Hey,
I was wondering if the V2 motor shield can power two stepper motors (Vexta PK266-03A and PK266-03B). I am attaching the data sheet.
1.2Amps per channel, and a max 3amps are the specs of the V2 shield, but my motors are rated for 3amps. (check page 34 attached)
Is there a way we can make this work?
Ali T.
Can I drive two 3amps rated stepper motor with Motor shield
- alitarraf
- Motors datasheet
- motors.PNG (176.55 KiB) Viewed 417 times
- Franklin97355
Re: Can I drive two 3amps rated stepper motor with Motor shi
The motor shield will not work with those motors. Check out this tutorial https://learn.adafruit.com/all-about-st ... he-stepper
- alitarraf
Ok so will the synthetos grbl shield work? Its rated current is 2.25amps PER winding.
My motors have 3amps, 2.25V, 0.75 ohm.
Does this mean 3amps per winding or 3amps total?
I am a little bit confused and would appreciate any help in the right direction.
Ali T.
Ali T.
3A per phase is the maximum safe current that the motor can handle. Each phase (winding) of those motors will draw 3A at 2.25v when not moving because the phase resistance is 0.75 ohms. However, the motor isn't really designed to be run from a 2.25v source. Performance would be terrible if you did. You can run it from a higher voltage source - as long as the driver limits the current per phase to 3A or less. The guide linked above describes how this works.My motors have 3amps, 2.25V, 0.75 ohm.
That is the maximum current per phase that the shield will supply. You can safely run your motors using this shield because the current will be limited to no more than 2.25A.will the synthetos grbl shield work? Its rated current is 2.25amps PER winding.
- alitarraf
Thanks Bill, that makes things clearer!
Ali T.
Ali T.
