Drive multiple twin motor gearbox and solenoid.
sharat471
Post by sharat471 »
Hello, I am building an autonomous system that would use 2 twin gearboxes and a solenoid. What is the best way to control these using arduino? Any advise is appreciated. Thank you.
gearbox 1 - https://www.pololu.com/product/61
gearbox 2 - https://www.pololu.com/product/74
solenoid - http://www.mcmaster.com/#69905k95/=xeyao9
Re: Drive multiple twin motor gearbox and solenoid.
The 3v motors in those gearboxes are a little hard to work with. You can get most H-bridges to sort-of work with them. but the it is hard to speed control is not very precise. And, since they are operating at such a low voltage, they need a lot of current, and the stall current (2.1A) is enough to fry any of the L293D-based motor shields.
These motors are a drop-in replacement, but are designed for 6v operation (double teh voltage means half the current for the same power), so they are a better match for the H-bridges in most of the motor shields. https://www.adafruit.com/product/711
Our V2 motor shield will control all 4 of them. https://www.adafruit.com/products/1438
The Solenoid is best controlled with a power MOSFET and a diode for kickback protection.
https://www.adafruit.com/product/355
https://www.adafruit.com/products/755
Connection is as in the diagram below. Using the MOSFET linked above, the 10K ohm resistor shown is not required.
sharat471
Post by sharat471 »
Is there a way to control the solenoid, arduino and the shield using a single power supply? Thank you.
It is not clear what the operating voltage of the solenoid is. The link you posted has a whole page of solenoids.
In general, you would find a supply that can handle the highest voltage component, and use regulators to reduce the voltage for the other components.
sharat471
Post by sharat471 »
Thank you. The solenoid is - Sealed Linear Solenoid Intermittent, Pull, 24V DC, 1/4" Stroke, 4 oz Force.
I see 24V DC going directly to solenoid and the same stepped down voltage going down to the (arduino+motor shield). What regulator can we use for this?
This would be a good choice. It should have enough power for both the motors and the Arduino.: https://www.adafruit.com/products/1385
Since this is 5v, you can't feed it to the Arduino DC input (i needs 7v -12v). You can feed direct to the Arduino 5v pin. Or, you can cut the "B" end from a USB cable and splice that onto onto the output of the UBEC. Then you can power the Arduino via the USB jack.
sharat471
Post by sharat471 »
Thank you. Any recommendation on the 24v supply adapter I could use?
We do not havre any 24v supplies in the store. You might check with Jameco, or Mouser. You probably want one rated for about 2-3A.
msc_chandu
Post by msc_chandu »
Hello. Is there a solenoid at adafruit that you recommend which is compatible with a suitable power supply available on adafruit.com? Thank you.
msc_chandu
Thank you.
Will this adapter be enough to drive the solenoid and the arduino & shield?
I am planning to use this adapter to drive the solenoid and connect the "UBEC DC/DC Step-Down (Buck) Converter - 5V @ 3A output" to the same. The output of the UBEC will drive the arduino and the shield.
Which shield?
msc_chandu
Hello. The shield is the v2 motor shield - https://www.adafruit.com/products/1438.
I went over the previous communication again; By using a 12V power supply (https://www.adafruit.com/products/352), I can be directly connected to a 12V solenoid, ardruino DC port with v2 motor shield. Is my understanding correct?
If yes, then this should my problem with using single power supply instead of many.
Thank you.
Yes. That should work.
