When I try to turn on the GPS using the FONA_Test sketch, I get the message ...
FONA> O
---> AT+CGPSPWR?
<--- ERROR
Failed to turn on
FONA>
I get the same messages for any command for GPS or GPRS.
The cellular functions seem to work fine as I have tested SMS both send and receive.
Could this be a possible bad shield? I have nothing else hooked up to the Uno and the LiPoly battery is fully charged and the unit is receiving power via USB.
FONA SIM808 GPS will not turn on
Re: FONA SIM808 GPS will not turn on
- saulahebert
Saul
- Franklin97355
Can you post one from the bottom of the shield so we can see the soldering?
- saulahebert
as requested...
- IMG_0110.JPG (528.45 KiB) Viewed 2054 times
- adafruit2
be sure you are grabbing the latest library and example code, the GPS commands changed from CGPS to CGNS (and are a little different besides)
- saulahebert
Thank you! This turned out to be the problem... V.1 GPS commands on a V.2 GNSS SIM808 chip
Do you have a version of the FONA program and library modified for the GNSS commands?
I do not see one available for download.
Saul
Saul
- adafruit2
yeah the library has been updated, it now checks which version of the module is used
https://github.com/adafruit/Adafruit_FO ... 6974ae6488
- laurchar
I nearly got the same problem, so I use the same discussion.
I have FONA V2 based on MP3337, the GPS is working well, but I use it without no GSM card.
So, GPRS positioning is not working, is that right : should I have a SIM card to get GPRS position ?
Laurent
Laurent
- adafruit2
yes! you must have a SIM card - GPRS uses the cell network
- laurchar
But, it seems that Adafruit_FONA_3G has not been updated for GNSS and V2 module.
GPS is no more working if I use Adafruit_FONA_3G.
Laurent
Laurent
- adafruit2
the FONA 3g does have GPS but its not very good - it takes a long time to get a fix!
