PN532 Shield not outputting to serial
- lilbbytrimble
So awhile back I purchased a PN532 Shield and finally today got around to soldering it together and uploading the format code to my Arduino Leonardo. The upload process runs just fine, however when I open the serial monitor I get zero output to it, and I've even made sure the baud rate is set to the proper number. However I do notice that on my shield that the busy LED is always lit but I don't have enough experience with the board to know if that is an issue or not. If anyone has any helpful advice that would be greatly appreciated!
- Franklin97355
Re: PN532 Shield not outputting to serial
Could you post large (less than 1meg,~800x600), clear, detailed pictures of both sides of your board showing any soldering you have done and the connections to it?
- marshaj847
Have you made wiring corrections for use on a Leonardo
https://learn.adafruit.com/adafruit-pn5 ... eld-wiring
"The IRQ pin is tied to Digital pin #2 by default. However, on the Arduino Leonardo and Yun, digital #2 is used for I2C which will not work. If using with a Leonardo or Yun, cut the trace beween the IRQ pin and Digital #2 and solder a wire from IRQ pin to Digital #4 or higher. Then change the example code so the the IRQ pin is declared as the new pin (say #6) not #"
I have a new PM532 breakout board hooked up to an Uno (with a 328 chip). I've uploaded the ReadMifare sketch, but all that it is outputting to the serial monitor is this: ��>�
what might be wrong? I've double-checked the wiring....
- Franklin97355
Check the baud rate between the program you are running and the serial monitor. They both need to be the same.
yes, the baud rate was off.
now I am getting this message:
Hello!
Hello!
wiring problem? or?TIMEOUT!
TIMEOUT!
Didn't find PN53x board
- Franklin97355
If you post some pictures of your boards and connections we can take a look.
is this sufficient information?
Problem solved! I had the MOSI from the PN532 connected to the Arduino digital pin 12 instead of the 4050!
