Hi there,
I am considerably new to electronics, and recently I purchased the CC3000 wifi shield. I have followed the steps from the learning center, and still not able to get my wifi shield started.
I have soldered the Wifi shield according to instructions and mounted it onto the Arduino UNO. Now, I have connected the UNO to my computer USB port, and uploaded the 'build test' sample code from Adafruit's library. However, when I check the serial monitor I get some really weird output.
So, I would like to know if there is a step that I'm missing. When I connect the UNO, the serial monitor just shows 'attempting to connect to.....' and a series of weird characters.
Any help or tips would be much appreciated.
Thank you
Adafruit CC3000 WiFi shield initial setup
- adafruit_support_rick
Re: Adafruit CC3000 WiFi shield initial setup
Please post clear, detailed pictures of both sides of the shield, showing your soldering.
- brunohppl
Hi Rick, thanks for replying.
Here are the pictures of the board:
Hmmm. This is very peculiar. I'm wondering if your computer USB port is not providing enough power. Do you have a 9VDC wall wart you can use to power the Arduino? Or a self-powered USB hub? Something other than the computer USB...
- brunohppl
Yes, I do have a powerBoost 500 charger from Adafruit and a 3.7v/2500mAh battery.
Do you still get the same result using the battery and PowerBoost?
- brunohppl
I have not tried yet, because I don't have the adaptor in order to connect both the computer USB and powerBoost at the same time. I will try in different computers and see if I can get any different result in the meantime.
- brunohppl
It seems to not work on different computers as well. Now, I need to figure out a way to test with an external power supply.
If it still shows that output on the Serial Monitor, do you think I should take it for damaged?
I will need to get another board, but I don't want to waste any money; so just trying to make sure it is really faulty and is it not my setup.
That's not right. Let's try replacing the shield for you. Please email [email protected] with a link to this thread for a replacement CC3000 shield.brunohppl wrote:It seems to not work on different computers as well.
- brunohppl
Ok, thank you Rick.
