Problems with Programming Adruino Uno with Ultimate GPS Logg
khushwant
Post by khushwant »
Problems with Programming Adruino Uno with Ultimate GPS Logger Shield
Dear Sir madam
I can not seam to get the Shield to run the programmer even with the following the instruction Adafruit Ultimate GPS Logger Shield - Includes GPS Module
However I am get a reading when I flick the switch and it works without the chip
How can I get it run with the chip Please help
adafruit_support_rick
Re: Problems with Programming Adruino Uno with Ultimate GPS
Post by adafruit_support_rick »
Please post clear, detailed pictures of both sides of the shield, showing your soldering.
khushwant
Post by khushwant »
Dear Sir
Firstly thanks for your quick reply
I would like to give you some background to what I am trying to do
I am trying to Use a GPS and a 9DOF break out board to see what Happens when I drive my cab in the capital of UK
To measure the speed and look at the direction of the yaw
I have come too Arduino late in life also I am a Cab driver
The picture show the Use of a GPS Shield Uno board and a 9 DOF wired up has shown on your web Page with the addition of the shield
The image file I tried to attach were said by your site to be invalid.
Is there an email to send the pictures
Kas
make sure your image file is png or jpg. The file should be less than 1MB in size. 800x600 is a good size
khushwant
Post by khushwant »
Hi Rick
Thanks for advice on Images.
I have listen to advice and Resized and will also check the connection with Ohm meter.
I enclose the Pic to show my soildering
khushwant
Post by khushwant »
HI Rick
More Pics to help
Thank
Kas
The GPS is not an I2C device. It is a serial device. You need to connect to Digital 8 (TX) and Digital 7 (RX) on the GPS Shield.
khushwant
Post by khushwant »
Hi Rick
Thanks for that
Regards
Kas
