I have brought an Adafruit Monochrome LCD Shield for Arduino.
I've soldered all the pins, installed the Adafruit librarys and uploaded the Example Sketch.
And after adjusting the potentiometer, I was able to see the "Hello, world!" on the display and buttons worked as well.
But unfortunately the "Hello, world!" is very light and there's almost NO BRIGHTNESS on the display, so it's very hard to see what's on the display.
So does anyone know how to fix that?
Brightness Problem with the Monochrome Arduino LCD Shield
- Wassermangel
- Franklin97355
Re: Brightness Problem with the Monochrome Arduino LCD Shiel
Could you post large (less than 1meg,~800x600), clear, detailed pictures of both sides of your board showing any soldering you have done and the connections to it?
- Wassermangel
Here are the photos.
- Attachments
- IMG_20150815_173427.jpg (186.56 KiB) Viewed 264 times
- IMG_20150815_173326.jpg (195.69 KiB) Viewed 264 times
- IMG_20150815_173320.jpg (178.96 KiB) Viewed 264 times
Those solder joints need some work. I can see gold where the solder hasn't made a connection to the pads, and in a few cases I can see the gap between the edge of a hole and a pin.
Take a look at our soldering tutorial for advice on how a well-formed joint should look:
https://learn.adafruit.com/adafruit-gui ... -soldering
