I recently purchased this RGB LCD Shield with a 16x2 negative display:
https://www.adafruit.com/products/714
I soldered it altogether as per the assembly instructions (photos attached) and I am using the sample program that comes in the "Adafruit-RGB-LCD-Shield-Library-master" (see https://codebender.cc/sketch:157836).
The problem I have is that the buttons change the colors per the example program, but there is no text displayed. No Hello World or the number of milliseconds since start up. Just a blank screen that I can change the color of using the buttons.
I had some issues trying to fit the LCD screen onto the shield with the stackable headers, so I had to have the LCD pin headers at a slight angle, but I think the connections are good. I resoldered all of the pin connections to the LCD screen, both on the board and on the LCD screen. I resoldered all of the pins of the MLP23 chip. I'm just a novice solderer, but I think the connections look good. I don't think there are any shorts at least. Still no luck. Same behavior before and after.
Any suggestions? Are there particular pins/connections I can look at that are related to the text display?
-Mark
Issue with RGB LCD Shield 16x2
- mwomack
- Attachments
- IMG_20150926_161119_653.jpg (593.01 KiB) Viewed 293 times
- IMG_20150926_161108_735.jpg (402.86 KiB) Viewed 293 times
- IMG_20150926_161056_286.jpg (179.05 KiB) Viewed 293 times
- mwomack
Re: Issue with RGB LCD Shield 16x2
I should also mention that I tried my shield with two different Uno boards, same results of no text displayed, just the background color.
-Mark
-Mark
- adafruit_support_mike
Have you adjusted the contrast potentiometer? That needs to be cranked most of the way to one side before the LCD starts to show output.
- mwomack
Yes, that was it! I adjusted the potentiometer and the text appeared! Glad to see I could handle the basic soldering after all.
I missed the Adjust Contrast portion of the tutorial. Argh.
Thank you!
-Mark
Thank you!
-Mark
That catches everyone the first couple of times. ;-)
Glad to hear it's working for you. Happy hacking!
