Hello
I have a Mega protoshield for Arduino
see: http://www.adafruit.com/product/192
I have place the Protoshield on my arduino Mega 2560
I have place the 3 pin for the jumper as well (so that i can choose between 5 or 3.3V
But i get the shield not working
on the middle rail (+ and the G) I get no voltage there, also the reset button will not work?
What do i wrong
Hope you understand my bad english
i have use this as a setup guide
https://www.youtube.com/watch?v=HjqLomkcnOg
Hope some one could help
here a link to the setup
https://plus.google.com/+AlbertvEe/posts/5wKsXYa5G5g
Mega protoshield for Arduino No volatage on middel rail
- appie21
- adafruit_support_rick
Re: Mega protoshield for Arduino No volatage on middel rail
Have you soldered the header pins?
- appie21
Helloadafruit_support_rick wrote:Have you soldered the header pins?
Did you mean the 3 pins where the jumper is on?
I have not soldered them!
You need to solder all of the pin headers to the proto board.
You don't need to solder the jumper wires.
- appie21
Hi i have tested with my multimeteradafruit_support_rick wrote:You need to solder all of the pin headers to the proto board.
If i place one end in the ground pin (near thr 5.5v) the circuit is closed) (Ok)
if i place the jumper on 5.5v and place one of the wire in 5.5v and the other on the + rail i get no circuit?
I don't have one of these, so I'm not certain, but I don't think the middle rail is connected to anything. You have to jumper it
I have an earlier version of the same board and a jumper was required to power those rails.
- appie21
You mean to place the jumper on 3 .3 and 5v I have place a jumper there but no circuit on the + rail
You need a jumper between 5V and the rail to get 5V on the rail
- appie21
Hi if i do exact the same as on this video https://www.youtube.com/watch?v=HjqLomk ... e=youtu.beadafruit_support_rick wrote:You need a jumper between 5V and the rail to get 5V on the rail
look at 5:44 then i get no beep sound (circuit)
Put one wire of my multimeter on the 5 volt of the jumper and the other rope pin of the multiumeter on the rail +
Not following you. Can you post a picture of the wiring on the proto board?
