I have a Adafruit FONA 800 Shield - Voice/Data Cellular GSM for Arduino (https://www.adafruit.com/product/2468) that I'm currently using with an Arduino UNO however; I'd like to use it with a Mega instead. How would I wire this shield up to the Mega without using it as a shield. Essentially, I would just be treating the shield as a breakout board and wiring it to the Mega.
Bonus Question: I also have the Proto-Screwshield (Wingshield) R3 Kit for Arduino (https://www.adafruit.com/product/196) that I'm also using with the UNO. I really like the Screw Terminals versus Headers and would like to know, is there anyway I could either, a. Use this existing shield with the Mega (as most of the pins look to be the same) or if not; b. implemement an alternative solution that would still use screw terminals?
Note: I asked this question yesterday however; I believe I may have posted it in the wrong forum. As such, I apologize for that.
FONA 800 Shield -> Wiring to Mega 2560
Re: FONA 800 Shield -> Wiring to Mega 2560
Shields for the Uno will work on a Mega with some minor limits. The biggest one is that the Uno's SPI pins are 10-13, while a Mega's are 50-53.
If you want to use the FONA 800 Shield as a breakout, ignore the pins along the sides and use the IO breakout pins near the SIM holder. This page of the tutorial show all the signal connections: https://learn.adafruit.com/adafruit-fon ... ld/pinouts
- madelinemountainvector
I got the FONA 800 to work with the Mega 2560.
I had to solder a header into the row of vias right next to the SIM card holder, and jumper these pins together:
RX on the new row to pin 12 on the outside edge.
TX on the new row to pin 11 on the outside edge
RST on the new row to pin 4 on the outside edge.
I also had to cut the connection between the pads on the back (the little square things)
Then in the code, I had to change the pin assignments to this:
#define FONA_RX 12
#define FONA_TX 11
#define FONA_RST 4
Note: other combinations of 12 and 11 will work, as long as they are consistent between which ones you jumper and what you assign them as in the code.
#define FONA_RX 12
#define FONA_TX 11
#define FONA_RST 4
