Has anyone else experienced this issue?
I was running 2 moon 17HD steppers, when I heard a crackle, looked over to the controller, and saw smoke come out of it. I immediately cut power.
I don't see any damage, but my power supply won't get it past 3 volts before it wants to spike to 2A.
The UNO is fine. It was not powering the board.
Thoughts?
I was planning on ordering another board so I can run three steppers for my project, but I'm a little concerned now.
D
Motorshield v2.3 cooked out at 5vdc / 1.9A!
- problah
Re: Motorshield v2.3 cooked out at 5vdc / 1.9A!
Upon inspection, it looks like the TB435A1 for Stepper 2 has a wart in it. That sucks. This is the first time I've really had a chance to use this board. My current never spiked above its rating.
I don't have the soldering gear to replace that.
Well, dang.
D
Well, dang.
D
- Franklin97355
Could you post large (less than 1meg,~800x600), clear, detailed pictures of both sides of your board showing any soldering you have done and the connections to it?
- problah
What are the electrical specs of the motors you are using? The shield is only rated for 1.2A/phase.
https://learn.adafruit.com/all-about-st ... he-stepper
- problah
They are Moon 17HD's from my old cupcake printer. The specs for them are 0.3-0.5A.
D
D
What is the resistance of each coil?The specs for them are 0.3-0.5A.
- adafruit2
Can you read any date code on the burnt out chip? does the same motor work on the other side of the shield?
- problah
I'll have to check when I am home. I'm on overnight business tonight.
D
D
- problah
I've got a shot here of the chip:
TB435A1
6612FNG
One looks cooked, and isn't working, but the board wasn't letting me get much voltage/current (it would start climbing past 1.2A after 2-ish volts) to it anymore, so I can't speak to the second chip.
D
TB435A1
6612FNG
D
- adafruit2
ok lets just try replacing it. let us know if that does/doesnt work :)
email support@adafruit
- problah
Thanks! Will do!
I will also order the second one.
D
D
