PN 532 with RGB LCD.
Re: PN 532 with RGB LCD.
Is that with the RGB LCD shield installed?
- hankbern
Now that the real monitor got a response from ASCII Table, is there something I can do next?
- hankbern
Sorry, I did not notice that we are on page2. To answer your question, yes that is with the RGB LCD installed.
OK. That means that there is no short circuit or other fault on the shield that is preventing the Arduino from running at all.
But if you are still not seeing any Serial Monitor output from the i2cscanner, there must be something on the shield that is keeping i2cscanner from running. That probably means some soldering or assembly issue with the i2c port expander chip. Is it possible to get some sharper photos showing the chip?
One thing that helps for good photos is plenty of light. If you put the board near a window or even take it outside you may get better results.
- hankbern
I have taken photos in sunlight with a digital camera, but the file size is too large to transmit with this means. I have taken more photos with the on board camera on my computer with additional light using anLED flashlight. I am not too hopeful that they will show more detail.
- RGB731 - 1 (1).jpg (127.57 KiB) Viewed 282 times
- hankbern
- hankbern
- RGB731 - 1 (2).jpg (124.96 KiB) Viewed 280 times
- hankbern
- RGB731 - 1 (3).jpg (131.26 KiB) Viewed 280 times
- hankbern
You should be able to re-size them to keep them under 1 megabyte. 800x600 is a good size for posting.the file size is too large to transmit with this means.
From what I can see, the chip is positioned correctly. But a clearer look at the solder would be helpful.
- hankbern
Thanks, those are much clearer. Your soldering on the chip looks fine. The solder joints on the header pins for 5v and GND have not flowed well onto the solder pads. There are a few on the top-side of the display header that look a little suspect as well.
- hankbern
When you say header pins for 5v and GND, do you mean the highlighted pins?
- RGB - 1 (4)x.jpg (66.6 KiB) Viewed 205 times
Yes, those two and the one to the right of them also.
- hankbern
I have attempted to repair the pins noted plus any others that appeared to be in question. I am able to repeat the serial monitor output for the ASCII Table. But when I try Hello World I get the same empty blocks.
