help with my project
Delwig
Post by Delwig »
Hello, I need some help,
I have an Arduino Uno and a Adafruit 16-Channel 12-bit PWM/Servo Shield - I2C interface,
I can get them to sweep and go separate, but I need help with making them move simultaneously and also at different times,
For Example, I need 5 servos to move 45 degrees every 48 seconds and return and 5 servos to move 45 degrees every 2 seconds and return and 5 servos to move 45 degrees every 3.5 mins and return.
This is for a phone tapper with stylus pens project.
any help would be greatly appreciated.
Thank you
Re: help with my project
This tutorial shows how to control multiple servos simultaneously:
https://learn.adafruit.com/multi-taskin ... 1/overview
Delwig
Post by Delwig »
only problem with that is i have Adafruit 16-Channel 12-bit PWM/Servo Shield - I2C interface
and the normal arduino code does not seem to work
it has to use the Adafruit PWM Servo Driver Library and i have yet to find a tutorial on that that explains anything more then Pulse Length, setPWMFreq(freq), and setPWM(channel, on, off)
This shows how to convert degrees to pulselength.
https://learn.adafruit.com/adafruit-16- ... lse-length
And the same multitasking principles apply regardless of which library you use.
