Hello.
My system built with Atmega128 for HMC5883L sensor I2C communication (100KHz).
X and Y raw data is ok, but the raw data for Z axis is very strange, always 0 or -1, which means read data from the sensor for Z axis is always 0 or 1.
Please refer the attached figure.
Is it normal?
Z axis raw data from HMC5883L is 0 or -1
- mylogic
- Compass Problem.jpg (244.63 KiB) Viewed 290 times
Re: Z axis raw data from HMC5883L is 0 or -1
Do you get the same output if you hold the breakout at different angles (rotating X to Y, Y to Z, Z to X, and so on)?
- mylogic
Yes, it is. Z value always 0 or -1 for any different rotation angles.adafruit_support_mike wrote:Do you get the same output if you hold the breakout at different angles (rotating X to Y, Y to Z, Z to X, and so on)?
That sounds like a dead sensor.
Send a note to [email protected] with a link to this thread and your order number. The folks there will get you a replacement.
(#1746)
(#1746)
