Hello!
I am working with GPS and the shield for the first time. Attached is a screenshot of some data that was parsed using the "Adafruit_GPS" library and the appropriate example code.
– Can somebody explain to me, why the quality changed from 0 to 2 indicating a change from invalid to DGPS, when I cannot see an obvious change in the sentence itself?
– Does it have to do with the checksum at the end or something?
– Is the data really invalid? Why, since nothing really changed?
– Can the module use DGPS? Where does the reference come from?
This change occurred approx. 10 mins after the fix.
Thanks in advance.
Ultimate GPS Logger Shield – Confusion about correct fix
- sp100
- GPS_data
- Bildschirmfoto 2015-11-10 um 22.37.53.png (52.81 KiB) Viewed 286 times
Re: Ultimate GPS Logger Shield – Confusion about correct fix
You seem to be comparing the $GPGGA sentences to the $GPRMC sentences. That doesn't work. The fields have different meanings.
The value after 'E' in the $GPRMC sentence is actually 0.02, which is ground speed in knots.
This page has a breakdown of NMEA sentences and what they mean:
http://www.gpsinformation.org/dale/nmea.htm
- sp100
Thanks for the fast reply. I am very sorry for making this not clear enough. I was referring to the GGA sentence where after time, latitude, longitude comes fix and then number of satellites. Which in my attachment is fix = 2 and satellites = 9 all the time.
In the RMC sentence is A for active all the time also. So I want to understand, where the change in the parsed information comes from? And how DGPS is possible?
Does this make more sense now?
The code that parses the NMEA sentences is in the Adafruit_GPS library: https://github.com/adafruit/Adafruit-GP ... it_GPS.cpp
In this case, the fix quality is read from the $GPGGA sentence. The parsed output follows the NMEA sentence itself though, so the one that gave you the 'quality: 0' output would be the one above the text that you posted.
The GPS modules are capable of doing DGPS and SBAS. The commands to enable/disable them are:
and are explained in the GPS module's command datasheet:
http://www.adafruit.com/datasheets/PMTK ... 39-A01.pdf
set DGPS mode: $PMTK301,1*2D
disable DGPS mode: $PMTK301,0*2C
set SBAS mode: $PMTK319,1*24
enable SBAS: $PMTK313,1*2E
disable SBAS: $PMTK313,0*2F
