My objective: To save and then retrieve lat long coordinates that work well with Google Maps. The NMEA data I'm getting is not working at all in your LOCUS Parser.
When I run "File-->Examples-->Adafruit-GPS-->parsing" or
When I run "File-->Examples-->Adafruit-GPS-->locus-start",
I get garbage data when I run locus-dumpbasic.
The sentences include a bunch of FFFFFFF's and typos and the LOCUS Parser cannot read them (https://learn.adafruit.com/custom/ultimate-gps-parser_
However, when I run File-->Examples-->Adafruit-GPS-->parsing, I get great, accurate data in the serial monitor:
[Example:
Time: 7:46:38.0
Date: 28/6/2015
Fix: 1 quality: 2
Location (in degrees, works with Google Maps): 45.5548, -122.6138]
All I want to be able to do is to log this Google-map-friendly information once I unplug my Ultimate GPS from my computer and take it around town. Then I want to retrieve it with a locus_basicdump into my serial monitor. Please help! I've been trying to fix this for weeks. Thank you.
-D
Ultimate GPS Locus_Dumpbasic sending bad data
- Dgt211
- adafruit_support_rick
Re: Ultimate GPS Locus_Dumpbasic sending bad data
You need to manually delete the extra FFFFFFFF lines with a text editor.
- Dgt211
Thank you for your prompt response. As can be seen from the data (pasted below), it is not just a problem with a lot of FFF's, but also garbled "PMTKLOX" phrases.
After taking the GPS out for a spin, is there anyway to just dump the latitude, longitude coordinates (such as those that appear in the serial monitor when running "File-->Examples-->Adafruit-GPS-->parsing") instead of this LOCUS parsing data? It is curious that the module appears to be working when I run "parsing" but not after I run "locus_start" and then "locus_dumpbasic".
Here is an example of what I get:
ZÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿþÿÿÿÿÿÿÿñAdafruit GPS logging start test!
$PMTKLOX,0,1852
$PMTKLOX,,,0100010A,1F0000,0F000000,00100A,0000000,0000000,000000,00000000,000000,00000000,000000,0000001,FFFFFFF,FFFFFF,FFFFFFFF,00CC46E9C8F55,043336,423D3AF5,260024,7D9C8F5,4323836,423C3F,C2460036*26
$MTKLOX,1,1,8CCF55,0432383643C3AF5,C246007A9C8F55,0432386423D3AF5,C2460E,B39C8F55,045836,42383AF5C4600FB,C29C8F504343836,423AA5,C245008A,D1CF55,04323836,2A3AF5,C24600CE09C8F55,043186,423B3AF5,C260AF*5F
$PMTKO,1,2,EF9C8F5,4313836,423B3F,C24600A0,FE9855,04313836,433AF5,C24600B109D8F55,043233,423B3AF5,C24040,1C9D8F55,033836,423B3AF5C460052,2B9D85,04313836,4233F5,C2460065,398F55,0431383643B3AF5,C2450075C
$PMTKLOX13,499D8F55,041836,423B3AF5,250004,589D8F5,4313836,423A3F,C2440015,67DF55,04313836,2A3AF5,C244002,69D8F55,043133,423A3AF5,C2403B,859D8F55,413836,423A3AF,24400C8,949D85,04323836,4233F5,C24400DA*2
$PMTKLOX,1,4A9D8F55,0431386423B3AF5,C2440F,B29D8F55,045836,423C3AF5,2200FB,C19D8F504383836,423DA5,C2430085,D0DF55,04373836,2D3AF5,C24400CDF9D8F55,043786,423D3AF5,C24093,EE9D8F55,473836,423D3AF,24400A2*58
PTKLOX,1,5,FD9855,04373836,433AF5,C24400B009F503836,42393AF5,230042,1B9E8F504343836,4237A5,C242005B,2AEF55,04333836,273AF5,C242006,99E8F55,023086,423B3AF5,C22077,489E8F55,293836,42393AF,242001D*24
$MKLOX,1,6,579855,02263836,433AF5,C242000E69E8F55,0226386423D3AF5,C24208,759E8F55,02A836,423C3AF5,220026,849E8F5022B3836,423CA5,C24200D6,93EF55,022B3836,2D3AF5,C24200C,29E8F55,022C33,423E3AF5,C220F5*25
$PMTKO,1,7,B19E8F5502C3836,423E3A5C24200E6,C09EF5,022C3836,433AF5,C2420097C9E8F55,022C386423D3AF5,C2420B,DE9E8F55,02D836,423A3AF5C41008F,ED9E8F5022D3836,4239A5,C24100BF,FCEF55,022D3836,293AF5,C24100A*6
$PMTKLOX,,,0B9F8F55,022336,42393AF5,C40058,1A9F8F5502D3836,42393A5C2410049,299855,022E3836,433AF5,C241007939F8F55,022E38642393AF5,C24108,479F8F55,02E836,42393AF5C410017,569F8F5022E3836,4239A5,C2410006*52
PMTKLOX,1,9,698F55,022E383,2393AF5,C24103,749F8F55,022336,42393AF5,C40024,839F8F5502E3836,42393F,C24100D3,929855,022E3836,433AF5,C24100C2A9F8F55,022F386423A3AF5,C24103,B09F8F55,023836,423A3AF5C4100E2*57
$PTLOX,1,10,BF9FF5,02313836,42AAF5,C24100F3C9F8F55,023A38642383AF5,C2410B,DD9F8F55,02A836,42393AF5,210099,EC9F8F5,43E3836,423AA5,C24300AB,FCFF55,02053836,2F3AF5,C244009,BA08F55,022E33,42303AF5,C2306F*16
$PMTKO,1,11,1AA08F5,2273836,42363F,C2430071,29A855,02263836,433AF5,C243004,8A08F55,022633,423B3AF5,C2405F,47A08F55,023836,423A3AF5C430022,56A085,02283836,4233F5,C2430033,6A8F55,022B38364363AF5,C24300213
$PMTKLOX,,2,86A08F55,023836,423B3AF5C4300EC,95A08F502423836,4226A5,C243008B,A40F55,024138364243AF5,C24300BB3A08F55,02428642213AF5,C240AA,C2A08F55,043836,42223AF,24300D8,D1A085,02403836,4223F5,C24300CE*6
$PMTKLOX,1,13EA08F55,0235386422C3AF5,C24083,EFA08F55,023836,42323AF5C40AFA08F55,022D38642343AF5,C2409D,0DA18F55,023836,42363AF5C43006F,1CA18F5023836,42363AF,243007A,2BA185,02263836,4233F5,C243004C*5
$PMTKLOX,1,1,AA18F55,022A33,423A3AF5,C24051,49A18F55,023836,42373AF,243002B,58A185,022E3836,4233F5,C2430034,6A8F55,0231383643A3AF5,C24300776A18F55,023336,42383AF5,C40005,85A18F550313836,42383A5C24300F7*6D
PTKLOX,1,15,9A8F55,023638364343AF5,C24300DA3A18F55,023C86,42323AF5,C230D6,B2A18F55,283836,42313A5C24300C0,C1A1F5,02383836,420AF5,C24300B2,018F55,042B383,2333AF5,C24402,DFA18F55,04D836,423D3AF5,260087*6A
$PMKOX,1,16,EEA185,041F3836,42FAF5,C24700B7,D18F55,041E383,23F3AF5,C2470A,0CA28F55,041336,42403AF5,C4002A,1BA28F5,41C3836,42403F,C247003D,2AA855,041D3836,443AF5,C247000C3A28F55,041E38642413AF5,C2401C*12
$PMTKLX1,17,48A28F5501E3836,42433A5C247006F,57A2F5,04203836,443AF5,C247004F6AF502864423AF5,C24707,75A28F55,041336,42453AF5,C40055,84A28F5,41D3836,42453F,C24700A6,93A855,041D3836,443AF5,C24700B11
$PMTKLOX,11,A2A28F55,041336,42443AF5,C40081,B1A28F550213836,42423A5C24700A8,C0A255,04223836,443AF5,C24700D9CAF55,0425383643F3AF5,C2470A,DEA28F55,042336,423D3AF5,C400B2,EDA28F550293836,423D3A5C2470083*18
$MTKLOX,1,19,FA8F55,042B38364373AF5,C2480050BA38F55,042C86,42353AF5,C27069,1AA38F5502B3836,42333A5C2470079,29A3F5,042A3836,423AF5,C24800443A38F55,042A38642343AF5,C24802,47A38F55,047836,42383AF5,29002D*62
$PMKOX,1,20,56A385,04293836,425AF5,C24A003C,538F55,042B383,2343AF5,C24A00,74A38F55,04A836,42363AF5,2A001E,83A38F5,4293836,42363F,C24A00EA,92A855,04273836,433AF5,C24A00F,1A38F55,042733,42383AF5,C240C8*6E
$PMTKLX1,21,B0A38F550263836,423A3A5C24A00DA,BFA855,04253836,433AF5,C24A00D5CA38F55,0423386423A3AF5,C240A1,DDA38F55,023836,423B3AF5C4A00B3,ECA38F504203836,423BA5,C24A0081,FB3F55,0420383643D3AF5,C24A00012
$PMTKLOX,,2,0AA48F55,044836,423C3AF5,2A0063,19A48F504283836,423DA5,C24A007D,284F55,04293836,2D3AF5,C24A004,7A48F55,042986,423F3AF5,C2A050,46A48F55,493836,42413AF,24A005F,55A485,04293836,4243F5,C24A004F*5
$PMTKLOX,1,2,4A48F55,042833,42443AF5,C24079,73A48F55,023836,42423AF,24A0064,82A485,04213836,4243F5,C24A0091,9A8F55,042138364463AF5,C24A007A0A48F55,042336,42473AF5,C400B4,AFA48F550243836,42483A5C24A00B2*10
PTKLOX,1,24,BA8F55,0220383643E3AF5,C24700ACDA48F55,021B86,42393AF5,C2909B,DCA48F550223836,42373A5C24A00BE,EBA4F5,02243836,427AF5,C24A008F,A48F55,02243864363AF5,C24A09,09A58F55,022336,42373AF5,C4006D*6E
$PMTLX,1,25,18A58F502243836,4238A5,C2490071,2A8F55,022538364383AF5,C24900F36A58F55,022586,423A3AF5,C290C55F,253836,423B3A5C249002E,54A5F5,02243836,42BAF5,C249003E6A58F55,042538642393AF5,C2490C*6D
$PMTKLO,,26,72A58F55,403836,42393A5C2490008,81A5F5,04323836,42CAF5,C24900FC,058F55,042F383,23C3AF5,C24900,9FA58F55,04B836,423D3AF5,2900FA,AEA58F5,42C3836,423E3F,C24900CF,BDA855,042A3836,2E3AF5,C24900D*1
$PMTKLOX,12,CCA58F55,042336,423E3AF5,C400A9,DBA58F5,4273836,423F3F,C24900B0,EAA855,04243836,443AF5,C24900FCFA58F55,042538642413AF5,C240EE,08A68F55,023836,42413AF5C49001D,17A68F504243836,4241A5,C2490002*6
$PMTKLOX,1,282A68F55,042238642413AF5,C24905,35A68F55,042836,42413AF5C490026,44A68F504233836,4242A5,C2490055,536F55,04223836,233AF5,C249004,2A68F55,042786,42413AF5,C29074,71A68F55,413836,42413AF,2490061*62
$MKLOX,1,29,80A855,041F3836,213AF5,C24900A,FA68F55,041E33,42413AF5,C240A0,9EA68F55,013836,42403AF,24900B3,ADA685,433,33FC24900FC,BC6F55,04223836,2F3AF5,C24900D,BA68F55,042433,42403AF5,C240DF*1E
$PMTKO,1,30,DAA68F5,4273836,423F3F,C24900B2,E9A855,04283836,2F3AF5,C249008,8A68F55,042833,423E3AF5,C2409E,07A78F55,023836,423D3AF5C49006C,16A78F504253836,423CA5,C249007E,257F55,0421383643A3AF5,C24900F69
$PMTKLOX,,1,34A78F55,04E836,423A3AF5,290061,43A78F5,41D3836,4239A5,C2490016,527F55,041E3836,2A3AF5,C249000,1A78F55,041B33,423A3AF5,C29031,70A78F55,4A3836,423A3AF,2490021,7FA785,04183836,4233F5,C248002C*E
$PMTKLOX,1,3,EA78F55,041733,423B3AF5,C240D2,9DA78F55,013836,423C3AF5C4800C2,ACA78F504133836,4233F5,C24800F2,BA8F55,0412383643D3AF5,C248004CAA78F55,041336,423F3AF5,C40094,D9A78F550143836,423F3A5C2480082*10
PTKLOX,1,33,E87F55,04133836,2F3AF5,C248004F7A78F55,041486,423D3AF5,C280AE,06A88F55,433836,423D3A5C2480057,15A8F5,04133836,42DAF5,C2480044,488F55,0413383,23E3AF5,C24807,33A88F55,044836,423F3AF5,280067*11
$PMKOX,1,34,42A885,04143836,4233F5,C2480017,188F55,0417383,23D3AF5,C24800,60A88F55,041336,423D3AF5,C40035,6FA88F5,4193836,423E3F,C2480037,7EA855,041A3836,433AF5,C24800268A88F55,041533,423F3AF5,C240D8*16
$PMTKLX1,35,9CA88F550113836,423E3A5C24800CC,ABA855,04143836,433AF5,C24800FEBA88F55,0413386423E3AF5,C24808,C9A88F55,044836,423C3AF5C48009E,D8A88F504153836,423AA5,C2480088,E78F55,041338364383AF5,C24800368
$PMTKLOX,,6,F6A88F55,046836,42353AF5,2800AA,05A98F5,4273836,4233A5,C248006F,149F55,042D3836,2B3AF5,C248007,3A98F55,042F33,423C3AF5,C2804E,32A98F55,4C836,423F3AF5C48005F,41A98F5042B3836,423FA5,C248002B*69
PMTKLOX,1,37,098F55,042C386423F3AF5,C2480D,5FA98F55,041836,423B3AF5,28002B,6EA98F5,4303836,423A3F,C248001A,7D9F55,042E3836,2C3AF5,C248001,CA98F55,042C33,423B3AF5,C240E5,9BA98F55,4A3836,423B3AF,24800F4*6C
$MKLOX,1,38,AAA855,04313836,433AF5,C24800DCBA98F55,043233,423B3AF5,C240CE,C8A98F55,023836,42403AF5C4800D9,D7A98F504273836,4243F5,C24800CA,EA8F55,042238364483AF5,C24700DF5A98F55,042286,424B3AF5,C270ED*1A
$PMTLX,1,39,04AA8F504203836,424EA5,C2470018,13AF55,042A3836,2B3AF5,C24700022AA8F55,043986,424A3AF5,C26022,31AA8F55,483836,423C3AF,2460046,40AA85,04373836,428AF5,C245003F,FA8F55,0437383,2393AF5,C24503*1F
$PMTKLOX140,5EAA8F55,033836,42373AF,245002A,6DAA85,04323836,4233F5,C245001A,7A8F55,043038364333AF5,C24500,8BAA8F55,042336,42313AF5,C400E5,9AAA8F550323836,422E3A5C24500F6,A9AAF5,04333836,423AF5,C24500C41
$PMTKLOX,1,1CCAA8F55,043286,422E3AF5,C250A0,DBAA8F5502E3836,42323A5C24500B7,EAAAF5,04343836,427AF5,C2450099,9A8F55,043C383,2373AF5,C245020BF54E8,2FF,2450078,17AB85,04433836,4243F5,C2450066*6
$PMTKLOX,1,422AB8F55,044738642453AF5,C24055,35AB8F55,043836,42433AF5C450041,44AB8F504493836,4241A5,C245003D,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFF0200010A,1F0000,0F000000,00030A,00000000,000000,0000000,0000000*11
PTKLOX,1,43,000000,00000000,000000,0000001,FFFFFFF,FFFFFF,FFFFFFFF,00CC14,53AB8F55,4E3836,42403AF,245002C,62AB85,04423836,4243F5,C2450010,7A8F55,043A383,23F3AF5,C24500,80AB8F55,043336,423F3AF5,C400F5*6A
$PMTLX,1,44,8FAB85,043A3836,4233F5,C24500F9,9A8F55,043A38364393AF5,C24500CADAB8F55,043936,42373AF5,C400D2,BCAB8F550343836,42363A5C24500CF,CBABF5,04303836,427AF5,C24500BDDAB8F55,042B38642393AF5,C24509*11
$PMTKLO,,45,E9AB8F55,483836,423B3A5C245008B,F8ABF5,04253836,42BAF5,C2450097,7C8F55,0422383,23C3AF5,C24506,16AC8F55,040836,423A3AF5,25007A,25AC8F5,41E3836,42363F,C245007B,34CF55,041B3836,2A3AF5,C246006*4
$PMTKLOX,14,43AC8F55,041336,423A3AF5,C40011,52AC8F5,41E3836,423A3F,C2460003,61A855,041F3836,433AF5,C24600327AC8F55,042033,423A3AF5,C2401F,7FAC8F55,013836,423A3AF5C46002F,8EAC8F5041F3836,423BA5,C24600DF*6
$PMTKLOX,1,479AC8F55,041B386423B3AF5,C24608,ACAC8F55,04B836,42393AF5,2600FB,BBAC8F5041A3836,4239A5,C24600ED,CACF55,04163836,293AF5,C246000D9AC8F55,041186,42383AF5,C26085,E8AC8F55,403836,42383AF,24600B5*16
$MKLOX,1,48,F7CF55,04133836,283AF5,C24500A,6AD8F55,041033,42383AF5,C24059,15AD8F55,4E3836,42383AF,2460057,24AD85,040E3836,4233F5,C2460066,3A8F55,040C383,2393AF5,C24607,42AD8F55,04033,42383AF5,C26003*1D
$PMTKO,1,49,51AD8F5,40F3836,4238A5,C2460012,60DF55,04113836,273AF5,C246003,FAD8F55,041733,42383AF5,C24034,7EAD8F55,493836,42363AF,2460015,8DAD85,042F3836,4233F5,C24600E3,9A85033643AF5,C24600E8*1
$PMTKLOX,1,0ABAD8F55,043486,42373AF5,C260DC,BAAD8F55,453836,42393AF,24600C2,C9ADF5,04373836,427AF5,C24600BD,8D8F55,043A383,2393AF5,C2460F,E7AD8F55,048836,42393AF5,260092,F6AD8F5,4363836,42383F,C246008C*16
$MTKLOX,1,51,5E8F55,0431383,2393AF5,C24607,14AE8F55,043336,42393AF5,C40068,23AE8F5,4343836,42383F,C2460058,32A855,04323836,433AF5,C246004E4AE8F55,043033,423A3AF5,C2403C,50AE8F55,023836,423A3AF5C460036*6A
$PTLOX,1,52,5FA855,042C3836,433AF5,C245003D6AE8F55,042B386423B3AF5,C2450A,7DAE8F55,04C86,42393AF5,C2501C,8CAE8F55,493836,42363A5C24500E7,9BAEF5,04273836,424AF5,C24400FD,AE8F55,0429383,2333AF5,C24405*10
$PMTKLO,,53,B9AE8F55,493836,42333AF,24400D6,C8AE85,04273836,422AF5,C24400A8,7E8F55,0429383,2303AF5,C2440B,E6AE8F55,042336,42313AF5,C4008A,F5AE8F5,4263836,42323F,C2440094,04A855,04273836,433FC405*68
$PMTKLO,,54,13AF8F550273836,42333A5C2440073,22AFF5,04283836,424AF5,C244004A,1F8F55,042A383,2343AF5,C2440B,40AF8F55,04C836,42343AF5,24002C,4FAF8F5,42C3836,42353F,C2440022,5EA855,042A3836,243AF5,C244003*6
$PMTKLOX,15,6DAF8F55,042336,42353AF5,24000B,7CAF8F5,4253836,42363F,C244001B,8BA855,04243836,433AF5,C24400EC9AF8F55,0240386423C3AF5,C24095,ACAF8F55,033836,42373AF5C4200DE,BBAF8F5022A3836,4237A5,C24300D3*1
$PMTKLOX,1,56CAF8F55,022A38642353AF5,C24300,D9AF8F55,02C836,42353AF5,2300B5,E8AF8F502283836,4234A5,C2430081,F7FF55,02243836,233AF5,C24300506B08F55,042486,42353AF5,C2307B,15B08F55,453836,42353AF,2420068*6B
$MKLOX,1,57,240F55,04223836,253AF5,C242005,3B08F55,042533,42353AF5,C2404E,42B08F55,023836,42363AF,242003B,51B085,04263836,4233F5,C2420020,6B8F55,042B383,23C3AF5,C24201,6FB08F55,043336,423E3AF5,C4000B*6E
$PMTLX,1,58,7EB08F,043D3836,4243F5,C240006F,8B8F55,043638364403AF5,C23F00B9CB08F55,042A86,42393AF5,C309F,ABB08F55,4B3836,42363AF,23F00A6,BAB085,04233836,4233F5,C23F00B1,908F55,0432383,23A3AF5,C23E0D*65
$PMTKLOX159,D8B08F55,043836,423E3AF,23D00B1,E7B085,04593836,4243F5,C23B00E2,FB8F55,045738364493AF5,C23C00B05B18F55,045336,42473AF5,C3000C,14B18F5505C3836,42473A5C23B001A,23B1F5,04543836,443AF5,C23C00206
$PMTKLOX,1,032B18F55,045486,42453AF5,C2C031,41B18F55,443836,42443A5C23C0043,50B1F5,044B3836,422AF5,C23D004A,F18F55,044838642423AF5,C23D06,6EB18F55,04C836,42413AF5,2D0070,7DB18F5,4423836,42413F,C23E006E*11
PMTKLOX,1,61,C18F55,0436383,23D3AF5,C23F09,9BB18F55,043336,423C3AF5,C30083,AAB18F5,4343836,423C3F,C23F00B3,B9B855,04323836,433AF5,C23F00A1CB18F55,0431386423B3AF5,C230D3,D7B18F55,023836,423B3AF5C3F00D2*6D
$PTL,,2E18F55,042E383,23B3AF5,C23F0E,F5B18F55,042336,423C3AF5,2F00F7,04B28F5,42D3836,423C3F,C23F0007,13B855,042F3836,433AF5,C23F00152B28F55,042833,42383AF5,C23021,31B28F55,023836,42363AF5C3E003C*11
$MKLOX,1,63,40B855,04283836,433AF5,C23E004E4B28F55,042038642363AF5,C23D09,5EB28F55,049836,42373AF5C3D0070,6DB28F5040D3836,4236A5,C23C0047,7C2F55,041038364363AF5,C23C00B8BB28F55,041786,42353AF5,C2C0B8*16
$PMTKO,1,64,9AB28F5,4173836,4234A5,C23C00A8,A92F55,04103836,233AF5,C23B009,8B28F55,040333,42313AF5,C2309E,C7B28F55,4D76,423A3AF5,C2901B,D6B28F550023836,423A3A5C23800FB,E5B2F5,040B3836,425AF5,C23800CE*3
$PMTKLOX,1,5F4B28F55,040A86,42323AF5,C270D6,03B38F55,443836,42323AF,237003E,12B385,04163836,424AF5,C237002B,138F55,0417383,2353AF5,C23601,30B38F55,04F836,42313AF5,260004,3FB38F5,4253836,42313F,C2360031*12
$MTKLOX,1,66,4B8502364343AF5,C23604,5DB38F55,042336,42333AF5,C30050,6CB38F550213836,42383A5C236006F,7BB855,04233836,433AF5,C23600758B38F55,041F386423A3AF5,C23605,99B38F55,023836,423B3AF5C360098*6C
$PTLOX,1,67,A8B3F5,04213836,42BAF5,C23600A8,738F55,0420386423E3AF5,C23603,C6B38F55,042836,423A3AF5,2600C4,D5B38F5,42E3836,423CA5,C23600DD,E43F55,042E3836,2F3AF5,C23600E,3B38F55,042D33,42413AF5,C23085*16
$PMTKO,1,68,02B48F5,41F3836,42453F,C2360045,11B855,041D3836,443AF5,C235005,0B48F55,041133,423F3AF5,C23013,2FB48F55,013836,423E3AF5C360019,4BB485,04203836,4233F5,C236004D,5B8F55,043038364323AF5,C23A00964
$PMTKLOX,,9,70B48F55,033836,42303AF5C3A0067,7FB48F5042B3836,4231A5,C23B0075,8E4F55,042B38364313AF5,C23B0049DB48F55,042B86,42313AF5,C2B097,B5B48F5502B3836,42313A5C23B00BF,C4B4F5,04213836,421AF5,C23E00C1*5
$PMTKLOX,1,0D3B48F55,042186,42313AF5,C2E0D6,E2B48F55,413836,42313AF,23E00E7,F8B4F5,04213836,421A5C23E00FD,07B855,04203836,433AF5,C240007F2239255,024633,42433AF5,C260E1,35239255,043836,423F3AF5C65008F*6F
$PTLOX,1,71,442955,02423836,443AF5,C26500845239255,023F38642413AF5,C2640E,75239255,02A836,42303AF5C6300BB,842392502213836,4239A5,C264005F,933255,02203836,2E3AF5,C264004,2239255,022186,423D3AF5,C2407D*6E
$PMTKO,1,72,9E24925,2673836,42363F,C264000B,AD4255,022B3836,2D3AF5,C264007,C249255,023633,423D3AF5,C26073,CB249255,033836,423D3AF,2640008,DA2495,02363836,4233F5,C2640014,E29255,0232383,23B3AF5,C26402*10
$PMTKLOX173,1C259255,023836,423B3AF5C6400CC,2B25925022E3836,423CA5,C26400FC,429255,0230383643C3AF5,C26400F55259255,022986,42413AF5,C200FF,642592550283836,42423A5C26300CC,732525,02253836,424AF5,C26300D0*5
$PMTKLOX,1,7,2259255,021C86,42483AF5,C2205152,2636,423E3AF5,C6004C,A02592550223836,423F3A5C2640078,AF2525,02213836,42FAF5,C2640074B259255,0220386423F3AF5,C26404,CD259255,02D836,42403AF5,240055*6D
$PTLOX,1,75,DC2525,021B3836,421AF5,C2640043,B59255,021B383,2433AF5,C26407,FA259255,02B836,42463AF5,230065,0926925,2153836,42493F,C2630094,182955,02153836,283AF5,C262008,7269255,041633,42463AF5,C2508C*13
$PMTKLX1,76,3F26925,4163836,424C3F,C25E009F,4F2955,02163836,433AF5,C25D009F6269255,020038642373AF5,C250A4,7B269255,013836,423E3AF5C5C00A9,8A2692502163836,423FA5,C25C005D,929255,0217383643F3AF5,C25C00F14
$PMTKLOX,,7,A8269255,028836,42403AF5C5C000E,B72692502183836,4240A5,C25C0011,C66255,02183836,203AF5,C25C006,5269255,041886,42403AF5,C2C075,E4269255,493836,423F3AF,25B003D,F32695,041A3836,42FAF5,C25A0028*5
$PMTKLOX,1,7,2279255,041A33,423E3AF5,C250D9,11279255,01334335,C25A00CA,079255,041A383,23E3AF5,C2590F,2F279255,041336,423F3AF5,2800F7,3E27925,41A3836,423F3F,C25800E6,4D2955,04233836,433AF5,C24F00B*A
$PMTKLOX,17,5C279255,042336,423C3AF5,C400AA,6B2792550233836,423C3A5C24B009A,7A2955,04233836,433AF5,C24B008B8279255,0423386423B3AF5,C24B0F,98279255,042836,423B3AF5C4B006F,BA2792504223836,423BA5,C24B004D*62
PMTKLOX,1,80,979255,0423386423A3AF5,C2480D,D8279255,042836,423A3AF5,28002D,E727925,4223836,423AA5,C2480012,F67255,04223836,2A3AF5,C248000,5289255,042233,423A3AF5,C280FF,14289255,423836,423A3AF,24700E1*1F
$MKLOX,1,81,232955,04223836,2A3AF5,C24700D,2289255,042233,423A3AF5,C240C7,41289255,023836,423A3AF5C4700B4,502895,04223836,4233F5,C24700A5,529255,0422383643A3AF5,C24700A6E289255,042336,423A3AF5,C4009B*1E
$PMTLX,1,82,7D2892504223836,423AA5,C2470088,8C8255,042138364335C407A,9B289255,413836,423A3A5C247006D,022C25,02313836,424AF5,C24C00E3,1C9255,022D38642343AF5,C24A0A,202C9255,028836,42343AF5,2B00DF*64
$PMKOX,1,83,2F2C95,02283836,424AF5,C24B00D0,EC9255,0229383,2333AF5,C24A0C,4D2C9255,022336,42323AF5,2A00B6,5C2C925,22A3836,42333F,C24A00A7,8C2955,02163836,433AF5,C24A004,B2C9255,020833,42333AF5,C24042*65
$PMTKLX1,84,AA2C92550093836,42333F,C24A0072,B92955,020C3836,433AF5,C24A0063C2C9255,021138642333AF5,C2490B,D72C9255,013836,42333AF5C490014,E62C92502113836,4235A5,C2490023,F29255,021038364353AF5,C2490011F
$PMTKLOX,,5,042D9255,02E836,42353AF5,2900DF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,03010A,1F000000,F00000,0000120,0000FFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,00FC8C1C*0
$PMTKLOX,1,8,32D9255,021133,42363AF5,C240D4,222D9255,013836,42373AF5C4900ED,312D95,021C3836,4233F5,C24900FB,429255,021E38364363AF5,C2490084F2D9255,021336,42363AF5,C40084,5E2D925501F3836,42363A5C2490097*1B
PTKLOX,1,87,629255,022338364383AF5,C2490067C2D9255,022486,42373AF5,C2908F,8B2D92550263836,42383A5C2490075,9A2D25,02273836,428AF5,C2490065,9D9255,022838642383AF5,C24909,B82D9255,028836,42383AF5,290048*18
$PMKOX,1,88,C72D95,02283836,429AF5,C2490036,6D9255,0228383,2383AF5,C24902,E52D9255,022336,42383AF5,29015,F42D9255,2A3836,42383A5C2490006,032E25,02293836,42AAF5,C24900F3,2E9255,022C383,23A3AF5,C2490E*6A
$PMTKLO,,89,212E9255,2C3836,42393AF,24900D7,4E2E95,02303836,4233F5,C24900A6,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF1
$PMTKLOX,1,0FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF*61
$PMKOX,1,91,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF*60
$PMTKLX1,92,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF*3
$PMTKLOX,,3,FFFFFFFF,FFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF*62
PTKLOX,1,94,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF6
$PMTKLOX,1,5FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF*64
PMTKLOX,1,96,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF*67
$MKLOX,1,97,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF*66
$PMTKLOX198,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFF,FFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF*69
$PMKOX,1,99,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF*68
$PMTKLX1,100,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFF59
$PMTKLOX1101,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF5
$PMTKLOX,112,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFF*5B
$PMTKLOX1103,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF*A
$PMTKLOX,114,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF*5D
PMTKLOX,1,105FFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF*5C
PTKLOX,1,106,FFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFF,FFFFFF,FFFFFFFF*5F
PMTKLOX,1,107FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF*5E
PTKLOX,1,108,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF*51
$MKLOX,1,109,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF*50
$PMKOX,1,110,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF*58
$PMTKO,1,111,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF*59
$PMTKLO,,112,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFF5A
$PMTKLOX,,1,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF*5B
PMTKLOX,1,114FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF*5
$PMTKLOX,1,11,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF*5D
$MTKLOX,1,116,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF*5E
$MKLOX,1,117,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF*5F
$PMKOX,1,118,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF*50
$PMTKO,1,119,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF*51
$PMTKLO,,120,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF5
$PMTKLOX,1,2,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF*5
$PMTKLOX,1,12,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF*59
PTKLOX,1,123,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF*58
$PTLOX,1,124,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF*5F
$PMTLX,1,125,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF*5E
$PMTKLX1,126,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFF,FFFFFFFF,FFFFFF,FFFFFFF,FFF,FFF,FFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF*5D
PTKLOX,1,127,FFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFFF,FFFFFFFFFFFFFFF,FFFFFF,FFFFFFFF,FFFFFF,FFFFFFFFFFFFFF*5C
$PMTKLO,2*4
$M016,*6
You want the PMTKLOX stuff. Each line is a formatted sentence containing the track data.
The problem is that your sentences are garbled - they are missing characters. You may have some wiring or assembly issues with your GPS that are causing you to drop characters.
Can you post some clear pictures of your both sides of your GPS and wiring?
What kind of Arduino are you using?
Are you running the locus_dumpbasic sketch unmodified?
- Dgt211
I got the answer! I knew it wasn't my soldering since I was getting perfectly good data while running "parsing" and "locus_start". The problem was that I needed to update to a new version of Arduino IDE. Once I got the latest version, locus_dump works perfectly!! finally!!! oh I wish someone would've told me this months ago.
