I have a problem on the 1.8 "TFT Adafruit Shield microSD joystick from adafruit.
I have a program but the problem is that the joystick does not work, you can not move while with the joystick test program so it works it does not come to that.
I give you so the program.
Thank you.
problem programing
- adafruit_support_rick
Re: problem programing
Does the joystick work with the adafruit shieldtest example sketch?
Please post clear, detailed pictures of both sides of the shield, showing your soldering.
- Antoine51
Hello ,
Yes the joystick work with the adafruit shieldtest example sketch.
Post your sketch
- Antoine51
Here is the program
- Attachments
- TFT_Shield.zip
- (5.04 KiB) Downloaded 22 times
Are you using an Adafruit shield? The Adafruit Shield reads the joystick on analog 3, and it has a completely different range of values for the joystick positions.
- Antoine51
Yes , I use an Arduino Uno AND That the 1.8 "TFT microSD and joystick from Adafruit
Alright, then you're going to have to change your sketch to read the joystick the same way that our shieldtest example sketch does. I suggest using the same readButton function as the example, and modifying your code to use the symbolic constants for button presses:
#define BUTTON_NONE 0
#define BUTTON_DOWN 1
#define BUTTON_RIGHT 2
#define BUTTON_SELECT 3
#define BUTTON_UP 4
#define BUTTON_LEFT 5
uint8_t readButton(void) {
float a = analogRead(3);
a *= 5.0;
a /= 1024.0;
Serial.print("Button read analog = ");
Serial.println(a);
if (a < 0.2) return BUTTON_DOWN;
if (a < 1.0) return BUTTON_RIGHT;
if (a < 1.5) return BUTTON_SELECT;
if (a < 2.0) return BUTTON_UP;
if (a < 3.2) return BUTTON_LEFT;
else return BUTTON_NONE;
- Antoine51
Hello ,
I get an error when I run the program :
core.a(main.cpp.o): In function `main':
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino/main.cpp:43: undefined reference to `loop'
You don't have a loop function in your sketch.
Yes.
Even if you don't put any code in it, the Arduino sketch environment wants at least:
void loop () {}
- Antoine51
It's good his work! Thank you !
