There is no USPS pickup on Monday Feb 15th, 2016 because of President's Day. USPS orders placed after 11am EST Fri February 12th will go out Tuesday February 16. UPS orders will ship as normal.
Parallax PIR motor control
by keithg on Thu Oct 30, 2008 8:36 pm
I am trying to run small dc motors activated by a Parallax PIR on a Ladyada motor shield. Being less than a novice, I am having some difficulty trying to write a sketch that will accomplish this goal. The PIR is functioning on the Arduino board. Would you please advise how to put these two sketches together? This is our school project that will feature hacked toys that present the word of the week in unique presentations to elementary students. Your help will be appreciated. Thank you.
* //making sense of the Parallax PIR sensor's output
* Switches a LED according to the state of the sensors output pin.
* Determines the beginning and end of continuous motion sequences.
* @author: Kristian Gohlke / krigoo (_) gmail (_) com / http://krx.at
* @date: 3. September 2006
* kr1 (cleft) 2006
* released under a creative commons "Attribution-NonCommercial-ShareAlike 2.0" license
* http://creativecommons.org/licenses/by-nc-sa/2.0/de/
* The Parallax PIR Sensor is an easy to use digital infrared motion sensor module.
* (http://www.parallax.com/detail.asp?product_id=555-28027)
* The sensor?s output pin goes to HIGH if motion is present.
* However, even if motion is present it goes to LOW from time to time,
* which might give the impression no motion is present.
* This program deals with this issue by ignoring LOW-phases shorter than a given time,
* assuming continuous motion is present during these phases.
//VARS
//the time we give the sensor to calibrate (10-60 secs according to the datasheet)
int calibrationTime = 30;
//the time when the sensor outputs a low impulse
long unsigned int lowIn;
//the amount of milliseconds the sensor has to be low
//before we assume all motion has stopped
long unsigned int pause = 5000;
boolean lockLow = true;
boolean takeLowTime;
int pirPin = 3; //the digital pin connected to the PIR sensor's output
int ledPin = 13;
//SETUP
void setup(){
Serial.begin(9600);
pinMode(pirPin, INPUT);
pinMode(ledPin, OUTPUT);
digitalWrite(pirPin, LOW);
//give the sensor some time to calibrate
Serial.print("calibrating sensor ");
for(int i = 0; i < calibrationTime; i++){
Serial.print(".");
delay(1000);
Serial.println(" done");
Serial.println("SENSOR ACTIVE");
delay(50);
//LOOP
void loop(){
if(digitalRead(pirPin) == HIGH){
digitalWrite(ledPin, HIGH); //the led visualizes the sensors output pin state
if(lockLow){
//makes sure we wait for a transition to LOW before any further output is made:
lockLow = false;
Serial.println("---");
Serial.print("motion detected at ");
Serial.print(millis()/1000);
Serial.println(" sec");
delay(50);
takeLowTime = true;
if(digitalRead(pirPin) == LOW){
digitalWrite(ledPin, LOW); //the led visualizes the sensors output pin state
if(takeLowTime){
lowIn = millis(); //save the time of the transition from high to LOW
takeLowTime = false; //make sure this is only done at the start of a LOW phase
//if the sensor is low for more than the given pause,
//we assume that no more motion is going to happen
if(!lockLow && millis() - lowIn > pause){
//makes sure this block of code is only executed again after
//a new motion sequence has been detected
lockLow = true;
Serial.print("motion ended at "); //output
Serial.print((millis() - pause)/1000);
delay(50);
#include <AFMotor.h>
AF_DCMotor motor(2, MOTOR12_64KHZ); // create motor #2, 64KHz pwm
Serial.begin(9600); // set up Serial library at 9600 bps
Serial.println("Motor test!");
motor.setSpeed(200); // set the speed to 200/255
Serial.print("tick");
motor.run(FORWARD); // turn it on going forward
delay(1000);
Serial.print("tock");
motor.run(BACKWARD); // the other way
delay(1000);
Serial.print("tack");
motor.run(RELEASE); // stopped
delay(1000);
keithg
Re: Parallax PIR motor control
by franklin97355 on Thu Oct 30, 2008 10:05 pm
If you have the pir code working do you have the motor code working? When both are working write down a description of what you want to happen like:
1 program starts and waits for pir to stabilize
2 pir waits for movement
3 motor activated
4 motor stops
5 program loops to top
This will let you write code that will accomplish those tasks.
franklin97355
by keithg on Thu Oct 30, 2008 10:13 pm
Thanks for the advise. The pir is working but the motor is not responding to:
delay(1000);
delay(1000);
delay(1000);
keithg
by adafruit on Thu Oct 30, 2008 11:13 pm
well you should get the motor shield working first
do any of the motors work?
post a photo of the setup WITHOUT the PIR sensor
