, 05);
//A0 should be BPM
switch (range) {
case 4: // DEAD
default:
For this code:
#include <stdio.h>
int main(int argc, char *argv[]) {
int n = 1;
switch ( n ) {
case 1:
printf( "n = 1 case.\n" );
case 2:
printf( "n = 2 case.\n" );
case 3:
printf( "n = 3 case.\n" );
default:
printf( "default case.\n" );
n = 1 case.
n = 2 case.
n = 3 case.
default case.
#include <stdio.h>
int n = 1;
switch ( n ) {
case 1:
break;
case 2:
break;
case 3:
break;
default:
- stem5
Thank you very much for all your help, we have finally been able to get a functioning code. However, there is only one small problem which we would like to fix. Every thirty seconds, when the pulse sensor checks for our heartbeat, it will restart the track corresponding to the heart beat from the beginning, instead of continuing it from where it had left off. We wanted to know if there was any way to make it "continue" playing instead of just "start" playing. If there is no possible way, it is fine.
Thank you
Stem5
Thank you
Stem5
