I was used the VS1053 breakoutboard and a Auduino Uno to test the Simple Audio Player. I exactly followed the tutorial and soldered all the pins on the board.
https://learn.adafruit.com/adafruit-vs1 ... yer-wiring
when I run the code, it shown the VS1053 found, and Playing Track 001 ... and Done Playing. However it didn't play any music which I putted in the SD card. All my connection is correct, so I thought it probably because of the SD card. After I changed a new, good one, it's still the same.
Does anyone has any idea about this?
Thanks! >~<
Trouble with VS1053 simple test >~<
- adafruit_support_bill
Re: Trouble with VS1053 simple test >~<
Please post photos showing all your soldering and connections to the board.
If it says it was playing track 001, then it must have found the card and the file on it. The problem is most likely on the output side.
- kain leo
Hi thanks so much!! It turned out I connected to a wrong pin number. >~<
I got another problem. I'm testing the Ogg Recorder now. It says "SD failed, or not present". Do you know what's wrong with this?
Actually, I'm not sure about the electronic circuit connection, could you please to help me to check if it's correct? (attached images)
Thanks vary vary much! >~<
- Attachments
- 1.png (569.95 KiB) Viewed 232 times
- kain leo
2
- Attachments
- 2.png (878.75 KiB) Viewed 232 times
- 3.png (670.57 KiB) Viewed 232 times
- kain leo
Is the playback still working? You were able to access the SD card before. Double check that your connections to that are still OK. You may have knocked something loose when wiring up the mic.I got another problem. I'm testing the Ogg Recorder now. It says "SD failed, or not present".
