I´ve been using your 2.8" TFT shield with an Arduino Leonardo successfully both with bmp images and text. However I need to use some specific spanish characters as 'ñ', 'á', '¿', etc...
¿How can I update the font to include those characters?
2.8" TFT -> extended character set
- afcec
- adafruit_support_mike
Re: 2.8" TFT -> special characters
Those are in the extended (higher than 127) values of the GFX library's built-in font. '¿' is character 168, for instance.
It will probably be easiest to write a quick program that prints all 256 character values in a 16x16 grid. The row and column values will give you the hex value for each character you want.
- afcec
Re: 2.8" TFT -> extended character set
Thank you, I finally ended up hacking glcdfont.c. I just changed the pattern values for those characters I am not using. It´s the easiest way and helps you save program memory...
If it works, it works. ;-)
Happy hacking!
Happy hacking!
- DiegoLiedo
Hi afcec, could you point me on how to hack those characters, I'm in need for exactly the same spanish characters.Thank you, I finally ended up hacking glcdfont.c. I just changed the pattern values for those characters I am not using. It´s the easiest way and helps you save program memory...
Thank you .
- afcec
Hi,DiegoLiedo wrote:Hi afcec, could you point me on how to hack those characters, I'm in need for exactly the same spanish characters.Thank you, I finally ended up hacking glcdfont.c. I just changed the pattern values for those characters I am not using. It´s the easiest way and helps you save program memory...
Thank you .
find glcdfont.c which is one of the files included with the library "Adafruit-GFX-Library-master". If you open the file with any editor, you´ll see 255 rows consisting of 5 bytes each. Those 5 bytes represent the pattern for a single character in your font, according to the following criteria:
http://www.instructables.com/id/LED-Sco ... -/?lang=es
In my case, apart from [A-Z], [a-z], [0-9] I just needed [á,é,BANNED,ó,BANNED] so I took these steps:
1. Locate in the file 5 unused characters (in my case 5 characters with code lower than 127) and modify the patterns (yes, draw them) to meet your requirements. For that purpose I used Excel to draw the patterns. It´s a weird at the begginning but you´ll get used to doing it at the second attemp.
2. Once you are finished, remove from glcdfont.c all those characters with ASCII code higher than 127 in case you are not using them. You can save hundreds of precious bytes in program memory.
Give it a try and tell me in case you need any assistance.
- asteroid
For those interested, the following code will print glcdfont character set:
Displays glcdfont character set on 2.8" TFT TouchShield
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_ILI9341.h>
#include <Adafruit_STMPE610.h>
// Default values for Adafruit shield v2.
#define STMPE_CS 8
#define TFT_DC 9
#define TFT_CS 10
Adafruit_STMPE610 ts = Adafruit_STMPE610(STMPE_CS);
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
// Assign human-readable names to some common 16-bit color values:
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
// Rotations 0,2 = portrait : 0->USB=right,upper : 2->USB=left,lower
// Rotations 1,3 = landscape : 1->USB=left,upper : 3->USB=right,lower
const int rotation = 1; //(0->3)
void CharacterGrid()
int row = 16;
int col = 16;
int left, top;
int l = 10;
int t = 0;
int w = 19;
int h = 15;
int hgap = 0;
int vgap = 0;
int id = 0;
for(int j = 0; j < row; j++){
for (int i = 0; i < col; i++){
left = l + i*(w + vgap);
top = t + j*(h + hgap);
tft.drawChar(left, top, id, WHITE, BLUE, 2);
id++;
void setup()
tft.begin();
tft.setRotation(rotation);
tft.fillScreen(BLUE);
CharacterGrid();
void loop()
