Hello. I have the Adafruit CC3000 Arduino WiFi shield (PID 1491). All the examples using your library work fine, well done.
However, I have some server code from another project that uses the Wiznet W5100 wifi chip and the standard Arduino IDE ethernet library which I would like to leverage on the CC3000. Looking at this header file from the Adafruit library suggests there is a compatibility layer to make your CC3000 library look like the Arduino library but I am not finding that to be the case. For example, compiling this sample server sketch from the Arduino library immediately gives errors such as 'EthernetServer' does not name a type and indeed grepping the entire source for the CC3000 library I do not find this defined anywhere.
So my question is: is there a technique that allows me to write code for the CC3000 that follows the API of the Arduino ethernet code?
Thanks for your time.
CC3000 lib vs Arduino lib
Re: CC3000 lib vs Arduino lib
The CC3000 library isn't a drop-in replacement for the Arduino Ethernet library.
The Adafruit_CC3000_Server.h header defines a wrapper class (Adafruit_CC3000_ClientRef) that's generally compatible with the way the Ethernet library works, but you'll still need to adjust your code to use it.
